电子发烧友论坛|
报以下错误,我是个新手,哪位大神帮看看,谢谢啊
myproject zebra$ idf.py -p /dev/cu.usbserial-1420 flash Executing action: flash Running ninja in directory /Users/zebra/workspace/esp/myproject/build Executing "ninja flash"... [1/5] cd /Users/zebra/workspace/esp/myproject/build/esp-idf/esptool_py && /Users/zebra/.espressif/python_env/idf5.1_py3.10_env/bin/python /Users/zebra/workspace/esp/esp-idf/components/partition_table/check_sizes.py --offset 0x8000 partition --type app /Users/zebra/workspace/esp/myproject/build/partition_table/partition-table.bin /Users/zebra/workspace/esp/myproject/build/myproject.bin myproject.bin binary size 0x2a110 bytes. Smallest app partition is 0x100000 bytes. 0xd5ef0 bytes (84%) free. [2/5] Performing build step for 'bootloader' [1/1] cd /Users/zebra/workspace/esp/myproject/build/bootloader/esp-idf/esptool_py && /Users/zebra/.espressif/python_env/idf5.1_py3.10_env/bin/python /Users/zebra/workspace/esp/esp-idf/components/partition_table/check_sizes.py --offset 0x8000 bootloader 0x1000 /Users/zebra/workspace/esp/myproject/build/bootloader/bootloader.bin Bootloader binary size 0x6730 bytes. 0x8d0 bytes (8%) free. [2/3] cd /Users/zebra/workspace/esp/esp-idf/components/esptool_py && /usr/local/Cellar/cmake/3.24.2/bin/cmake -D IDF_PATH=/Users/zebra/workspace/esp/esp-idf -D "SERIAL_TOOL=/Users/zebra/.espressif/python_env/idf5.1_py3.10_env/bin/python;;/Users/zebra/workspace/esp/esp-idf/components/esptool_py/esptool/esptool.py;--chip;esp32" -D "SERIAL_TOOL_ARGS=--before=default_reset;--after=hard_reset;write_flash;@flash_args" -D WORKING_DIRECTORY=/Users/zebra/workspace/esp/myproject/build -P /Users/zebra/workspace/esp/esp-idf/components/esptool_py/run_serial_tool.cmake esptool esp32 -p /dev/cu.usbserial-1420 -b 460800 --before=default_reset --after=hard_reset write_flash --flash_mode dio --flash_freq 40m --flash_size 2MB 0x1000 bootloader/bootloader.bin 0x10000 myproject.bin 0x8000 partition_table/partition-table.bin esptool.py v4.5 Serial port /dev/cu.usbserial-1420 A fatal error occurred: Could not open /dev/cu.usbserial-1420, the port doesn't exist CMake Error at run_serial_tool.cmake:63 (message): /Users/zebra/.espressif/python_env/idf5.1_py3.10_env/bin/python;;/Users/zebra/workspace/esp/esp-idf/components/esptool_py/esptool/esptool.py;--chip;esp32 failed. FAILED: CMakeFiles/flash /Users/zebra/workspace/esp/myproject/build/CMakeFiles/flash cd /Users/zebra/workspace/esp/esp-idf/components/esptool_py && /usr/local/Cellar/cmake/3.24.2/bin/cmake -D IDF_PATH=/Users/zebra/workspace/esp/esp-idf -D "SERIAL_TOOL=/Users/zebra/.espressif/python_env/idf5.1_py3.10_env/bin/python;;/Users/zebra/workspace/esp/esp-idf/components/esptool_py/esptool/esptool.py;--chip;esp32" -D "SERIAL_TOOL_ARGS=--before=default_reset;--after=hard_reset;write_flash;@flash_args" -D WORKING_DIRECTORY=/Users/zebra/workspace/esp/myproject/build -P /Users/zebra/workspace/esp/esp-idf/components/esptool_py/run_serial_tool.cmake ninja: build stopped: subcommand failed. ninja failed with exit code 1, output of the command is in the /Users/zebra/workspace/esp/myproject/build/log/idf_py_stderr_output_43039 and /Users/zebra/workspace/esp/myproject/build/log/idf_py_stdout_output_43039 |
1个回答
从您提供的错误信息来看,这个问题可能是由于以下几个原因导致的:
1. 确保您已经正确连接了ESP32-C6开发板到计算机,并且选择了正确的串口设备(-p参数)。 2. 检查您的开发板是否有足够的电源供应。如果电源不稳定或不足,可能导致烧录失败。 3. 确保您已经安装了正确版本的Espressif IoT Development Framework(ESP-IDF)。您可以通过以下命令检查当前安装的版本: ``` idf.py --version ``` 如果版本不是最新的,您可以使用以下命令更新: ``` python -m pip install --upgrade espidf ``` 4. 确保您的Python环境是3.7至3.9之间的版本。ESP-IDF 5.1支持Python 3.7至3.9,如果您的Python版本不符合要求,您可能需要创建一个新的Python虚拟环境并安装相应版本的Python。 5. 检查您的开发板是否已经进入烧录模式。通常,您需要按住BOOT按钮,然后给开发板供电或按下RESET按钮。这样,开发板就会进入烧录模式。 6. 如果以上方法都无法解决问题,您可以尝试重新烧录固件。首先,使用以下命令清除构建: ``` idf.py fullclean ``` 然后,再次尝试烧录: ``` idf.py -p /dev/cu.usbserial-1420 flash ``` 希望这些建议能帮助您解决问题。如果问题仍然存在,请提供更多详细信息,以便我们能更好地帮助您。 |
只有小组成员才能发言,加入小组>>
471 浏览 0 评论
994 浏览 0 评论
1710 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1370 浏览 1 评论
1256 浏览 1 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1288浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
943浏览 3评论
2386浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2575浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1071浏览 2评论
/9
GMT+8, 2025-12-14 07:52 , Processed in 0.832788 second(s), Total 77, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
871
