使用同样的代码和工程配置挂载合宙9.9元的开发板JTAG是可以的,环境使用的是Espressif-IDE 2.5
现在工程PCB使用的是ESP32-C3-MINI-U模组 观察硬件差异只有合宙9.9元的开发板的FLASH是外置的 ESP32-C3-MINI-U模组是片内FLASH 在工程中已经关闭了内存保护,但模组还是挂不上JTAG,日志如下: 大概能看出来是openocd对flash的操作有什么问题 Open On-Chip Debugger v0.11.0-esp32-20211220 (2021-12-20-15:43) Licensed under GNU GPL v2 For bug reports, read http://openocd.org/doc/doxygen/bugs.html Info : only one transport option; autoselect 'jtag' Info : esp_usb_jtag: VID set to 0x303a and PID to 0x1001 Info : esp_usb_jtag: capabilities descriptor set to 0x2000 Warn : Transport "jtag" was already selected Flashing C:/Espressif/frameworks/esp-idf-v4.4/workspace/BMS76952_4S/build/partition_table/partition-table.bin at 0x8000 Error: libusb_open() failed with LIBUSB_ERROR_NOT_SUPPORTED Info : esp_usb_jtag: Device found. Base speed 40000KHz, div range 1 to 255 Info : clock speed 40000 kHz Info : JTAG tap: esp32c3.cpu tap/device found: 0x00005c25 (mfg: 0x612 (Espressif Systems), part: 0x0005, ver: 0x0) Info : Examined RISC-V core; found 1 harts Info : hart 0: XLEN=32, misa=0x40101104 Info : starting gdb server for esp32c3 on 3333 Info : Listening on port 3333 for gdb connections Info : JTAG tap: esp32c3.cpu tap/device found: 0x00005c25 (mfg: 0x612 (Espressif Systems), part: 0x0005, ver: 0x0) Info : [0] Found 8 triggers Error: Failed to get flash maps (4294967295)! Warn : Failed to get flash mappings (-4)! Error: Failed to get flash size! Error: Failed to get flash size! Error: Failed to probe flash, size 0 KB Error: auto_probe failed Error: Failed to find bank 'esp32c3.flash'! ** Flashing Failed ** -1 Started by GNU MCU Eclipse Info : Listening on port 6666 for tcl connections Info : Listening on port 4444 for telnet connections Info : accepting 'gdb' connection on tcp/3333 Warn : No symbols for FreeRTOS! Error: Failed to get flash maps (4294967295)! Warn : Failed to get flash mappings (-4)! Error: Failed to get flash size! Error: Failed to get flash size! Error: Failed to probe flash, size 0 KB Error: auto_probe failed Error: Connect failed. Consider setting up a gdb-attach event for the target to prepare target for GDB connect, or use 'gdb_memory_map disable'. Error: attempted 'gdb' connection rejected shutdown command invoked |
1个回答
由于ESP32-MINI-U模组没有内置JTAG调试接口,您需要使用其他方法进行调试。以下是一些建议:
1. 使用ESP-Prog调试器:ESP-Prog是一款专为ESP32设计的调试器,可以通过USB连接到您的计算机。您可以使用它进行JTAG调试。 2. 使用UART调试:虽然这不是JTAG调试,但您可以使用UART(通用异步收发传输器)进行基本的调试。您需要将ESP32-MINI-U模组的TX和RX引脚连接到计算机的串行端口,然后使用串行通信工具(如PuTTY、Minicom等)查看调试信息。 3. 使用Espressif的ESP-IDF框架:ESP-IDF提供了一套完整的开发环境,包括调试工具。您可以使用它来编译、烧录和调试您的程序。 4. 检查您的配置:确保您的Espressif-IDE 2.5环境配置正确,包括烧录器、串行端口等设置。此外,检查您的OpenOCD版本是否与ESP32-C3-MINI-U模组兼容。 5. 更新固件:尝试更新ESP32-C3-MINI-U模组的固件,以解决可能的兼容性问题。 |
只有小组成员才能发言,加入小组>>
471 浏览 0 评论
994 浏览 0 评论
1710 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1370 浏览 1 评论
1256 浏览 1 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1289浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
943浏览 3评论
2387浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2577浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1071浏览 2评论
/9
GMT+8, 2025-12-14 14:17 , Processed in 0.782088 second(s), Total 76, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
556
