电子发烧友论坛|
(一)现象
我使用idf开发esp32c3,使用i2c外设时出现问题。I2C正常发送了出去,但从机没有应答。 我此前使用过nxp的lpc55s69进行过测试,并将这两次的波形使用逻辑分析仪采集出来,区别仅有ACK应答。读取数据的时候现象也是一样的,从机无法作出应答,但时序波形与lpc55s69下实验仅有ack部分有区别。 从机使用AS5600和ADXL345都测试过,现象如上一致。 引脚也更换过多个,包括4、5、6、8、9,都是如此。 实验使用的esp32c3为合宙版。后来又使用安可信的esp32(非c3),额外编写esp32工程,现象依然如此。 实验使用的idf为v4.4-release分支。开发环境ubuntu20.04+vscode+idf4.4 I use idf to program esp32c3, and problem occurred when using i2c. The i2c was send successfully as display in logic analyzer, but no ack receive from slaver. I had been test the slaver(both adxl345 and as5600) in NXP's lpc55s69, and it work as same as above, except the ack is successfully receive. I have change the pin of i2c, but it does not work! the board in this experience is esp32c3 developed by hezhou: https://wiki.luatos.com/chips/esp32c3/board.html the idf version is v4.4-release. and I develop it in ubuntu20.04+vscode+idf4.4 (二)代码 i2c_simple.tar.gz (16.17 KiB) Downloaded 351 times 初始化 init static esp_err_t i2c_master_init(void) { int i2c_master_port = I2C_MASTER_NUM; i2c_config_t conf = { .mode = I2C_MODE_MASTER, .sda_io_num = I2C_MASTER_SDA_IO, .scl_io_num = I2C_MASTER_SCL_IO, .sda_pullup_en = GPIO_PULLUP_ENABLE, .scl_pullup_en = GPIO_PULLUP_ENABLE, .master.clk_speed = I2C_MASTER_FREQ_HZ }; i2c_param_config(i2c_master_port, &conf); return i2c_driver_install(i2c_master_port, conf.mode, I2C_MASTER_RX_BUF_DISABLE, I2C_MASTER_TX_BUF_DISABLE, 0); } 逻辑代码 the logic code 1-自己编写cmd-program by cmd // i2c_cmd_handle_t cmd = i2c_cmd_link_create(); // i2c_master_start(cmd); // i2c_master_write_byte(cmd, AS5600_I2C_ADDR << 1 | I2C_MASTER_WRITE, false); // i2c_master_write_byte(cmd, 0x00, false); // i2c_master_stop(cmd); // ret = i2c_master_cmd_begin(0, cmd, 1000 / portTICK_RATE_MS); // i2c_cmd_link_delete(cmd); // cmd = i2c_cmd_link_create(); // vTaskDelay(50 / portTICK_PERIOD_MS); // i2c_master_start(cmd); // i2c_master_write_byte(cmd, AS5600_I2C_ADDR << 1 | I2C_MASTER_READ, false); // i2c_master_read_byte(cmd, data, false); // i2c_master_stop(cmd); // ret = i2c_master_cmd_begin(0, cmd, 1000 / portTICK_RATE_MS); // i2c_cmd_link_delete(cmd); 2-调用函数-program by usb the sdk function i2c_master_write_to_device(I2C_NUM_0, 0x1D, data, 1, 500 / portTICK_PERIOD_MS); (三) https://img-mid.csdnimg.cn/release/stat ... 320,m_lfit https://img-mid.csdnimg.cn/release/stat ... 320,m_lfit 图片外链很麻烦,详细请看:https://ask.csdn.net/questions/7752699 基于以上情况,我只能怀疑是不是sda电平在接收ack的时候被主机钳住总线了? 毕竟合宙的板子似乎外部没有接任何器件了,尽只有我挂的adxl345 而且安可信的esp32板子也是同样的情况,难道是有什么配置没有配好吗? I think the sda might be limited by esp32c3, thus the slaver can't pull it down? --------------------2022 07 05--------------------- 今天尝试了DS3231,同样的代码,意外的竟可以驱动!但换回ADXL345依然不能驱动,我仅仅修改了从机地址而已! 但有个问题 DS3231 模块是一个3.3-5V都兼容的,模块,但在esp32c3上只有5V才有正常的Ack响应。是不是里面某些电气特性上有问题? --------------------2022 07 06--------------------- 今天又尝试了DS3231,发现虽然通过设置ack相关位为0实现了应答,但读上来的数据全是FF,看样子数据上传的时候还是被钳住了总线。 |
1个回答
根据您提供的信息,您在使用ESP32C3进行I2C通信时遇到了没有应答的问题。以下是一些建议和解决方案,希望能帮助您解决问题:
1. 检查硬件连接:确保I2C数据线(SDA和SCL)连接正确,没有接触不良或短路的情况。同时检查电源和地线是否连接稳定。 2. 检查I2C设备地址:确保您使用的I2C设备地址与代码中设置的地址一致。不同的设备可能有不同的地址,需要在数据手册中查找。 3. 检查I2C时钟频率:ESP32C3的I2C时钟频率可能与您的从设备不兼容。尝试降低时钟频率,例如使用100kHz或更低的频率。 4. 检查I2C初始化代码:确保您的I2C初始化代码正确无误,包括I2C端口号、时钟频率、数据位等参数。 5. 使用I2C扫描工具:使用I2C扫描工具(如i2cdetect)扫描I2C总线上的设备,以确保您的设备被正确识别。 6. 检查I2C总线冲突:确保I2C总线上没有其他设备与您的设备发生冲突。如果有多个设备共享同一I2C总线,请确保它们的地址不重复。 7. 检查I2C设备:确保您的I2C设备(AS5600和ADXL345)工作正常,没有损坏或故障。 8. 更新ESP-IDF:您提到使用的ESP-IDF版本为v4.4-release,可以尝试升级到最新版本,以获取可能的修复和改进。 9. 检查ESP32C3硬件:如果以上方法都无法解决问题,可能是ESP32C3硬件本身存在问题。您可以尝试更换另一块ESP32C3进行测试。 |
只有小组成员才能发言,加入小组>>
330 浏览 0 评论
948 浏览 0 评论
1676 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1335 浏览 1 评论
1234 浏览 1 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1254浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
928浏览 3评论
2341浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2529浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1052浏览 2评论
/9
GMT+8, 2025-12-3 14:17 , Processed in 0.751450 second(s), Total 44, Slave 37 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
646
