电子发烧友论坛|
使用的是esp32c3,外接flash为4M,在初始的工程加入部分代码无问题,可以正常执行。
继续加入多个.a后,出现了第二个DROM,readelf可以看到多了一个 [17] .eh_frame。此时编译无问题,但是执行时报错boot: Image contains multiple DROM segments. Only the last one will be mapped. Section Headers: [Nr] Name Type Addr Off Size ES Flg Lk Inf Al [ 0] NULL 00000000 000000 000000 00 0 0 0 [ 1] .rtc.text NOBITS 50000000 184000 000010 00 WA 0 0 1 [ 2] .rtc.force_fast PROGBITS 50000010 184020 000000 00 W 0 0 1 [ 3] .rtc.data PROGBITS 50000010 184010 000010 00 WA 0 0 8 [ 4] .rtc_noinit PROGBITS 50000020 184020 000000 00 W 0 0 1 [ 5] .rtc.force_slow PROGBITS 50000020 184020 000000 00 W 0 0 1 [ 6] .iram0.text PROGBITS 40380000 0d6000 00fae6 00 AX 0 0 256 [ 7] .dram0.dummy NOBITS 3fc80000 0c3000 00fc00 00 WA 0 0 1 [ 8] .dram0.data PROGBITS 3fc8fc00 0d2c00 002c78 00 WA 0 0 8 [ 9] .noinit PROGBITS 3fc92878 184020 000000 00 W 0 0 1 [10] .dram0.bss NOBITS 3fc92880 0d5878 0044c8 00 WA 0 0 16 [11] .flash.text PROGBITS 42000020 0e6020 09d95a 00 AX 0 0 2 [12] .flash_rodata_dum NOBITS 3c000020 001020 0a0000 00 WA 0 0 1 [13] .flash.appdesc PROGBITS 3c0a0020 0a1020 000100 00 A 0 0 16 [14] .flash.rodata PROGBITS 3c0a0120 0a1120 021318 00 WA 0 0 16 [15] .got PROGBITS 3c0c1438 0c2438 00000c 04 WA 0 0 4 [16] .got.plt PROGBITS 3c0c1444 0c2444 000008 04 WA 0 0 4 [17] .eh_frame PROGBITS 3c0c1450 0c2450 0007e8 00 A 0 0 8 [18] .flash.rodata_nol NOBITS 3c0c1c38 0c2c38 0020e6 00 A 0 0 4 [19] .iram0.text_end NOBITS 4038fae6 0e5ae6 00011a 00 WA 0 0 1 [20] .iram0.data PROGBITS 4038fc00 184020 000000 00 W 0 0 1 [21] .iram0.bss PROGBITS 4038fc00 184020 000000 00 W 0 0 1 [22] .dram0.heap_start NOBITS 3fc96d48 0d5878 000008 00 WA 0 0 1 [23] .debug_info PROGBITS 00000000 184020 26331c 00 0 0 1 [24] .debug_abbrev PROGBITS 00000000 3e733c 04ad18 00 0 0 1 [25] .debug_loc PROGBITS 00000000 432054 0fcd82 00 0 0 1 [26] .debug_aranges PROGBITS 00000000 52edd8 00b920 00 0 0 8 [27] .debug_ranges PROGBITS 00000000 53a6f8 010750 00 0 0 1 [28] .debug_line PROGBITS 00000000 54ae48 1aad78 00 0 0 1 [29] .debug_str PROGBITS 00000000 6f5bc0 059ebe 01 MS 0 0 1 [30] .comment PROGBITS 00000000 74fa7e 00005b 01 MS 0 0 1 [31] .riscv.attributes RISCV_ATTRIBUTE 00000000 74fad9 00002a 00 0 0 1 [32] .debug_frame PROGBITS 00000000 74fb04 02a3d0 00 0 0 4 [33] .debug_loclists PROGBITS 00000000 779ed4 0195ab 00 0 0 1 [34] .debug_rnglists PROGBITS 00000000 79347f 001b21 00 0 0 1 [35] .debug_line_str PROGBITS 00000000 794fa0 003078 01 MS 0 0 1 [36] .symtab SYMTAB 00000000 798018 021cb0 10 37 3252 4 [37] .strtab STRTAB 00000000 7b9cc8 027b19 00 0 0 1 [38] .shstrtab STRTAB 00000000 7e17e1 0001e7 00 0 0 1 segments段如下 [0;32mI (226) esp_image: segment 0: paddr=00010020 vaddr=3c0a0020 size=2142ch (136236) map[0m [0;32mI (298) esp_image: segment 1: paddr=00031454 vaddr=3fc8fc00 size=02c78h ( 11384) load[0m [0;32mI (360) esp_image: segment 2: paddr=000340d4 vaddr=40380000 size=0d374h ( 54132) load[0m [0;32mI (421) esp_image: segment 3: paddr=00041450 vaddr=3c0c1450 size=007e8h ( 2024) map[0m [0;32mI (482) esp_image: segment 4: paddr=00041c40 vaddr=4038d374 size=02774h ( 10100) load[0m [0;32mI (543) esp_image: segment 5: paddr=000443bc vaddr=50000010 size=00010h ( 16) load[0m [0;32mI (603) esp_image: segment 6: paddr=000443d4 vaddr=00000000 size=0bc44h ( 48196) [0m [0;32mI (664) esp_image: segment 7: paddr=00050020 vaddr=42000020 size=9d95ch (645468) map[0m [0;32mI (820) boot: Loaded app from partition at offset 0x10000[0m [0;32mI (821) boot: Disabling RNG early entropy source...[0m D (826) boot: Mapping segment 0 as DROM[0m [0;31mE (830) boot: Image contains multiple DROM segments. Only the last one will be mapped.[0m 向各位大佬求救~~ |
1个回答
ESP32-C3在执行bootloader时出现“Image contains multiple DROM segments. Only the last one will be mapped”的错误,意味着您的固件包含了多个DROM(Data ROM)段。这通常是由于以下原因导致的:
1. **多个静态库(.a文件)**:您提到在项目中加入了多个静态库文件。如果这些库中包含了DROM段,它们可能会在链接时导致多个DROM段的问题。确保所有库都正确地合并,并且没有重复的DROM段。 2. **链接脚本问题**:可能存在链接脚本配置错误,导致多个DROM段被生成。检查您的链接脚本,确保DROM段被正确地处理。 3. **固件大小超出限制**:ESP32-C3的ROM大小有限,如果固件大小超过了这个限制,可能会导致多个DROM段的问题。检查您的固件大小,确保它没有超出ESP32-C3的ROM容量。 4. **编译器/链接器设置**:检查您的编译器和链接器设置,确保它们正确地处理了DROM段。可能需要调整一些设置,以避免生成多个DROM段。 解决这个问题的方法可能包括: - **优化代码和库**:检查您的代码和库,看看是否有可能优化它们以减少DROM段的数量。 - **调整链接脚本**:修改链接脚本,以确保只有一个DROM段被生成。 - **减少固件大小**:如果可能,尝试减少固件的大小,以适应ESP32-C3的ROM限制。 - **更新工具链**:确保您使用的编译器和链接器是最新版本,以避免潜在的兼容性问题。 - **咨询社区或技术支持**:如果您无法解决问题,可以尝试咨询ESP32社区或寻求技术支持。 最后,`readelf`显示的输出信息可以帮助您进一步分析问题。例如,`.eh_frame`是一个用于异常处理的段,它可能不是导致问题的根本原因,但了解这些细节有助于您更全面地了解固件的结构。 |
只有小组成员才能发言,加入小组>>
944 浏览 0 评论
1671 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1330 浏览 1 评论
1233 浏览 1 评论
5015 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1250浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
927浏览 3评论
2330浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2526浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1051浏览 2评论
/9
GMT+8, 2025-12-1 22:18 , Processed in 0.689534 second(s), Total 70, Slave 53 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
346
