D:硬件开发资料esp-idf-v5.0.1examplesperipheralstwaitwai_networktwai_network_master>idf.py set-target esp32s3
Adding "set-target"'s dependency "fullclean" to list of commands with default set of options. Executing action: fullclean Build directory 'd:硬件开发资料esp-idf-v5.0.1examplesperipheralstwaitwai_networktwai_network_masterbuild' not found. Nothing to clean. Executing action: set-target Set Target to: esp32s3, new sdkconfig created. Existing sdkconfig renamed to sdkconfig.old. Running cmake in directory d:硬件开发资料esp-idf-v5.0.1examplesperipheralstwaitwai_networktwai_network_masterbuild Executing "cmake -G Ninja -DPYTHON_DEPS_CHECKED=1 -DESP_PLATFORM=1 -DIDF_TARGET=esp32s3 -DCCACHE_ENABLE=1 d:硬件开发资 料esp-idf-v5.0.1examplesperipheralstwaitwai_networktwai_network_master"... -- Found Git: C:/Program Files/Git/cmd/git.exe (found version "2.40.0.windows.1") -- ccache will be used for faster recompilation -- The C compiler identification is GNU 11.2.0 -- The CXX compiler identification is GNU 11.2.0 -- The ASM compiler identification is GNU -- Found assembler: M:/work/tool/Espressif_ide2.9.0/tools/xtensa-esp32s3-elf/esp-2022r1-11.2.0/xtensa-esp32s3-elf/bin/xtensa-esp32s3-elf-gcc.exe -- Detecting C compiler ABI info -- Detecting C compiler ABI info - done -- Check for working C compiler: M:/work/tool/Espressif_ide2.9.0/tools/xtensa-esp32s3-elf/esp-2022r1-11.2.0/xtensa-esp32s3-elf/bin/xtensa-esp32s3-elf-gcc.exe - skipped -- Detecting C compile features -- Detecting C compile features - done -- Detecting CXX compiler ABI info -- Detecting CXX compiler ABI info - done -- Check for working CXX compiler: M:/work/tool/Espressif_ide2.9.0/tools/xtensa-esp32s3-elf/esp-2022r1-11.2.0/xtensa-esp32s3-elf/bin/xtensa-esp32s3-elf-g++.exe - skipped -- Detecting CXX compile features -- Detecting CXX compile features - done -- Project is not inside a git repository, or git repository has no commits; will not use 'git describe' to determine PROJECT_VER. -- Building ESP-IDF components for target esp32s3 -- Project sdkconfig file D:/硬件开发资料/esp-idf-v5.0.1/examples/peripherals/twai/twai_network/twai_network_master/sdkconfig Traceback (most recent call last): File "D:硬件开发资料esp-idf-v5.0.1toolskconfig_newprepare_kconfig_files.py", line 102, in main() File "D:硬件开发资料esp-idf-v5.0.1toolskconfig_newprepare_kconfig_files.py", line 94, in main env.update(json.load(args.env_file)) File "C:UsersiwlbAppDataLocalProgramsPythonPython310libjson__init__.py", line 293, in load return loads(fp.read(), UnicodeDecodeError: 'gbk' codec can't decode byte 0xac in position 35: illegal multibyte sequence Traceback (most recent call last): File "D:硬件开发资料esp-idf-v5.0.1toolskconfig_newconfgen.py", line 607, in main() File "D:硬件开发资料esp-idf-v5.0.1toolskconfig_newconfgen.py", line 255, in main env = json.load(args.env_file) File "C:UsersiwlbAppDataLocalProgramsPythonPython310libjson__init__.py", line 293, in load return loads(fp.read(), UnicodeDecodeError: 'gbk' codec can't decode byte 0xac in position 35: illegal multibyte sequence CMake Error at D:/硬件开发资料/esp-idf-v5.0.1/tools/cmake/kconfig.cmake:176 (message): Failed to run confgen.py (M:/work/tool/Espressif_ide2.9.0/python_env/idf5.0_py3.10_env/Scripts/python.exe;D:/硬件开发资料/esp-idf-v5.0.1/tools/kconfig_new/confgen.py;--list-separator=semicolon;--kconfig;D:/硬件开发资料/esp-idf-v5.0.1/Kconfig;--sdkconfig-rename;D:/硬件开发资料/esp-idf-v5.0.1/sdkconfig.rename;--config;D:/硬件开发资料/esp-idf-v5.0.1/examples/peripherals/twai/twai_network/twai_network_master/sdkconfig;--env-file;D:/硬件开发资料/esp-idf-v5.0.1/examples/peripherals/twai/twai_network/twai_network_master/build/config.env). Error 1 Call Stack (most recent call first): D:/硬件开发资料/esp-idf-v5.0.1/tools/cmake/build.cmake:590 (__kconfig_generate_config) D:/硬件开发资料/esp-idf-v5.0.1/tools/cmake/project.cmake:440 (idf_build_process) CMakeLists.txt:6 (project) -- Configuring incomplete, errors occurred! See also "D:/硬件开发资料/esp-idf-v5.0.1/examples/peripherals/twai/twai_network/twai_network_master/build/CMakeFiles/CMakeOutput.log". Traceback (most recent call last): File "D:硬件开发资料esp-idf-v5.0.1toolsidf.py", line 772, in main() File "D:硬件开发资料esp-idf-v5.0.1toolsidf.py", line 707, in main cli(sys.argv[1:], prog_name=PROG, complete_var=SHELL_COMPLETE_VAR) File "M:worktoolEspressif_ide2.9.0python_envidf5.0_py3.10_envlibsite-packagesclickcore.py", line 1128, in __call__ return self.main(*args, **kwargs) File "M:worktoolEspressif_ide2.9.0python_envidf5.0_py3.10_envlibsite-packagesclickcore.py", line 1053, in main rv = self.invoke(ctx) File "M:worktoolEspressif_ide2.9.0python_envidf5.0_py3.10_envlibsite-packagesclickcore.py", line 1691, in invoke return _process_result(rv) File "M:worktoolEspressif_ide2.9.0python_envidf5.0_py3.10_envlibsite-packagesclickcore.py", line 1628, in _process_result value = ctx.invoke(self._result_callback, value, **ctx.params) File "M:worktoolEspressif_ide2.9.0python_envidf5.0_py3.10_envlibsite-packagesclickcore.py", line 754, in invoke return __callback(*args, **kwargs) File "D:硬件开发资料esp-idf-v5.0.1toolsidf.py", line 602, in execute_tasks task(ctx, global_args, task.action_args) File "D:硬件开发资料esp-idf-v5.0.1toolsidf.py", line 189, in __call__ self.callback(self.name, context, global_args, **action_args) File "d:硬件开发资料esp-idf-v5.0.1toolsidf_py_actionscore_ext.py", line 161, in set_target ensure_build_directory(args, ctx.info_name, True) File "D:硬件开发资料esp-idf-v5.0.1toolsidf_py_actionstools.py", line 455, in ensure_build_directory RunTool('cmake', cmake_args, cwd=args.build_dir, hints=hints)() File "D:硬件开发资料esp-idf-v5.0.1toolsidf_py_actionstools.py", line 219, in __call__ print_hints(stderr_output_file, stdout_output_file) File "D:硬件开发资料esp-idf-v5.0.1toolsidf_py_actionstools.py", line 125, in print_hints output = ' '.join(line.strip() for line in file if line.strip()) File "D:硬件开发资料esp-idf-v5.0.1toolsidf_py_actionstools.py", line 125, in output = ' '.join(line.strip() for line in file if line.strip()) UnicodeDecodeError: 'gbk' codec can't decode byte 0xac in position 50: illegal multibyte sequence D:硬件开发资料esp-idf-v5.0.1examplesperipheralstwaitwai_networktwai_network_master> |
2个回答
请更换 esp-idf 在英文路径下。
根据您提供的错误信息,这个问题可能是由于以下几个原因导致的:
1. 路径问题:您的项目路径中可能包含特殊字符或空格,导致命令无法正确执行。 2. 权限问题:您可能没有足够的权限来执行这个命令。 3. 环境问题:您的开发环境可能没有正确配置。 为了解决这个问题,请尝试以下步骤: 1. 检查路径:确保您的项目路径中没有特殊字符或空格。如果有,请将项目移动到一个没有特殊字符或空格的路径下。 2. 以管理员身份运行:尝试以管理员身份运行命令提示符或终端,然后再次执行命令。 3. 检查环境变量:确保您的环境变量已经正确设置。对于ESP-IDF,您需要设置以下环境变量: - `IDF_PATH`:指向您的ESP-IDF安装目录。 - `PATH`:将`IDF_PATH`中的`components/esptool_py/esptool`添加到系统路径。 4. 更新ESP-IDF:您当前使用的ESP-IDF版本是5.0.1,尝试更新到最新版本,以获取最新的功能和修复。 5. 清理并重新配置:在命令提示符或终端中,尝试执行以下命令来清理并重新配置项目: ``` cd path/to/your/project idf.py fullclean idf.py set-target esp32s3 idf.py menuconfig ``` |
只有小组成员才能发言,加入小组>>
1118 浏览 1 评论
574浏览 6评论
477浏览 5评论
有没有办法在不使用混杂模式的情况下实现Wifi驱动程序接收缓冲区访问中断呢?
461浏览 5评论
461浏览 4评论
435浏览 4评论
GMT+8, 2024-12-19 21:50 , Processed in 0.783243 second(s), Total 51, Slave 45 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
