编译amazon_alexa,主板选择audio_board_lyratd_dspg,最后Link时候报错。错误信息如下:
[1407/1409] Linking CXX executable avs.elf FAILED: avs.elf cmd.exe /C "cd . && C:Espressiftoolsxtensa-esp32-elfesp-2021r2-patch3-8.4.0xtensa-esp32-elfbinxtensa-esp32-elf-g++.exe -mlongcalls -Wno-frame-address @CMakeFilesavs.elf.rsp -o avs.elf && cd ." c:/espressif/tools/xtensa-esp32-elf/esp-2021r2-patch3-8.4.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: avs.elf section `.iram0.text' will not fit in region `iram0_0_seg' c:/espressif/tools/xtensa-esp32-elf/esp-2021r2-patch3-8.4.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: IRAM0 segment data does not fit. c:/espressif/tools/xtensa-esp32-elf/esp-2021r2-patch3-8.4.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: region `iram0_0_seg' overflowed by 2732 bytes c:/espressif/tools/xtensa-esp32-elf/esp-2021r2-patch3-8.4.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: D:/esp-va-sdk/components/esp-ssdp/lib/libesp-ssdp.a(lssdp.c.obj):(.literal.trim_spaces+0x0): undefined reference to `__locale_ctype_ptr' c:/espressif/tools/xtensa-esp32-elf/esp-2021r2-patch3-8.4.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: D:/esp-va-sdk/components/esp-ssdp/lib/libesp-ssdp.a(lssdp.c.obj):(.text.trim_spaces+0x20): undefined reference to `__locale_ctype_ptr' c:/espressif/tools/xtensa-esp32-elf/esp-2021r2-patch3-8.4.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: D:/esp-va-sdk/components/esp-ssdp/lib/libesp-ssdp.a(lssdp.c.obj):(.text.trim_spaces+0x38): undefined reference to `__locale_ctype_ptr' c:/espressif/tools/xtensa-esp32-elf/esp-2021r2-patch3-8.4.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: D:/esp-va-sdk/components/esp-ssdp/lib/libesp-ssdp.a(lssdp.c.obj):(.text.trim_spaces+0x51): undefined reference to `__locale_ctype_ptr' c:/espressif/tools/xtensa-esp32-elf/esp-2021r2-patch3-8.4.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: D:/esp-va-sdk/components/esp-ssdp/lib/libesp-ssdp.a(lssdp.c.obj):(.text.trim_spaces+0x6a): undefined reference to `__locale_ctype_ptr' c:/espressif/tools/xtensa-esp32-elf/esp-2021r2-patch3-8.4.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: D:/esp-va-sdk/components/voice_assistant/lib/libavs.a(dialog.c.obj):(.literal.dialog_sm_thread+0x30): undefined reference to `xTaskNotify' c:/espressif/tools/xtensa-esp32-elf/esp-2021r2-patch3-8.4.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: D:/esp-va-sdk/components/voice_assistant/lib/libavs.a(dialog.c.obj):(.text.dialog_sm_thread+0xae): undefined reference to `xTaskNotify' collect2.exe: error: ld returned 1 exit status ninja: build stopped: subcommand failed. ninja failed with exit code 1 |
1个回答
根据您提供的错误信息,我们可以分析以下几个可能的原因:
1. 路径问题:请检查您的工具链路径是否正确。错误信息中提到了 "c:/espressif/tools/xtensa-esp32-elf/esp-2021",确保这个路径是正确的,并且工具链已经正确安装。 2. 权限问题:在某些情况下,编译器可能没有足够的权限来访问某些文件或目录。请尝试以管理员身份运行编译器或检查文件/目录的权限设置。 3. 依赖问题:请确保您的项目中所有依赖项都已正确安装和配置。这可能包括第三方库、头文件等。 4. CMake配置问题:检查您的 CMakeLists.txt 文件,确保所有必要的配置和设置都已正确添加。例如,确保您的项目链接了正确的库,以及编译器和链接器的选项设置正确。 5. 编译器/链接器错误:如果以上步骤都无法解决问题,可能是编译器或链接器本身的问题。您可以尝试更新或重新安装编译器/链接器,或者尝试使用不同的编译器/链接器。 为了解决这个问题,您可以尝试以下步骤: 1. 确认工具链路径正确无误。 2. 检查项目依赖项是否完整。 3. 检查 CMakeLists.txt 文件中的配置和设置。 4. 尝试以管理员身份运行编译器。 5. 如果问题仍然存在,尝试更新或重新安装编译器/链接器。 |
只有小组成员才能发言,加入小组>>
311浏览 6评论
268浏览 5评论
有没有办法在不使用混杂模式的情况下实现Wifi驱动程序接收缓冲区访问中断呢?
258浏览 5评论
261浏览 4评论
239浏览 4评论
GMT+8, 2024-6-25 14:55 , Processed in 0.500355 second(s), Total 47, Slave 41 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
