电子发烧友论坛|
ESP-ROM:esp32s3-20210327
Build:Mar 27 2021 rst:0x8 (TG1WDT_SYS_RST),boot:0x8 (SPI_FAST_FLASH_BOOT) Saved PC:0x40378c6f SPIWP:0xee mode:DIO, clock div:1 load:0x3fce3808,len:0x39c load:0x403c9700,len:0x9bc load:0x403cc700,len:0x28dc SHA-256 comparison failed: Calculated: 9477899d59fa5164e630d8218cb3994031873358e9105b31f53911d2dfd36c72 Expected: ffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffff Attempting to boot anyway... entry 0x403c98c0 ESP-ROM:esp32s3-20210327 Build:Mar 27 2021 rst:0x8 (TG1WDT_SYS_RST),boot:0x8 (SPI_FAST_FLASH_BOOT) Saved PC:0x40378c6f SPIWP:0xee mode:DIO, clock div:1 load:0x3fce3808,len:0x39c load:0x403c9700,len:0x9bc load:0x403cc700,len:0x28dc SHA-256 comparison failed: Calculated: 9477899d59fa5164e630d8218cb3994031873358e9105b31f53911d2dfd36c72 Expected: ffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffff Attempting to boot anyway... entry 0x403c98c0 ESP-ROM:esp32s3-20210327 Build:Mar 27 2021 rst:0x8 (TG1WDT_SYS_RST),boot:0x8 (SPI_FAST_FLASH_BOOT) Saved PC:0x40378c6f SPIWP:0xee mode:DIO, clock div:1 load:0x3fce3808,len:0x39c load:0x403c9700,len:0x9bc load:0x403cc700,len:0x28dc SHA-256 comparison failed: Calculated: 9477899d59fa5164e630d8218cb3994031873358e9105b31f53911d2dfd36c72 Expected: ffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffff Attempting to boot anyway... entry 0x403c98c0 ESP-ROM:esp32s3-20210327 Build:Mar 27 2021 rst:0x8 (TG1WDT_SYS_RST),boot:0x8 (SPI_FAST_FLASH_BOOT) Saved PC:0x40378c6f SPIWP:0xee mode:DIO, clock div:1 load:0x3fce3808,len:0x39c load:0x403c9700,len:0x9bc load:0x403cc700,len:0x28dc SHA-256 comparison failed: Calculated: 9477899d59fa5164e630d8218cb3994031873358e9105b31f53911d2dfd36c72 Expected: ffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffff Attempting to boot anyway... entry 0x403c98c0 ESP-ROM:esp32s3-20210327 Build:Mar 27 2021 rst:0x8 (TG1WDT_SYS_RST),boot:0x8 (SPI_FAST_FLASH_BOOT) Saved PC:0x40378c6f SPIWP:0xee mode:DIO, clock div:1 load:0x3fce3808,len:0x39c load:0x403c9700,len:0x9bc load:0x403cc700,len:0x28dc SHA-256 comparison failed: Calculated: 9477899d59fa5164e630d8218cb3994031873358e9105b31f53911d2dfd36c72 Expected: ffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffff Attempting to boot anyway... entry 0x403c98c0 ESP-ROM:esp32s3-20210327 Build:Mar 27 2021 rst:0x8 (TG1WDT_SYS_RST),boot:0x8 (SPI_FAST_FLASH_BOOT) Saved PC:0x40378c6f SPIWP:0xee mode:DIO, clock div:1 load:0x3fce3808,len:0x39c load:0x403c9700,len:0x9bc load:0x403cc700,len:0x28dc SHA-256 comparison failed: Calculated: 9477899d59fa5164e630d8218cb3994031873358e9105b31f53911d2dfd36c72 Expected: ffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffff Attempting to boot anyway... entry 0x403c98c0 ESP-ROM:esp32s3-20210327 Build:Mar 27 2021 rst:0x8 (TG1WDT_SYS_RST),boot:0x8 (SPI_FAST_FLASH_BOOT) Saved PC:0x40378c6f SPIWP:0xee mode:DIO, clock div:1 load:0x3fce3808,len:0x39c load:0x403c9700,len:0x9bc load:0x403cc700,len:0x28dc SHA-256 comparison failed: Calculated: 9477899d59fa5164e630d8218cb3994031873358e9105b31f53911d2dfd36c72 Expected: ffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffff Attempting to boot anyway... entry 0x403c98c0 ESP-ROM:esp32s3-20210327 Build:Mar 27 2021 rst:0x8 (TG1WDT_SYS_RST),boot:0x8 (SPI_FAST_FLASH_BOOT) Saved PC:0x40378c6f SPIWP:0xee mode:DIO, clock div:1 load:0x3fce3808,len:0x39c load:0x403c9700,len:0x9bc load:0x403cc700,len:0x28dc SHA-256 comparison failed: Calculated: 9477899d59fa5164e630d8218cb3994031873358e9105b31f53911d2dfd36c72 Expected: ffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffff Attempting to boot anyway... entry 0x403c98c0 |
1个回答
从您提供的日志信息来看,ESP32-S3设备不停重启的原因可能是以下几个方面:
1. **看门狗定时器复位**:日志中提到了`TG1WDT_SYS_RST`,这表示系统被看门狗定时器(Task Watchdog Timer)复位。这通常是因为程序在某个地方卡住,导致没有在预定时间内喂狗(即没有调用看门狗定时器的喂狗函数),看门狗定时器就会触发系统复位。 2. **SPI Flash 启动模式**:日志中的`SPI_FAST_FLASH_BOOT`表示设备正在尝试通过SPI Flash快速启动。如果SPI Flash中的数据损坏或者启动过程中出现问题,也可能导致设备无法正常启动并不断重启。 3. **SHA-256校验失败**:日志中的`SHA-256 comparison failed`表示设备在尝试启动时,对SPI Flash中的固件进行了SHA-256校验,但是校验结果与预期的值不匹配。这可能是因为固件文件损坏、烧录过程中出现问题或者固件本身存在问题。 4. **烧录参数问题**:日志中的`SPIWP:0xee`、`mode:DIO`、`clock div:1`等参数表示烧录时使用的SPI Flash参数。如果这些参数与实际的Flash芯片不匹配,也可能导致烧录失败或者设备无法正常启动。 为了解决这个问题,您可以尝试以下几个步骤: - **检查代码**:确保您的代码中没有无限循环或者阻塞操作,确保在看门狗定时器超时前进行喂狗操作。 - **重新烧录固件**:使用正确的烧录参数,确保固件文件没有损坏,并且在烧录过程中没有出现问题。 - **检查SPI Flash**:如果可能,尝试更换SPI Flash芯片,或者使用其他设备进行烧录测试,以排除硬件问题。 - **更新固件和烧录工具**:确保您使用的固件和烧录工具是最新版本,以避免已知的bug或者兼容性问题。 如果问题仍然存在,您可能需要进一步检查硬件连接、电源供应等其他方面,或者寻求社区或者专业人士的帮助。 |
只有小组成员才能发言,加入小组>>
945 浏览 0 评论
1672 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1330 浏览 1 评论
1233 浏览 1 评论
5021 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1253浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
927浏览 3评论
2338浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2527浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1052浏览 2评论
/9
GMT+8, 2025-12-2 06:32 , Processed in 0.423750 second(s), Total 40, Slave 33 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
974
