ESP32S3R8芯片+GD25Q32CSIG(4M flash) wifi天线用IPEX外置天线!用例程的scan可以扫描到附近的WIFI。用例程softap搜不到创建的wifi,没有打印错误信息。用例程station也连接不上路由器,初始化都没有错误,但是就是连不上。
station 打印信息如下 Executing action: monitor Running idf_monitor in directory d:esp-idfespressifframeworksesp-idf-v4.4workspacestation Executing "D:esp-idfEspressifpython_envidf4.4_py3.8_envScriptspython.exe D:/esp-idf/Espressif/frameworks/esp-idf-v4.4/tools/idf_monitor.py -p \.COM17 -b 115200 --toolchain-prefix xtensa-esp32s3-elf- --target esp32s3 --print_filter d:esp-idfespressifframeworksesp-idf-v4.4workspacestationbuildstation.elf -m 'D:esp-idfEspressifpython_envidf4.4_py3.8_envScriptspython.exe' 'D:esp-idfEspressifframeworksesp-idf-v4.4toolsidf.py'"... ?[0;33m--- idf_monitor on \.COM17 115200 ---?[0m --- Quit: Ctrl+] | Menu: Ctrl+T | Help: Ctrl+T followed by Ctrl+H --- ESP-ROM:esp32s3-20210327 Build:Mar 27 2021 rst:0x1 (POWERON),boot:0x8 (SPI_FAST_FLASH_BOOT) SPIWP:0xee mode:DIO, clock div:1 load:0x3fcd0108,len:0x1658 load:0x403b6000,len:0xb7c load:0x403ba000,len:0x2f58 entry 0x403b6248 I (24) boot: ESP-IDF v4.4-dirty 2nd stage bootloader I (25) boot: compile time 09:19:38 I (25) boot: chip revision: 0 I (27) boot.esp32s3: Boot SPI Speed : 80MHz I (31) boot.esp32s3: SPI Mode : DIO I (36) boot.esp32s3: SPI Flash Size : 4MB I (41) boot: Enabling RNG early entropy source... I (46) boot: Partition Table: I (50) boot: ## Label Usage Type ST Offset Length I (57) boot: 0 nvs WiFi data 01 02 00009000 00006000 I (65) boot: 1 phy_init RF data 01 01 0000f000 00001000 I (72) boot: 2 factory factory app 00 00 00010000 00100000 I (80) boot: End of partition table I (84) esp_image: segment 0: paddr=00010020 vaddr=3c070020 size=1342ch ( 78892) map I (106) esp_image: segment 1: paddr=00023454 vaddr=3fc951d0 size=04434h ( 17460) load I (110) esp_image: segment 2: paddr=00027890 vaddr=40374000 size=08788h ( 34696) load I (120) esp_image: segment 3: paddr=00030020 vaddr=42000020 size=68cf8h (429304) map I (198) esp_image: segment 4: paddr=00098d20 vaddr=4037c788 size=08a48h ( 35400) load I (206) esp_image: segment 5: paddr=000a1770 vaddr=50000000 size=00010h ( 16) load I (213) boot: Loaded app from partition at offset 0x10000 I (213) boot: Disabling RNG early entropy source... I (226) opi psram: vendor id : 0x0d (AP) I (226) opi psram: dev id : 0x02 (generation 3) I (227) opi psram: density : 0x03 (64 Mbit) I (230) opi psram: good-die : 0x01 (Pass) I (235) opi psram: Latency : 0x01 (Fixed) I (240) opi psram: VCC : 0x01 (3V) I (244) opi psram: SRF : 0x01 (Fast Refresh) I (250) opi psram: BurstType : 0x01 (Hybrid Wrap) I (255) opi psram: BurstLen : 0x01 (32 Byte) I (260) opi psram: Readlatency : 0x02 (10 cycles@Fixed) I (266) opi psram: DriveStrength: 0x00 (1/1) W (271) PSRAM: DO NOT USE FOR MASS PRODUCTION! Timing parameters will be updated in future IDF version. I (282) spiram: Found 64MBit SPI RAM device I (286) spiram: SPI RAM mode: sram 80m I (291) spiram: PSRAM initialized, cache is in normal (1-core) mode. I (298) cpu_start: Pro cpu up. I (301) cpu_start: Starting app cpu, entry point is 0x403752fc 0x403752fc: call_start_cpu1 at D:/esp-idf/Espressif/frameworks/esp-idf-v4.4/components/esp_system/port/cpu_start.c:156 I (0) cpu_start: App cpu up. I (728) spiram: SPI SRAM memory test OK I (736) cpu_start: Pro cpu start user code I (736) cpu_start: cpu freq: 160000000 I (736) cpu_start: Application information: I (739) cpu_start: Project name: station I (744) cpu_start: App version: v4.4-dirty I (749) cpu_start: Compile time: Oct 9 2022 09:17:54 I (755) cpu_start: ELF file SHA256: 3c268daeb45334e3... I (761) cpu_start: ESP-IDF: v4.4-dirty I (766) heap_init: Initializing. RAM available for dynamic allocation: I (774) heap_init: At 3FC9D098 len 00042F68 (267 KiB): D/IRAM I (780) heap_init: At 3FCE0000 len 0000EE34 (59 KiB): STACK/DRAM I (787) heap_init: At 3FCF0000 len 00008000 (32 KiB): DRAM I (793) heap_init: At 600FE000 len 00002000 (8 KiB): RTCRAM I (799) spiram: Adding pool of 8192K of external SPI memory to heap allocator I (808) spi_flash: detected chip: gd I (811) spi_flash: flash io: dio I (816) sleep: Configure to isolate all GPIO pins in sleep state I (822) sleep: Enable automatic switching of GPIO sleep configuration I (829) cpu_start: Starting scheduler on PRO CPU. I (0) cpu_start: Starting scheduler on APP CPU. I (840) spiram: Reserving pool of 32K of internal memory for DMA/internal allocations I (880) wifi station: ESP_WIFI_MODE_STA Hello world3 I (880) pp: pp rom version: e7ae62f I (880) net80211: net80211 rom version: e7ae62f I (900) wifi:wifi driver task: 3fca24b4, prio:23, stack:6656, core=0 I (900) system_api: Base MAC address is not set I (900) system_api: read default base MAC address from EFUSE I (920) wifi:wifi firmware version: 7679c42 I (920) wifi:wifi certification version: v7.0 I (920) wifi:config NVS flash: enabled I (920) wifi:config nano formating: disabled I (920) wifi:Init data frame dynamic rx buffer num: 32 I (930) wifi:Init management frame dynamic rx buffer num: 32 I (930) wifi:Init management short buffer num: 32 I (940) wifi:Init static tx buffer num: 16 I (940) wifi:Init tx cache buffer num: 32 I (940) wifi:Init static tx FG buffer num: 2 I (950) wifi:Init static rx buffer size: 1600 I (950) wifi:Init static rx buffer num: 10 I (960) wifi:Init dynamic rx buffer num: 32 I (960) wifi_init: rx ba win: 6 I (960) wifi_init: tcpip mbox: 32 I (970) wifi_init: udp mbox: 6 I (970) wifi_init: tcp mbox: 6 I (980) wifi_init: tcp tx win: 5744 I (980) wifi_init: tcp rx win: 5744 I (980) wifi_init: tcp mss: 1440 I (990) wifi_init: WiFi IRAM OP enabled I (990) wifi_init: WiFi RX IRAM OP enabled I (1000) phy_init: phy_version 302,3ddfab3,Dec 3 2021,14:39:12 I (1050) wifi:mode : sta (68:b6:b3:24:75:78) I (1050) wifi:enable tsf I (1050) wifi station: wifi_init_sta finished. I (1140) wifi<1,1>, old:<1,0>, ap:<255,255>, sta:<1,1>, prof:1 I (1140) wifi:state: init -> auth (b0) I (2140) wifi:state: auth -> init (200) I (2140) wifi<1,0>, old:<1,1>, ap:<255,255>, sta:<1,1>, prof:1 I (2140) wifi station: retry to connect to the AP I (2140) wifi station: connect to the AP fail I (2780) wifi<6,0>, old:<1,0>, ap:<255,255>, sta:<6,0>, prof:1 I (2780) wifi:state: init -> auth (b0) I (3780) wifi:state: auth -> init (200) I (3790) wifi<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1 I (3790) wifi station: retry to connect to the AP I (3790) wifi station: connect to the AP fail I (5830) wifi station: retry to connect to the AP I (5830) wifi station: connect to the AP fail I (5850) wifi<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1 I (5850) wifi:state: init -> auth (b0) I (6850) wifi:state: auth -> init (200) I (6850) wifi<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1 I (6850) wifi station: retry to connect to the AP I (6860) wifi station: connect to the AP fail I (7070) wifi<1,1>, old:<6,0>, ap:<255,255>, sta:<1,1>, prof:1 I (7070) wifi:state: init -> auth (b0) I (8070) wifi:state: auth -> init (200) I (8070) wifi<1,0>, old:<1,1>, ap:<255,255>, sta:<1,1>, prof:1 I (8080) wifi station: retry to connect to the AP I (8080) wifi station: connect to the AP fail I (10120) wifi station: connect to the AP fail I (10120) wifi station: Failed to connect to SSID:tianxing, password:23456789 |
1个回答
以下是一些建议和可能的原因:
1. 检查Wi-Fi配置:确保您在代码中设置了正确的SSID和密码。如果SSID或密码错误,设备将无法连接到Wi-Fi网络。 2. 检查Wi-Fi天线:您提到使用了IPEX外置天线,请确保天线连接正确,没有损坏或接触不良。 3. 检查电源供应:确保ESP32-S3R8设备获得足够的电源供应,因为不稳定的电源可能会影响Wi-Fi性能。 4. 更新ESP-IDF版本:您当前使用的是ESP-IDF v4.4,可以尝试升级到最新版本,以解决可能的已知问题。 5. 检查代码逻辑:确保您的代码中没有逻辑错误,例如在初始化Wi-Fi之前尝试连接或创建接入点。 6. 检查错误信息:尽管您提到没有打印错误信息,但仍然建议您检查ESP32-S3R8设备的串口输出,看看是否有任何有用的调试信息。 7. 尝试使用其他Wi-Fi模块:如果可能,尝试使用其他Wi-Fi模块(例如ESP8266或ESP32-WROOM-32)来排除硬件问题。 8. 检查周围环境:确保您的设备周围没有强烈的电磁干扰,这可能会影响Wi-Fi信号。 9. 检查ESP32-S3R8设备的固件:确保您的设备上运行的是正确的固件版本,以支持所需的Wi-Fi功能。 |
只有小组成员才能发言,加入小组>>
474浏览 6评论
397浏览 5评论
有没有办法在不使用混杂模式的情况下实现Wifi驱动程序接收缓冲区访问中断呢?
377浏览 5评论
383浏览 4评论
354浏览 4评论
GMT+8, 2024-9-28 16:24 , Processed in 0.750206 second(s), Total 80, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
