电子发烧友论坛|
开启uart_rxfifo_tout中断,一次性发送数据给单片机,理论上串口接收超时中断只能触发一次中断,但却触发了两次rxfifo_tout中断。求解答。
发送数据Code: Select all 0x61 0x61 0x61 总返回数据Code: Select all 0x61 0x61 0x61 0x4F 0x4B 0x01 0x4F 0x4B 0x02 (0x4F 0x4B为OK)Code: Select all #include #include #include "soc/uart_periph.h"#include "driver/uart.h"#include "soc/uhci_reg.h"#include "driver/gpio.h"#include "esp_event.h"#include "esp_log.h"TaskHandle_t rx_task_handle;#define UART_LOG "uart_log" //串口TAG#define UART1_RX_IO GPIO_NUM_9 //UART1_RX引脚 -> GPIO9#define UART1_TX_IO GPIO_NUM_10 //UART1_TX引脚 -> GPIO10#define BUFF_SIZE 1024uart_isr_handle_t uart1_handle;uint8_t rxbuf[128];uint16_t urxlen;static void IRAM_ATTR uart_intr_handle(void *arg){ volatile uart_dev_t *uart = &UART1; static uint8_t count = 0; count++; volatile uint8_t flag = 0; //标志位判断是否触发rxfifo_tout中断 if(uart->int_st.rxfifo_tout == 1) { uart_clear_intr_status(UART_NUM_1, UART_RXFIFO_TOUT_INT_CLR); flag = 1; //触发rxfifo_tout中断,标志位置1 } while (uart->status.rxfifo_cnt) { uint8_t c = uart->ahb_fifo.rw_byte; uart_tx_chars(UART_NUM_1, (char *)&c, 1); //返回数据 } if(flag) uart_tx_chars(UART_NUM_1, "OK", 2); //进入rxfifo_tout中断返回OK uart_tx_chars(UART_NUM_1,(char *)&count,1); //返回当前进入中断次数}void app_main(void){ uart_config_t uart_conf = { .baud_rate = 115200, //波特率:115200 .data_bits = UART_DATA_8_BITS, //数据位:八位 .parity = UART_PARITY_DISABLE, //校验位:不校验 .stop_bits = UART_STOP_BITS_1, //停止位:1 .flow_ctrl = UART_HW_FLOWCTRL_DISABLE, //硬件控制流:不启用 .source_clk = UART_SCLK_APB, //时钟总线:APB总线 }; uart_port_t uart_port = UART_NUM_1; //UART1 uart_param_config(uart_port, &uart_conf); uart_set_pin(uart_port, UART1_TX_IO, UART1_RX_IO, GPIO_NUM_NC, GPIO_NUM_NC); uart_driver_install(uart_port, BUFF_SIZE*2, 0, 0, NULL, 0); //关闭预先创建的uart中断 uart_isr_free(uart_port); uart_isr_register(uart_port, uart_intr_handle,NULL, ESP_INTR_FLAG_IRAM, &uart1_handle); uart_disable_intr_mask(uart_port, 0x001FFFFF); //关闭预先的串口中断 uart_enable_intr_mask(uart_port, UART_RXFIFO_TOUT_INT_ENA); //开启RXFIFO_TOUT中断 while(1) { vTaskDelay(1); }} |
2个回答
试试把uart_clear_intr_status(UART_NUM_1, UART_RXFIFO_TOUT_INT_CLR); 放到中断函数完成所有操作的最后面
我用你的代码试了,放在最后面的时候不会触发两次 //中断服务函数放在IRAM中执行,所以在这里定义的时候要添加IRAM_ATTR static void IRAM_ATTR uart2_irq_handler(void *arg) { //uart结构体指针指向串口中断寄存器 volatile uart_dev_t *uart = &UART2; //判断是什么中断触发了 if(uart->int_st.rxfifo_tout == 1) { //判断数据寄存器里是否有数据 while (uart->status.rxfifo_cnt) { //此处改为装入自己的buf缓冲区 uint8_t c = uart->fifo.rw_byte; //打印,中断内不可使用log打印 uart_write_bytes(UART_NUM_2, (char *)&c, 1); //把接收的数据重新打印出来 } //清除中断标志位 //uart_write_bytes(UART_NUM_2, "uart2_irq_handler", 15); //把接收的数据重新打印出来 uart_clear_intr_status(UART_NUM_2, UART_RXFIFO_TOUT_INT_CLR); } } |
根据您的描述,您在使用单片机时遇到了一个问题:在开启uart_rxfifo_tout中断后,一次性发送数据给单片机,但触发了两次rxfifo_tout中断。为了解决这个问题,我们可以从以下几个方面进行分析:
1. 检查中断配置:首先,请确保您正确配置了中断。检查您的中断设置,确保uart_rxfifo_tout中断已经正确启用。 2. 检查数据发送和接收逻辑:请检查您的发送和接收数据的逻辑,确保发送的数据与接收的数据一致。如果发送的数据与接收的数据不一致,可能会导致中断触发多次。 3. 检查硬件连接:请检查您的硬件连接,确保UART通信线路没有故障,如接触不良或线路干扰等。 4. 检查中断服务程序:请检查您的中断服务程序,确保在中断触发时,正确处理了接收到的数据,并在处理完成后清除了中断标志。如果中断标志没有被正确清除,可能会导致中断再次触发。 5. 检查中断优先级:请检查您的中断优先级设置,确保uart_rxfifo_tout中断的优先级正确。如果中断优先级设置不正确,可能会导致中断服务程序执行不完全,从而触发多次中断。 6. 检查软件版本和硬件兼容性:请确保您使用的软件版本与您的硬件兼容。如果软件版本与硬件不兼容,可能会导致一些意外的行为,如中断触发多次。 综上所述,要解决这个问题,您需要从多个方面进行排查。希望这些建议能帮助您找到问题的原因并解决它。 |
只有小组成员才能发言,加入小组>>
945 浏览 0 评论
1672 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1330 浏览 1 评论
1233 浏览 1 评论
5021 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1253浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
927浏览 3评论
2338浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2526浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1052浏览 2评论
/9
GMT+8, 2025-12-2 05:49 , Processed in 0.504038 second(s), Total 44, Slave 37 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
401
