电子发烧友论坛|
芯片型号 ESP32C3 +SIM7600 PPP拨号 模块一直复位
Writing at 0x00000000... (100 %) Wrote 19824 bytes (12014 compressed) at 0x00000000 in 0.5 seconds (effective 300.6 kbit/s)... Hash of data verified. Compressed 617616 bytes to 333794... Writing at 0x00010000... (4 %) Writing at 0x0001c824... (9 %) Writing at 0x00026d71... (14 %) Writing at 0x0002e533... (19 %) Writing at 0x00035316... (23 %) Writing at 0x0003d694... (28 %) Writing at 0x0004529b... (33 %) Writing at 0x0004bfd9... (38 %) Writing at 0x00052f2d... (42 %) Writing at 0x00059cd6... (47 %) Writing at 0x00060aa7... (52 %) Writing at 0x000674dd... (57 %) Writing at 0x0006eaae... (61 %) Writing at 0x00074e48... (66 %) Writing at 0x0007b495... (71 %) Writing at 0x00082153... (76 %) Writing at 0x00088594... (80 %) Writing at 0x0008ec5a... (85 %) Writing at 0x00096f56... (90 %) Writing at 0x0009d371... (95 %) Writing at 0x000a42fc... (100 %) Wrote 617616 bytes (333794 compressed) at 0x00010000 in 9.7 seconds (effective 509.7 kbit/s)... Hash of data verified. Compressed 3072 bytes to 103... Writing at 0x00008000... (100 %) Wrote 3072 bytes (103 compressed) at 0x00008000 in 0.0 seconds (effective 547.2 kbit/s)... Hash of data verified. Leaving... Hard resetting via RTS pin... Executing action: monitor Running idf_monitor in directory c:1.ddisk3.esp32examplesprotocolspppos_client Executing "C:Espressifpython_envidf4.4_py3.8_envScriptspython.exe C:1.Ddisk3.ESP32tools/idf_monitor.py -p COM6 -b 115200 --toolchain-prefix riscv32-esp-elf- --target esp32c3 --decode-panic backtrace c:1.ddisk3.esp32examplesprotocolspppos_clientbuildpppos_client.elf -m 'C:Espressifpython_envidf4.4_py3.8_envScriptspython.exe' 'C:1.Ddisk3.ESP32toolsidf.py' '-p' 'COM6'"... --- WARNING: GDB cannot open serial ports accessed as COMx --- Using .COM6 instead... --- idf_monitor on .COM6 115200 --- --- Quit: Ctrl+] | Menu: Ctrl+T | Help: Ctrl+T followed by Ctrl+H --- ESP-ROM:esp32c3-api1-20210207 Build:Feb 7 2021 rst:0x1 (POWERON),boot:0xc (SPI_FAST_FLASH_BOOT) SPIWP:0xee mode:DIO, clock div:1 load:0x3fcd6100,len:0x16bc load:0x403ce000,len:0x930 load:0x403d0000,len:0x2d28 entry 0x403ce000 I (30) boot: ESP-IDF v4.4.1 2nd stage bootloader I (30) boot: compile time 15:59:55 I (30) boot: chip revision: 3 I (32) boot.esp32c3: SPI Speed : 80MHz I (37) boot.esp32c3: SPI Mode : DIO I (41) boot.esp32c3: SPI Flash Size : 4MB I (46) boot: Enabling RNG early entropy source... I (51) boot: Partition Table: I (55) boot: ## Label Usage Type ST Offset Length I (62) boot: 0 nvs WiFi data 01 02 00009000 00006000 I (70) boot: 1 phy_init RF data 01 01 0000f000 00001000 I (77) boot: 2 factory factory app 00 00 00010000 00100000 I (85) boot: End of partition table I (89) esp_image: segment 0: paddr=00010020 vaddr=3c080020 size=18300h ( 99072) map I (113) esp_image: segment 1: paddr=00028328 vaddr=3fc8be00 size=01694h ( 5780) load I (114) esp_image: segment 2: paddr=000299c4 vaddr=40380000 size=06654h ( 26196) load I (123) esp_image: segment 3: paddr=00030020 vaddr=42000020 size=71500h (464128) map I (200) esp_image: segment 4: paddr=000a1528 vaddr=40386654 size=05728h ( 22312) load I (204) esp_image: segment 5: paddr=000a6c58 vaddr=50000010 size=00010h ( 16) load I (209) boot: Loaded app from partition at offset 0x10000 I (211) boot: Disabling RNG early entropy source... I (228) cpu_start: Pro cpu up. I (237) cpu_start: Pro cpu start user code I (237) cpu_start: cpu freq: 160000000 I (237) cpu_start: Application information: I (240) cpu_start: Project name: pppos_client I (245) cpu_start: App version: v4.4.1 I (250) cpu_start: Compile time: Jun 14 2022 15:58:39 I (256) cpu_start: ELF file SHA256: 6d1019c7b7fa2f7c... I (262) cpu_start: ESP-IDF: v4.4.1 I (267) heap_init: Initializing. RAM available for dynamic allocation: I (274) heap_init: At 3FC8F3D0 len 00030C30 (195 KiB): DRAM I (280) heap_init: At 3FCC0000 len 0001F060 (124 KiB): STACK/DRAM I (287) heap_init: At 50000020 len 00001FE0 (7 KiB): RTCRAM I (294) spi_flash: detected chip: mxic I (298) spi_flash: flash io: dio I (302) sleep: Configure to isolate all GPIO pins in sleep state I (309) sleep: Enable automatic switching of GPIO sleep configuration I (316) cpu_start: Starting scheduler. I (320) uart: queue free spaces: 30 E (820) esp-modem: esp_modem_dte_send_cmd(256): process command timeout E (820) dce_service: esp_modem_dce_sync(225): send command failed E (820) bg96: bg96_init(167): sync failed Guru Meditation Error: Core 0 panic'ed (Store access fault). Exception was unhandled. Stack dump detected Core 0 register dump: MEPC : 0x42008b48 RA : 0x42008b3e SP : 0x3fc922c0 GP : 0x3fc8c600 0x42008b48: sim7600_init at c:1.ddisk3.esp32examplesprotocolspppos_clientbuild/../components/modem/src/sim7600.c:138 0x42008b3e: sim7600_init at c:1.ddisk3.esp32examplesprotocolspppos_clientbuild/../components/modem/src/sim7600.c:138 TP : 0x3fc7a3b8 T0 : 0x4005890e T1 : 0x10000000 T2 : 0xffffffff S0/FP : 0x3fc954d0 S1 : 0x00000000 A0 : 0x00000000 A1 : 0x3fc98b10 A2 : 0x00000000 A3 : 0x00000800 A4 : 0x00000000 A5 : 0x42008960 0x42008960: sim7600_get_battery_status at c:1.ddisk3.esp32examplesprotocolspppos_clientbuild/../components/modem/src/sim7600.c:97 A6 : 0x42002a8a A7 : 0x0000000a S2 : 0x3fc954d0 S3 : 0x3fc97488 0x42002a8a: console_write at C:/1.Ddisk/3.ESP32/components/vfs/vfs_console.c:71 S4 : 0x3fc98a40 S5 : 0x00000000 S6 : 0x00000000 S7 : 0x00000000 S8 : 0x00000000 S9 : 0x00000000 S10 : 0x00000000 S11 : 0x00000000 T3 : 0x00000000 T4 : 0x00000000 T5 : 0x00000000 T6 : 0x00000000 MSTATUS : 0x00001881 MTVEC : 0x40380001 MCAUSE : 0x00000007 MTVAL : 0x0000008c 0x40380001: _vector_table at ??:? MHARTID : 0x00000000 Failed to run gdb_panic_server.py script: Command '['riscv32-esp-elf-gdb', '--batch', '-n', 'c:1.ddisk3.esp32examplesprotocolspppos_clientuildpppos_client.elf', '-ex', 'target remote | "C:Espressifpython_envidf4.4_py3.8_envScriptspython.exe" "C:1.Ddisk3.ESP32 oolsidf_monitor_base..gdb_panic_server.py" --target esp32c3 "C:UsersCNDEWA~1AppDataLocalTemp mps1unsjx_"', '-ex', 'bt']' returned non-zero exit status 1. b'C:Espressif ools iscv32-esp-elfesp-2021r2-patch3-8.4.0 iscv32-esp-elfin iscv32-esp-elf-gdb.exe: warning: Couldn't determine a path for the index cache directory.rnerror starting child process '"C:Espressifpython_envidf4.4_py3.8_envScriptspython.exe" "C:1.Ddisk3.ESP32 oolsidf_monitor_base..gdb_panic_server.py" --target esp32c3 "C:UsersCNDEWA~1AppDataLocalTemp mps1unsjx_"': CreateProcess: No such file or directoryrnNo stack.rn' Core 0 register dump: MEPC : 0x42008b48 RA : 0x42008b3e SP : 0x3fc922c0 GP : 0x3fc8c600 TP : 0x3fc7a3b8 T0 : 0x4005890e T1 : 0x10000000 T2 : 0xffffffff S0/FP : 0x3fc954d0 S1 : 0x00000000 A0 : 0x00000000 A1 : 0x3fc98b10 A2 : 0x00000000 A3 : 0x00000800 A4 : 0x00000000 A5 : 0x42008960 A6 : 0x42002a8a A7 : 0x0000000a S2 : 0x3fc954d0 S3 : 0x3fc97488 S4 : 0x3fc98a40 S5 : 0x00000000 S6 : 0x00000000 S7 : 0x00000000 S8 : 0x00000000 S9 : 0x00000000 S10 : 0x00000000 S11 : 0x00000000 T3 : 0x00000000 T4 : 0x00000000 T5 : 0x00000000 T6 : 0x00000000 MSTATUS : 0x00001881 MTVEC : 0x40380001 MCAUSE : 0x00000007 MTVAL : 0x0000008c MHARTID : 0x00000000 Stack memory: 3fc922c0: 0x3fc954d0 0x00000000 0x00000000 0x42007410 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 3fc922e0: 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 3fc92300: 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 3fc92320: 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0x0000001f 0x42013f08 3fc92340: 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0x0000000c 0x00000000 0x0000000c 0x3fc8f3d0 0x0000000c 3fc92360: 0x00000000 0x0000000c 0x3fc8f3d0 0x4038a42a 0x00000000 0x00001800 0x3fc8fab0 0x4038091a 3fc92380: 0x00000804 0x0000000c 0x00000000 0x00000000 0x00001800 0x3c08907c 0x00000000 0x3fc8bf94 3fc923a0: 0x00000001 0x00000003 0x00000001 0x00000000 0x00000000 0x0001c200 0x00000002 0x00000003 3fc923c0: 0x0000001b 0x00000017 0x00000400 0x00000200 0x0000001e 0x00000c00 0x00000005 0x00000200 3fc923e0: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x420710f8 3fc92400: 0x00000000 0x00000000 0x00000000 0x40387a8a 0x00000000 0x00000000 0x00000000 0x00000000 3fc92420: 0x00000000 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0x27146414 0x01010107 0x00000001 0x000000ff 3fc92440: 0xffffffff 0x7fefffff 0x00000000 0x3fc00000 0x00000000 0x40300000 0x00000000 0x3fe00000 3fc92460: 0x00000000 0x3ff80000 0x636f4361 0x3fd287a7 0x8b60c8b3 0x3fc68a28 0x509f79fb 0x3fd34413 3fc92480: 0x00000000 0x3ff00000 0x00000000 0x40240000 0x00000000 0x401c0000 0x00000000 0x40140000 3fc924a0: 0x00000000 0x43500000 0x7fc00000 0x7f7fffff 0x00000000 0x40000000 0xffc00000 0x41dfffff 3fc924c0: 0x94a03595 0x3fdfffff 0x35afe535 0x3fe00000 0x94a03595 0x3fcfffff 0x00000000 0x7ff80000 3fc924e0: 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0x00000154 0x3fc921b0 0x00000032 0x3fc8dcec 3fc92500: 0x3fc8dcec 0x3fc924f4 0x3fc8dce4 0x00000018 0x3fc96664 0x3fc96664 0x3fc924f4 0x00000000 3fc92520: 0x00000001 0x3fc914f0 0x6e69616d 0xc2018700 0x99fff320 0x001ffcd6 0x00000000 0x3fc924e0 3fc92540: 0x00000001 0x00000000 0x3fc97734 0x4200021e 0x00000000 0x3fc8fd7c 0x3fc8fde4 0x3fc8fe4c 3fc92560: 0x00000000 0x00000000 0x00000001 0x00000000 0x00000000 0x00000000 0x4205dd26 0x00000000 3fc92580: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 3fc925a0: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 3fc925c0: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 3fc925e0: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 3fc92600: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 3fc92620: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 3fc92640: 0x00000000 0x3f000000 0x00000154 0x3fc92c30 0x3fc8f3e4 0x3fc8dcd8 0x3fc8dcd8 0x3fc9264c 3fc92660: 0x3fc8dcd0 0x00000019 0x1b6503b5 0x8f4cd457 0x3fc9264c 0x00000000 0x00000000 0x3fc927a4 3fc92680: 0x454c4449 0xba80d700 0x0121b251 0x009890b5 0x00000000 0x3fc92da0 0x00000000 0x00000000 3fc926a0: 0x00000000 0x00000000 0x00000000 0x3fc8fd7c 0x3fc8fde4 0x3fc8fe4c 0x00000000 0x00000000 ELF file SHA256: 6d1019c7b7fa2f7c ELF file SHA256: 6d1019c7b7fa2f7c Rebooting... ESP-ROM:esp32c3-api1-20210207 Build:Feb 7 2021 rst:0x3 (RTC_SW_SYS_RST),boot:0xc (SPI_FAST_FLASH_BOOT) Saved PC:0x40380596 0x40380596: esp_restart_noos_dig at C:/1.Ddisk/3.ESP32/components/esp_system/esp_system.c:44 (discriminator 1) SPIWP:0xee mode:DIO, clock div:1 load:0x3fcd6100,len:0x16bc load:0x403ce000,len:0x930 load:0x403d0000,len:0x2d28 entry 0x403ce000 I (35) boot: ESP-IDF v4.4.1 2nd stage bootloader I (35) boot: compile time 15:59:55 I (35) boot: chip revision: 3 I (37) boot.esp32c3: SPI Speed : 80MHz I (42) boot.esp32c3: SPI Mode : DIO I (46) boot.esp32c3: SPI Flash Size : 4MB I (51) boot: Enabling RNG early entropy source... I (56) boot: Partition Table: I (60) boot: ## Label Usage Type ST Offset Length I (67) boot: 0 nvs WiFi data 01 02 00009000 00006000 I (75) boot: 1 phy_init RF data 01 01 0000f000 00001000 I (82) boot: 2 factory factory app 00 00 00010000 00100000 I (90) boot: End of partition table I (94) esp_image: segment 0: paddr=00010020 vaddr=3c080020 size=18300h ( 99072) map I (118) esp_image: segment 1: paddr=00028328 vaddr=3fc8be00 size=01694h ( 5780) load I (119) esp_image: segment 2: paddr=000299c4 vaddr=40380000 size=06654h ( 26196) load I (128) esp_image: segment 3: paddr=00030020 vaddr=42000020 size=71500h (464128) map I (204) esp_image: segment 4: paddr=000a1528 vaddr=40386654 size=05728h ( 22312) load I (209) esp_image: segment 5: paddr=000a6c58 vaddr=50000010 size=00010h ( 16) load I (214) boot: Loaded app from partition at offset 0x10000 I (216) boot: Disabling RNG early entropy source... I (233) cpu_start: Pro cpu up. I (242) cpu_start: Pro cpu start user code I (242) cpu_start: cpu freq: 160000000 I (242) cpu_start: Application information: I (244) cpu_start: Project name: pppos_client I (250) cpu_start: App version: v4.4.1 I (255) cpu_start: Compile time: Jun 14 2022 15:58:39 I (261) cpu_start: ELF file SHA256: 6d1019c7b7fa2f7c... I (267) cpu_start: ESP-IDF: v4.4.1 I (272) heap_init: Initializing. RAM available for dynamic allocation: I (279) heap_init: At 3FC8F3D0 len 00030C30 (195 KiB): DRAM I (285) heap_init: At 3FCC0000 len 0001F060 (124 KiB): STACK/DRAM I (292) heap_init: At 50000020 len 00001FE0 (7 KiB): RTCRAM I (299) spi_flash: detected chip: mxic I (303) spi_flash: flash io: dio I (307) sleep: Configure to isolate all GPIO pins in sleep state I (313) sleep: Enable automatic switching of GPIO sleep configuration I (321) cpu_start: Starting scheduler. I (325) uart: queue free spaces: 30 E (825) esp-modem: esp_modem_dte_send_cmd(256): process command timeout E (825) dce_service: esp_modem_dce_sync(225): send command failed E (825) bg96: bg96_init(167): sync failed Guru Meditation Error: Core 0 panic'ed (Store access fault). Exception was unhandled. Stack dump detected Core 0 register dump: MEPC : 0x42008b48 RA : 0x42008b3e SP : 0x3fc922c0 GP : 0x3fc8c600 0x42008b48: sim7600_init at c:1.ddisk3.esp32examplesprotocolspppos_clientbuild/../components/modem/src/sim7600.c:138 0x42008b3e: sim7600_init at c:1.ddisk3.esp32examplesprotocolspppos_clientbuild/../components/modem/src/sim7600.c:138 TP : 0x3fc7a3b8 T0 : 0x4005890e T1 : 0x10000000 T2 : 0xffffffff S0/FP : 0x3fc954d0 S1 : 0x00000000 A0 : 0x00000000 A1 : 0x3fc98b10 A2 : 0x00000000 A3 : 0x00000800 A4 : 0x00000000 A5 : 0x42008960 0x42008960: sim7600_get_battery_status at c:1.ddisk3.esp32examplesprotocolspppos_clientbuild/../components/modem/src/sim7600.c:97 A6 : 0x42002a8a A7 : 0x0000000a S2 : 0x3fc954d0 S3 : 0x3fc97488 0x42002a8a: console_write at C:/1.Ddisk/3.ESP32/components/vfs/vfs_console.c:71 S4 : 0x3fc98a40 S5 : 0x00000000 S6 : 0x00000000 S7 : 0x00000000 S8 : 0x00000000 S9 : 0x00000000 S10 : 0x00000000 S11 : 0x00000000 T3 : 0x00000000 T4 : 0x00000000 T5 : 0x00000000 T6 : 0x00000000 MSTATUS : 0x00001881 MTVEC : 0x40380001 MCAUSE : 0x00000007 MTVAL : 0x0000008c 0x40380001: _vector_table at ??:? MHARTID : 0x00000000 Failed to run gdb_panic_server.py script: Command '['riscv32-esp-elf-gdb', '--batch', '-n', 'c:1.ddisk3.esp32examplesprotocolspppos_clientuildpppos_client.elf', '-ex', 'target remote | "C:Espressifpython_envidf4.4_py3.8_envScriptspython.exe" "C:1.Ddisk3.ESP32 oolsidf_monitor_base..gdb_panic_server.py" --target esp32c3 "C:UsersCNDEWA~1AppDataLocalTemp mpwv37ptjz"', '-ex', 'bt']' returned non-zero exit status 1. b'C:Espressif ools iscv32-esp-elfesp-2021r2-patch3-8.4.0 iscv32-esp-elfin iscv32-esp-elf-gdb.exe: warning: Couldn't determine a path for the index cache directory.rnerror starting child process '"C:Espressifpython_envidf4.4_py3.8_envScriptspython.exe" "C:1.Ddisk3.ESP32 oolsidf_monitor_base..gdb_panic_server.py" --target esp32c3 "C:UsersCNDEWA~1AppDataLocalTemp mpwv37ptjz"': CreateProcess: No such file or directoryrnNo stack.rn' Core 0 register dump: MEPC : 0x42008b48 RA : 0x42008b3e SP : 0x3fc922c0 GP : 0x3fc8c600 TP : 0x3fc7a3b8 T0 : 0x4005890e T1 : 0x10000000 T2 : 0xffffffff S0/FP : 0x3fc954d0 S1 : 0x00000000 A0 : 0x00000000 A1 : 0x3fc98b10 A2 : 0x00000000 A3 : 0x00000800 A4 : 0x00000000 A5 : 0x42008960 A6 : 0x42002a8a A7 : 0x0000000a S2 : 0x3fc954d0 S3 : 0x3fc97488 S4 : 0x3fc98a40 S5 : 0x00000000 S6 : 0x00000000 S7 : 0x00000000 S8 : 0x00000000 S9 : 0x00000000 S10 : 0x00000000 S11 : 0x00000000 T3 : 0x00000000 T4 : 0x00000000 T5 : 0x00000000 T6 : 0x00000000 MSTATUS : 0x00001881 MTVEC : 0x40380001 MCAUSE : 0x00000007 MTVAL : 0x0000008c MHARTID : 0x00000000 Stack memory: 3fc922c0: 0x3fc954d0 0x00000000 0x00000000 0x42007410 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 3fc922e0: 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 3fc92300: 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 3fc92320: 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0x0000001f 0x42013f08 3fc92340: 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0x0000000c 0x00000000 0x0000000c 0x3fc8f3d0 0x0000000c 3fc92360: 0x00000000 0x0000000c 0x3fc8f3d0 0x4038a42a 0x00000000 0x00001800 0x3fc8fab0 0x4038091a 3fc92380: 0x00000804 0x0000000c 0x00000000 0x00000000 0x00001800 0x3c08907c 0x00000000 0x3fc8bf94 3fc923a0: 0x00000001 0x00000003 0x00000001 0x00000000 0x00000000 0x0001c200 0x00000002 0x00000003 3fc923c0: 0x0000001b 0x00000017 0x00000400 0x00000200 0x0000001e 0x00000c00 0x00000005 0x00000200 3fc923e0: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x420710f8 3fc92400: 0x00000000 0x00000000 0x00000000 0x40387a8a 0x00000000 0x00000000 0x00000000 0x00000000 3fc92420: 0x00000000 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0x27146414 0x01010107 0x00000001 0x000000ff 3fc92440: 0xffffffff 0x7fefffff 0x00000000 0x3fc00000 0x00000000 0x40300000 0x00000000 0x3fe00000 3fc92460: 0x00000000 0x3ff80000 0x636f4361 0x3fd287a7 0x8b60c8b3 0x3fc68a28 0x509f79fb 0x3fd34413 3fc92480: 0x00000000 0x3ff00000 0x00000000 0x40240000 0x00000000 0x401c0000 0x00000000 0x40140000 3fc924a0: 0x00000000 0x43500000 0x7fc00000 0x7f7fffff 0x00000000 0x40000000 0xffc00000 0x41dfffff 3fc924c0: 0x94a03595 0x3fdfffff 0x35afe535 0x3fe00000 0x94a03595 0x3fcfffff 0x00000000 0x7ff80000 3fc924e0: 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0x00000154 0x3fc921b0 0x00000032 0x3fc8dcec 3fc92500: 0x3fc8dcec 0x3fc924f4 0x3fc8dce4 0x00000018 0x3fc96664 0x3fc96664 0x3fc924f4 0x00000000 3fc92520: 0x00000001 0x3fc914f0 0x6e69616d 0xc2018700 0x99fff320 0x001ffcd6 0x00000000 0x3fc924e0 3fc92540: 0x00000001 0x00000000 0x3fc97734 0x4200021e 0x00000000 0x3fc8fd7c 0x3fc8fde4 0x3fc8fe4c 3fc92560: 0x00000000 0x00000000 0x00000001 0x00000000 0x00000000 0x00000000 0x4205dd26 0x00000000 3fc92580: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 3fc925a0: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 3fc925c0: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 3fc925e0: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 3fc92600: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 3fc92620: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 3fc92640: 0x00000000 0x3f000000 0x00000154 0x3fc92c30 0x3fc8f3e4 0x3fc8dcd8 0x3fc8dcd8 0x3fc9264c 3fc92660: 0x3fc8dcd0 0x00000019 0x1b6503b5 0x8f4cd457 0x3fc9264c 0x00000000 0x00000000 0x3fc927a4 3fc92680: 0x454c4449 0xba80d700 0x0121b251 0x009890b5 0x00000000 0x3fc92da0 0x00000000 0x00000000 3fc926a0: 0x00000000 0x00000000 0x00000000 0x3fc8fd7c 0x3fc8fde4 0x3fc8fe4c 0x00000000 0x00000000 ELF file SHA256: 6d1019c7b7fa2f7c ELF file SHA256: 6d1019c7b7fa2f7c Rebooting... ESP-ROM:esp32c3-api1-20210207 Build:Feb 7 2021 rst:0x3 (RTC_SW_SYS_RST),boot:0xc (SPI_FAST_FLASH_BOOT) Saved PC:0x40380596 0x40380596: esp_restart_noos_dig at C:/1.Ddisk/3.ESP32/components/esp_system/esp_system.c:44 (discriminator 1) SPIWP:0xee mode:DIO, clock div:1 load:0x3fcd6100,len:0x16bc load:0x403ce000,len:0x930 load:0x403d0000,len:0x2d28 entry 0x403ce000 I (35) boot: ESP-IDF v4.4.1 2nd stage bootloader I (35) boot: compile time 15:59:55 I (35) boot: chip revision: 3 I (37) boot.esp32c3: SPI Speed : 80MHz I (42) boot.esp32c3: SPI Mode : DIO I (46) boot.esp32c3: SPI Flash Size : 4MB I (51) boot: Enabling RNG early entropy source... I (56) boot: Partition Table: I (60) boot: ## Label Usage Type ST Offset Length I (67) boot: 0 nvs WiFi data 01 02 00009000 00006000 I (75) boot: 1 phy_init RF data 01 01 0000f000 00001000 I (82) boot: 2 factory factory app 00 00 00010000 00100000 I (90) boot: End of partition table I (94) esp_image: segment 0: paddr=00010020 vaddr=3c080020 size=18300h ( 99072) map I (118) esp_image: segment 1: paddr=00028328 vaddr=3fc8be00 size=01694h ( 5780) load I (119) esp_image: segment 2: paddr=000299c4 vaddr=40380000 size=06654h ( 26196) load I (128) esp_image: segment 3: paddr=00030020 vaddr=42000020 size=71500h (464128) map I (204) esp_image: segment 4: paddr=000a1528 vaddr=40386654 size=05728h ( 22312) load I (209) esp_image: segment 5: paddr=000a6c58 vaddr=50000010 size=00010h ( 16) load I (214) boot: Loaded app from partition at offset 0x10000 I (216) boot: Disabling RNG early entropy source... I (233) cpu_start: Pro cpu up. I (242) cpu_start: Pro cpu start user code I (242) cpu_start: cpu freq: 160000000 I (242) cpu_start: Application information: I (244) cpu_start: Project name: pppos_client I (250) cpu_start: App version: v4.4.1 I (255) cpu_start: Compile time: Jun 14 2022 15:58:39 I (261) cpu_start: ELF file SHA256: 6d1019c7b7fa2f7c... I (267) cpu_start: ESP-IDF: v4.4.1 I (272) heap_init: Initializing. RAM available for dynamic allocation: I (279) heap_init: At 3FC8F3D0 len 00030C30 (195 KiB): DRAM I (285) heap_init: At 3FCC0000 len 0001F060 (124 KiB): STACK/DRAM I (292) heap_init: At 50000020 len 00001FE0 (7 KiB): RTCRAM I (299) spi_flash: detected chip: mxic I (303) spi_flash: flash io: dio I (307) sleep: Configure to isolate all GPIO pins in sleep state I (313) sleep: Enable automatic switching of GPIO sleep configuration I (321) cpu_start: Starting scheduler. I (325) uart: queue free spaces: 30 E (825) esp-modem: esp_modem_dte_send_cmd(256): process command timeout E (825) dce_service: esp_modem_dce_sync(225): send command failed E (825) bg96: bg96_init(167): sync failed Guru Meditation Error: Core 0 panic'ed (Store access fault). Exception was unhandled. Stack dump detected Core 0 register dump: MEPC : 0x42008b48 RA : 0x42008b3e SP : 0x3fc922c0 GP : 0x3fc8c600 0x42008b48: sim7600_init at c:1.ddisk3.esp32examplesprotocolspppos_clientbuild/../components/modem/src/sim7600.c:138 0x42008b3e: sim7600_init at c:1.ddisk3.esp32examplesprotocolspppos_clientbuild/../components/modem/src/sim7600.c:138 TP : 0x3fc7a3b8 T0 : 0x4005890e T1 : 0x10000000 T2 : 0xffffffff S0/FP : 0x3fc954d0 S1 : 0x00000000 A0 : 0x00000000 A1 : 0x3fc98b10 A2 : 0x00000000 A3 : 0x00000800 A4 : 0x00000000 A5 : 0x42008960 0x42008960: sim7600_get_battery_status at c:1.ddisk3.esp32examplesprotocolspppos_clientbuild/../components/modem/src/sim7600.c:97 A6 : 0x42002a8a A7 : 0x0000000a S2 : 0x3fc954d0 S3 : 0x3fc97488 0x42002a8a: console_write at C:/1.Ddisk/3.ESP32/components/vfs/vfs_console.c:71 S4 : 0x3fc98a40 S5 : 0x00000000 S6 : 0x00000000 S7 : 0x00000000 S8 : 0x00000000 S9 : 0x00000000 S10 : 0x00000000 S11 : 0x00000000 T3 : 0x00000000 T4 : 0x00000000 T5 : 0x00000000 T6 : 0x00000000 MSTATUS : 0x00001881 MTVEC : 0x40380001 MCAUSE : 0x00000007 MTVAL : 0x0000008c 0x40380001: _vector_table at ??:? MHARTID : 0x00000000 Failed to run gdb_panic_server.py script: Command '['riscv32-esp-elf-gdb', '--batch', '-n', 'c:1.ddisk3.esp32examplesprotocolspppos_clientuildpppos_client.elf', '-ex', 'target remote | "C:Espressifpython_envidf4.4_py3.8_envScriptspython.exe" "C:1.Ddisk3.ESP32 oolsidf_monitor_base..gdb_panic_server.py" --target esp32c3 "C:UsersCNDEWA~1AppDataLocalTemp mpruksus6e"', '-ex', 'bt']' returned non-zero exit status 1. b'C:Espressif ools iscv32-esp-elfesp-2021r2-patch3-8.4.0 iscv32-esp-elfin iscv32-esp-elf-gdb.exe: warning: Couldn't determine a path for the index cache directory.rnerror starting child process '"C:Espressifpython_envidf4.4_py3.8_envScriptspython.exe" "C:1.Ddisk3.ESP32 oolsidf_monitor_base..gdb_panic_server.py" --target esp32c3 "C:UsersCNDEWA~1AppDataLocalTemp mpruksus6e"': CreateProcess: No such file or directoryrnNo stack.rn' Core 0 register dump: MEPC : 0x42008b48 RA : 0x42008b3e SP : 0x3fc922c0 GP : 0x3fc8c600 TP : 0x3fc7a3b8 T0 : 0x4005890e T1 : 0x10000000 T2 : 0xffffffff S0/FP : 0x3fc954d0 S1 : 0x00000000 A0 : 0x00000000 A1 : 0x3fc98b10 A2 : 0x00000000 A3 : 0x00000800 A4 : 0x00000000 A5 : 0x42008960 A6 : 0x42002a8a A7 : 0x0000000a S2 : 0x3fc954d0 S3 : 0x3fc97488 S4 : 0x3fc98a40 S5 : 0x00000000 S6 : 0x00000000 S7 : 0x00000000 S8 : 0x00000000 S9 : 0x00000000 S10 : 0x00000000 S11 : 0x00000000 T3 : 0x00000000 T4 : 0x00000000 T5 : 0x00000000 T6 : 0x00000000 MSTATUS : 0x00001881 MTVEC : 0x40380001 MCAUSE : 0x00000007 MTVAL : 0x0000008c MHARTID : 0x00000000 Stack memory: 3fc922c0: 0x3fc954d0 0x00000000 0x00000000 0x42007410 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 3fc922e0: 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 3fc92300: 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 3fc92320: 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0x0000001f 0x42013f08 3fc92340: 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0x0000000c 0x00000000 0x0000000c 0x3fc8f3d0 0x0000000c 3fc92360: 0x00000000 0x0000000c 0x3fc8f3d0 0x4038a42a 0x00000000 0x00001800 0x3fc8fab0 0x4038091a 3fc92380: 0x00000804 0x0000000c 0x00000000 0x00000000 0x00001800 0x3c08907c 0x00000000 0x3fc8bf94 3fc923a0: 0x00000001 0x00000003 0x00000001 0x00000000 0x00000000 0x0001c200 0x00000002 0x00000003 3fc923c0: 0x0000001b 0x00000017 0x00000400 0x00000200 0x0000001e 0x00000c00 0x00000005 0x00000200 3fc923e0: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x420710f8 3fc92400: 0x00000000 0x00000000 0x00000000 0x40387a8a 0x00000000 0x00000000 0x00000000 0x00000000 3fc92420: 0x00000000 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0x27146414 0x01010107 0x00000001 0x000000ff 3fc92440: 0xffffffff 0x7fefffff 0x00000000 0x3fc00000 0x00000000 0x40300000 0x00000000 0x3fe00000 3fc92460: 0x00000000 0x3ff80000 0x636f4361 0x3fd287a7 0x8b60c8b3 0x3fc68a28 0x509f79fb 0x3fd34413 3fc92480: 0x00000000 0x3ff00000 0x00000000 0x40240000 0x00000000 0x401c0000 0x00000000 0x40140000 3fc924a0: 0x00000000 0x43500000 0x7fc00000 0x7f7fffff 0x00000000 0x40000000 0xffc00000 0x41dfffff 3fc924c0: 0x94a03595 0x3fdfffff 0x35afe535 0x3fe00000 0x94a03595 0x3fcfffff 0x00000000 0x7ff80000 3fc924e0: 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0x00000154 0x3fc921b0 0x00000032 0x3fc8dcec 3fc92500: 0x3fc8dcec 0x3fc924f4 0x3fc8dce4 0x00000018 0x3fc96664 0x3fc96664 0x3fc924f4 0x00000000 3fc92520: 0x00000001 0x3fc914f0 0x6e69616d 0xc2018700 0x99fff320 0x001ffcd6 0x00000000 0x3fc924e0 3fc92540: 0x00000001 0x00000000 0x3fc97734 0x4200021e 0x00000000 0x3fc8fd7c 0x3fc8fde4 0x3fc8fe4c 3fc92560: 0x00000000 0x00000000 0x00000001 0x00000000 0x00000000 0x00000000 0x4205dd26 0x00000000 3fc92580: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 3fc925a0: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 3fc925c0: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 3fc925e0: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 3fc92600: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 3fc92620: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 3fc92640: 0x00000000 0x3f000000 0x00000154 0x3fc92c30 0x3fc8f3e4 0x3fc8dcd8 0x3fc8dcd8 0x3fc9264c 3fc92660: 0x3fc8dcd0 0x00000019 0x1b6503b5 0x8f4cd457 0x3fc9264c 0x00000000 0x00000000 0x3fc927a4 3fc92680: 0x454c4449 0xba80d700 0x0121b251 0x009890b5 0x00000000 0x3fc92da0 0x00000000 0x00000000 3fc926a0: 0x00000000 0x00000000 0x00000000 0x3fc8fd7c 0x3fc8fde4 0x3fc8fe4c 0x00000000 0x00000000 ELF file SHA256: 6d1019c7b7fa2f7c ELF file SHA256: 6d1019c7b7fa2f7c Rebooting... ESP-ROM:esp32c3-api1-20210207 Build:Feb 7 2021 rst:0x3 (RTC_SW_SYS_RST),boot:0xc (SPI_FAST_FLASH_BOOT) Saved PC:0x40380596 0x40380596: esp_restart_noos_dig at C:/1.Ddisk/3.ESP32/components/esp_system/esp_system.c:44 (discriminator 1) SPIWP:0xee mode:DIO, clock div:1 load:0x3fcd6100,len:0x16bc load:0x403ce000,len:0x930 load:0x403d0000,len:0x2d28 entry 0x403ce000 I (35) boot: ESP-IDF v4.4.1 2nd stage bootloader |
1个回答
但是,您遇到了模块一直复位的问题。为了解决这个问题,请按照以下步骤操作:
1. 确保硬件连接正确:检查ESP32C3和SIM7600模块之间的连接是否正确,包括电源、TX、RX等线路。 2. 检查电源供应:确保模块的电源供应稳定,电压在规定的范围内。 3. 检查固件烧录设置:在烧录固件时,请确保选择了正确的烧录设置,如烧录速度、波特率等。 4. 检查固件文件:确保您使用的固件文件是适用于ESP32C3和SIM7600模块的正确版本。 5. 检查烧录过程中的中断:在烧录过程中,确保没有其他程序或设备干扰烧录过程。 6. 检查模块硬件:如果以上步骤都无法解决问题,可能是模块硬件存在问题。您可以尝试更换模块或联系模块供应商寻求技术支持。 7. 检查代码:如果模块一直复位,可能是代码中存在问题。检查代码逻辑,确保没有死循环或其他导致模块复位的错误。 8. 使用串口助手:在烧录过程中,使用串口助手观察模块的输出信息,以便更好地了解问题所在。 |
只有小组成员才能发言,加入小组>>
442 浏览 0 评论
967 浏览 0 评论
1694 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1349 浏览 1 评论
1246 浏览 1 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1270浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
936浏览 3评论
2368浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2555浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1063浏览 2评论
/9
GMT+8, 2025-12-8 08:52 , Processed in 0.877589 second(s), Total 77, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
640
