电子发烧友论坛|
[11:28:33.519]收←◆ESP-ROM:esp32c3-api1-20210207
Build:Feb 7 2021 rst:0x1 (POWERON),boot:0xc (SPI_FAST_FLASH_BOOT) SPIWP:0xee mode:DIO, clock div:1 load:0x3fcd5820,len:0x170c load:0x403cc710,len:0x968 load:0x403ce710,len:0x2f68 entry 0x403cc710 [0;32mI (30) boot: ESP-IDF v5.1.1-dirty 2nd stage bootloader[0m [0;32mI (30) boot: compile time Sep 28 2023 10:30:44[0m [0;32mI (30) boot: chip revision: v0.4[0m [0;32mI (34) boot.esp32c3: SPI Speed : 80MHz[0m [0;32mI (39) boot.esp32c3: SPI Mode : DIO[0m [0;32mI (43) boot.esp32c3: SPI Flash Size : 2MB[0m [0;32mI (48) boot: Enabling RNG early entropy source...[0m [0;32mI (53) boot: Partition Table:[0m [0;32mI (57) boot: ## Label Usage Type ST Offset Length[0m [0;32mI (64) boot: 0 nvs WiFi data 01 02 00009000 00006000[0m [0;32mI (72) boot: 1 phy_init RF data 01 01 0000f000 00001000[0m [0;32mI (79) boot: 2 factory factory app 00 00 00010000 00100000[0m [0;32mI (87) boot: End of partition table[0m [0;32mI (91) esp_image: segment 0: paddr=00010020 vaddr=3c090020 size=22b18h (142104) map[0m [0;32mI (122) esp_image: segment 1: paddr=00032b40 vaddr=3fc90800 size=02898h ( 10392) load[0m [0;32mI (124) esp_image: segment 2: paddr=000353e0 vaddr=40380000 size=0ac38h ( 44088) load[0m [0;32mI (136) esp_image: segment 3: paddr=00040020 vaddr=42000020 size=8b6a0h (571040) map[0m [11:28:33.745]收←◆[0;32mI (227) esp_image: segment 4: paddr=000cb6c8 vaddr=4038ac38 size=059e8h ( 23016) load[0m [0;32mI (237) boot: Loaded app from partition at offset 0x10000[0m [0;32mI (237) boot: Disabling RNG early entropy source...[0m [0;32mI (249) cpu_start: Unicore app[0m [0;32mI (249) cpu_start: Pro cpu up.[0m D (257) clk: RTC_SLOW_CLK calibration value: 3705062[0m [0;32mI (263) cpu_start: Pro cpu start user code[0m [0;32mI (263) cpu_start: cpu freq: 160000000 Hz[0m [0;32mI (263) cpu_start: Application information:[0m [0;32mI (266) cpu_start: Project name: wifi_station[0m [0;32mI (271) cpu_start: App version: 1[0m [0;32mI (275) cpu_start: Compile time: Sep 28 2023 10:30:21[0m [0;32mI (281) cpu_start: ELF file SHA256: b3f1974edd4c2536...[0m [0;32mI (287) cpu_start: ESP-IDF: v5.1.1-dirty[0m [0;32mI (293) cpu_start: Min chip rev: v0.3[0m [0;32mI (298) cpu_start: Max chip rev: v0.99 [0m [0;32mI (302) cpu_start: Chip rev: v0.4[0m D (307) memory_layout: Checking 5 reserved memory ranges:[0m D (313) memory_layout: Reserved memory range 0x3fc80000 - 0x3fc90800[0m D (319) memory_layout: Reserved memory range 0x3fc90800 - 0x3fc97140[0m D (325) memory_layout: Reserved memory range 0x3fcdf060 - 0x3fce0000[0m D (332) memory_layout: Reserved memory range 0x50000000 - 0x50000010[0m D (338) memory_layout: Reserved memory range 0x50001fe8 - 0x50002000[0m D (345) memory_layout: Building list of available memory regions:[0m D (351) memory_layout: Available memory region 0x3fc97140 - 0x3fca0000[0m D (357) memory_layout: Available memory region 0x3fca0000 - 0x3fcc0000[0m D (364) memory_layout: Available memory region 0x3fcc0000 - 0x3fcdc710[0m D (371) memory_layout: Available memory region 0x3fcdc710 - 0x3fcdf060[0m D (377) memory_layout: Available memory region 0x50000010 - 0x50001fe8[0m [0;32mI (384) heap_init: Initializing. RAM available for dynamic allocation:[0m D (391) heap_init: New heap initialised at 0x3fc97140[0m [0;32mI (396) heap_init: At 3FC97140 len 000455D0 (277 KiB): DRAM[0m [0;32mI (402) heap_init: At 3FCDC710 len 00002950 (10 KiB): STACK/DRAM[0m D (409) heap_init: New heap initialised at 0x50000010[0m [0;32mI (414) heap_init: At 50000010 len 00001FD8 (7 KiB): RTCRAM[0m D (421) intr_alloc: Connected src 27 to int 2 (cpu 0)[0m D (426) spi_flash: trying chip: issi[0m D (429) spi_flash: trying chip: gd[0m D (433) spi_flash: trying chip: mxic[0m D (436) spi_flash: trying chip: winbond[0m D (440) spi_flash: trying chip: boya[0m D (444) spi_flash: trying chip: th[0m D (447) spi_flash: trying chip: generic[0m [0;32mI (451) spi_flash: detected chip: generic[0m [0;32mI (456) spi_flash: flash io: dio[0m [0;33mW (460) spi_flash: Detected size(4096k) larger than the size in the binary image header(2048k). Using the size in the binary image header.[0m D (473) cpu_start: calling init function: 0x42076c0e[0m D (478) cpu_start: calling init function: 0x42076b66[0m D (483) cpu_start: calling init function: 0x42076976[0m D (488) cpu_start: calling init function: 0x420764b4[0m D (493) cpu_start: calling init function: 0x42044b4c[0m D (498) efuse: In EFUSE_BLK2__DATA4_REG is used 2 bits starting with 0 bit[0m D (505) efuse: In EFUSE_BLK2__DATA5_REG is used 10 bits starting with 18 bit[0m D (512) cpu_start: calling init function: 0x42014346[0m D (517) cpu_start: calling init function: 0x4200002a[0m D (522) cpu_start: calling init function: 0x420058dc on core: 0[0m D (529) intr_alloc: Connected src 39 to int 3 (cpu 0)[0m D (533) cpu_start: calling init function: 0x4200329a on core: 0[0m [0;32mI (540) sleep: Configure to isolate all GPIO pins in sleep state[0m [0;32mI (546) sleep: Enable automatic switching of GPIO sleep configuration[0m D (553) cpu_start: calling init function: 0x42001364 on core: 0[0m D (559) intr_alloc: Connected src 50 to int 4 (cpu 0)[0m [0;32mI (564) app_start: Starting scheduler on CPU0[0m D (569) intr_alloc: Connected src 37 to int 7 (cpu 0)[0m [0;32mI (569) main_task: Started on CPU0[0m D (569) heap_init: New heap initialised at 0x3fcdc710[0m D (569) intr_alloc: Connected src 33 to int 9 (cpu 0)[0m [0;32mI (579) main_task: Calling app_main()[0m [0;32mI (589) wifi station: ESP_WIFI_MODE_STA[0m D (589) esp_netif_lwip: LwIP stack has been initialized[0m D (589) esp_netif_lwip: esp-netif has been successfully initialized[0m D (599) event: running task for loop 0x3fc9c5c8[0m D (599) event: created task for loop 0x3fc9c5c8[0m D (609) event: created event loop 0x3fc9c5c8[0m D (609) esp_netif_objects: esp_netif_add_to_list 0x3fc9d4f0[0m D (619) esp_netif_objects: esp_netif_add_to_list netif added successfully (total netifs: 1)[0m D (629) esp_netif_lwip: check: remote, if=0x0 fn=0x420109c2 [0m D (629) esp_netif_lwip: call api in lwip: ret=0x0, give sem[0m [0;32mI (639) pp: pp rom version: 9387209[0m [0;32mI (639) net80211: net80211 rom version: 9387209[0m D (649) nvs: nvs_open_from_partition misc 1[0m I (659) wifi:wifi driver task: 3fc9feec, prio:23, stack:6656, core=0 D (659) efuse: In EFUSE_BLK1__DATA1_REG is used 8 bits starting with 8 bit[0m D (669) efuse: In EFUSE_BLK1__DATA1_REG is used 8 bits starting with 0 bit[0m D (669) efuse: In EFUSE_BLK1__DATA0_REG is used 8 bits starting with 24 bit[0m D (679) efuse: In EFUSE_BLK1__DATA0_REG is used 8 bits starting with 16 bit[0m D (689) efuse: In EFUSE_BLK1__DATA0_REG is used 8 bits starting with 8 bit[0m D (689) efuse: In EFUSE_BLK1__DATA0_REG is used 8 bits starting with 0 bit[0m D (699) nvs: nvs_open_from_partition nvs.net80211 1[0m D (709) nvs: nvs_get opmode 1[0m D (709) nvs: nvs_get_str_or_blob sta.ssid[0m D (709) nvs: nvs_get sta.authmode 1[0m D (719) nvs: nvs_get_str_or_blob sta.pswd[0m D (719) nvs: nvs_get_str_or_blob sta.pmk[0m D (719) nvs: nvs_get sta.chan 1[0m D (729) nvs: nvs_get auto.conn 1[0m D (729) nvs: nvs_get bssid.set 1[0m D (729) nvs: nvs_get_str_or_blob sta.bssid[0m D (739) nvs: nvs_get sta.lis_intval 2[0m D (739) nvs: nvs_get sta.phym 1[0m D (749) nvs: nvs_get sta.phybw 1[0m D (749) nvs: nvs_get_str_or_blob sta.apsw[0m D (749) nvs: nvs_get_str_or_blob sta.apinfo[0m D (759) nvs: nvs_get sta.scan_method 1[0m D (759) nvs: nvs_get sta.sort_method 1[0m D (759) nvs: nvs_get sta.minrssi 1[0m D (769) nvs: nvs_get sta.minauth 1[0m D (769) nvs: nvs_get sta.pmf_e 1[0m D (769) nvs: nvs_get sta.pmf_r 1[0m D (779) nvs: nvs_get sta.btm_e 1[0m D (779) nvs: nvs_get sta.rrm_e 1[0m D (779) nvs: nvs_get sta.mbo_e 1[0m D (789) nvs: nvs_get_str_or_blob ap.ssid[0m D (789) nvs: nvs_get_str_or_blob ap.passwd[0m D (799) nvs: nvs_get_str_or_blob ap.pmk[0m D (799) nvs: nvs_get ap.chan 1[0m D (799) nvs: nvs_get ap.authmode 1[0m D (809) nvs: nvs_get ap.hidden 1[0m D (809) nvs: nvs_get ap.max.conn 1[0m D (809) nvs: nvs_get bcn.interval 2[0m D (819) nvs: nvs_get ap.phym 1[0m D (819) nvs: nvs_get ap.phybw 1[0m D (819) nvs: nvs_get ap.sndchan 1[0m D (829) nvs: nvs_get ap.pmf_e 1[0m D (829) nvs: nvs_get ap.pmf_r 1[0m D (829) nvs: nvs_get ap.p_cipher 1[0m D (839) nvs: nvs_get lorate 1[0m D (839) nvs: nvs_get_str_or_blob country[0m D (839) nvs: nvs_get ap.ftm_r 1[0m D (849) nvs: nvs_get sta.ft 1[0m D (849) nvs: nvs_get sta.owe 1[0m D (849) nvs: nvs_get sta.trans_d 1[0m D (859) nvs: nvs_get sta.sae_h2e 1[0m D (859) nvs: nvs_get sta.sae_pk_mode 1[0m D (859) nvs: nvs_get sta.bss_retry 1[0m D (869) nvs: nvs_get_str_or_blob sta.owe_data[0m D (869) nvs: nvs_get sta.he_dcm 1[0m D (879) nvs: nvs_get sta.he_dcm_c_tx 1[0m D (879) nvs: nvs_get sta.he_dcm_c_rx 1[0m D (879) nvs: nvs_get sta.he_mcs9_d 1[0m D (889) nvs: nvs_get sta.he_su_b_d 1[0m D (889) nvs: nvs_get sta.he_su_b_f_d 1[0m D (889) nvs: nvs_get sta.he_mu_b_f_d 1[0m D (899) nvs: nvs_get sta.he_cqi_f_d 1[0m D (899) nvs: nvs_get_str_or_blob sta.sae_h2e_id[0m D (909) nvs: nvs_get ap.sae_h2e 1[0m D (909) nvs: nvs_get_str_or_blob ap.pmk_info[0m D (909) nvs: nvs_get nan.phym 1[0m D (919) nvs: nvs_set ap.sndchan 1 1[0m I (919) wifi:wifi firmware version: ce9244d I (919) wifi:wifi certification version: v7.0 I (929) wifi:config NVS flash: enabled I (929) wifi:config nano formating: disabled I (939) wifi:Init data frame dynamic rx buffer num: 32 I (939) wifi:Init management frame dynamic rx buffer num: 32 I (949) wifi:Init management short buffer num: 32 I (949) wifi:Init dynamic tx buffer num: 32 I (949) wifi:Init static tx FG buffer num: 2 I (959) wifi:Init static rx buffer size: 1600 I (959) wifi:Init static rx buffer num: 10 I (969) wifi:Init dynamic rx buffer num: 32 [0;32mI (969) wifi_init: rx ba win: 6[0m [0;32mI (969) wifi_init: tcpip mbox: 32[0m [0;32mI (979) wifi_init: udp mbox: 6[0m [0;32mI (979) wifi_init: tcp mbox: 6[0m [0;32mI (989) wifi_init: tcp tx win: 5744[0m [0;32mI (989) wifi_init: tcp rx win: 5744[0m [0;32mI (989) wifi_init: tcp mss: 1440[0m [0;32mI (999) wifi_init: WiFi IRAM OP enabled[0m [0;32mI (999) wifi_init: WiFi RX IRAM OP enabled[0m D (1009) nvs: nvs_get opmode 1[0m D (1009) wifi:clear blacklist D (1009) nvs: nvs_set_blob sta.ssid 36[0m D (1029) nvs: nvs_set_blob sta.pswd 65[0m D (1029) nvs: nvs_set bssid.set 1 0[0m D (1029) nvs: nvs_set sta.lis_intval 2 3[0m D (1029) nvs: nvs_set sta.chan 1 0[0m D (1029) nvs: nvs_set sta.scan_method 1 0[0m D (1039) nvs: nvs_set sta.sort_method 1 0[0m D (1039) nvs: nvs_set sta.minrssi 1 -127[0m D (1039) nvs: nvs_set sta.minauth 1 3[0m D (1049) nvs: nvs_set_blob sta.apsw 2[0m D (1059) nvs: nvs_set sta.pmf_e 1 1[0m D (1059) nvs: nvs_set sta.pmf_r 1 0[0m D (1059) nvs: nvs_set sta.rrm_e 1 0[0m D (1059) nvs: nvs_set sta.btm_e 1 0[0m D (1069) nvs: nvs_set sta.mbo_e 1 0[0m D (1069) nvs: nvs_set sta.ft 1 0[0m D (1069) nvs: nvs_set sta.owe 1 0[0m D (1079) nvs: nvs_set sta.bss_retry 1 0[0m D (1079) nvs: nvs_set sta.trans_d 1 0[0m D (1079) nvs: nvs_set sta.sae_h2e 1 2[0m D (1089) nvs: nvs_set sta.sae_pk_mode 1 0[0m D (1089) nvs: nvs_set_blob sta.sae_h2e_id 32[0m D (1099) nvs: nvs_set_blob sta.apinfo 700[0m [0;32mI (1099) phy_init: phy_version 970,1856f88,May 10 2023,17:44:12[0m D (1109) phy_init: loading PHY init data from application binary[0m D (1109) nvs: nvs_open_from_partition phy 0[0m D (1119) nvs: nvs_get cal_version 4[0m D (1119) nvs: nvs_get_str_or_blob cal_mac[0m D (1119) efuse: In EFUSE_BLK1__DATA1_REG is used 8 bits starting with 8 bit[0m D (1129) efuse: In EFUSE_BLK1__DATA1_REG is used 8 bits starting with 0 bit[0m D (1139) efuse: In EFUSE_BLK1__DATA0_REG is used 8 bits starting with 24 bit[0m D (1149) efuse: In EFUSE_BLK1__DATA0_REG is used 8 bits starting with 16 bit[0m D (1149) efuse: In EFUSE_BLK1__DATA0_REG is used 8 bits starting with 8 bit[0m D (1159) efuse: In EFUSE_BLK1__DATA0_REG is used 8 bits starting with 0 bit[0m D (1169) nvs: nvs_get_str_or_blob cal_data[0m D (1169) nvs: nvs_close 3[0m D (1169) efuse: In EFUSE_BLK1__DATA1_REG is used 8 bits starting with 8 bit[0m D (1179) efuse: In EFUSE_BLK1__DATA1_REG is used 8 bits starting with 0 bit[0m D (1189) efuse: In EFUSE_BLK1__DATA0_REG is used 8 bits starting with 24 bit[0m D (1189) efuse: In EFUSE_BLK1__DATA0_REG is used 8 bits starting with 16 bit[0m D (1199) efuse: In EFUSE_BLK1__DATA0_REG is used 8 bits starting with 8 bit[0m D (1209) efuse: In EFUSE_BLK1__DATA0_REG is used 8 bits starting with 0 bit[0m D (1229) temperature_sensor: range changed, change to index 2[0m D (1259) wifi:filter: set rx policy=0 I (1259) wifi:mode : sta (ec:da:3b I (1259) wifi:enable tsf D (1259) wifi:filter: set rx policy=1 D (1259) wifi:connect status 0 -> 0 D (1259) event: running post WIFI_EVENT:2 with handler 0x42014788 and context 0x3fc9d744 on loop 0x3fc9c5c8[0m D (1269) wifi_init_default: wifi_start esp-netif:0x3fc9d4f0 event-id2[0m D (1279) wifi_init_default: WIFI mac address: ec da 3b ab 7 18[0m D (1279) esp_netif_lwip: check: remote, if=0x3fc9d4f0 fn=0x420109e2 [0m D (1289) esp_netif_lwip: call api in lwip: ret=0x0, give sem[0m D (1299) esp_netif_handlers: esp_netif action has started with netif0x3fc9d4f0 from event_id=2[0m D (1299) esp_netif_lwip: check: remote, if=0x3fc9d4f0 fn=0x42011456 [0m D (1309) esp_netif_lwip: esp_netif_start_api 0x3fc9d4f0[0m D (1319) esp_netif_lwip: esp_netif_get_hostname esp_netif:0x3fc9d4f0[0m D (1319) esp_netif_lwip: check: local, if=0x3fc9d4f0 fn=0x420121c4 [0m D (1329) esp_netif_lwip: esp_netif_update_default_netif_lwip 0x3fc9d4f0[0m D (1339) esp_netif_lwip: call api in lwip: ret=0x0, give sem[0m D (1339) event: running post WIFI_EVENT:2 with handler 0x42007f2e and context 0x3fca55f8 on loop 0x3fc9c5c8[0m D (1349) wifi:Start wifi connect D (1349) wifi:connect status 0 -> 0 D (1359) wifi:connect chan=0 D (1359) wifi:first chan=6 D (1359) wifi:connect status 0 -> 1 D (1369) wifi:filter: set rx policy=3 D (1369) wifi:clear scan ap list D (1369) wifi:start scan: type=0x50f, priority=2, cb=0x42036826, arg=0x0, ss_state=0x1, time=1382136, index=0 D (1379) wifi:perform scan: ss_state=0x9, chan<6,0>, dur<0,120> [0;32mI (1389) wifi station: wifi_init_sta finished.[0m D (1389) wifi:rsn valid: gcipher=3 ucipher=3 akm=5 D (1399) wifi:profile match: ss_state=0x7 D (1399) wifi:scan end: arg=0x0, status=0, ss_state=0x7 D (1409) wifi:find first mathched ssid, scan done D (1409) wifi:filter: set rx policy=4 D (1409) wifi:first chan=1 D (1419) wifi:handoff_cb: status=0 D (1419) wifi:ap found, mac=4e:1d:96:d8:a5:5e D (1419) wifi:new_bss=0x3fc94a40, cur_bss=0x0, new_chan=<6,0>, cur_chan=1 D (1429) wifi:filter: set rx policy=5 I (1429) wifi D (1439) wifi:connect_op: status=0, auth=5, cipher=3 D (1439) wifi:auth mode is not none D (1449) wifi:connect_bss: auth=1, reconnect=0 I (1449) wifi:state: init -> auth (b0) D (1459) wifi:start 1s AUTH timer D (1459) wifi:clear scan ap list D (1469) wifi:recv auth: seq=2, status=0 I (1469) wifi:state: auth -> assoc (0) D (1469) wifi:restart connect 1s timer for assoc D (1469) wifi:recv assoc: type=0x10 D (1479) wifi:filter: set rx policy=6 I (1479) wifi:state: assoc -> run (10) D (1479) wifi:start 10s connect timer for 4 way handshake D (1489) gdma: new group (0) at 0x3fca5fac[0m D (1489) gdma: new pair (0,0) at 0x3fca5fe0[0m D (1499) gdma: new tx channel (0,0) at 0x3fca5f78[0m D (1499) gdma: new rx channel (0,0) at 0x3fca6000[0m D (1509) gdma: tx channel (0,0), (1:0) bytes aligned, burst enabled[0m D (1509) gdma: rx channel (0,0), (1:0) bytes aligned, burst disabled[0m I (1529) wifi:connected with EESP123456, aid = 6, channel 6, BW20, bssid = 4e:1d:96:d8:a5:5e I (1529) wifi:security: WPA2-PSK, phy: bgn, rssi: -23 D (1529) wifi:remove all except 4e:1d:96:d8:a5:5e from rc list D (1539) wifi:clear blacklist D (1539) nvs: nvs_set sta.chan 1 6[0m D (1549) nvs: nvs_set_blob sta.apinfo 700[0m D (1549) wifi:filter: set rx policy=7 I (1549) wifi:pm start, type: 1 I (1549) wifi:set rx beacon pti, rx_bcn_pti: 0, bcn_timeout: 25000, mt_pti: 0, mt_time: 10000 D (1559) wifi:Send sta connected event D (1569) wifi:connect status 1 -> 5 D (1569) wifi:obss scan is disabled D (1569) wifi:start obss scan: obss scan is stopped D (1579) event: running post WIFI_EVENT:4 with handler 0x420147bc and context 0x3fc9d7a4 on loop 0x3fc9c5c8[0m I (1579) wifi:AP's beacon interval = 102400 us, DTIM period = 3 D (1589) wifi:set max rate: from to D (1599) wifi:sig_b=1, sig_g=0, sig_n=0, max_b=0, max_g=108, max_n=144 D (1609) wifi:update trc D (1609) esp_netif_handlers: esp_netif action connected with netif0x3fc9d4f0 from event_id=4[0m D (1619) esp_netif_lwip: check: remote, if=0x3fc9d4f0 fn=0x4201197a [0m D (1619) esp_netif_lwip: esp_netif_up_api esp_netif:0x3fc9d4f0[0m D (1629) esp_netif_lwip: check: local, if=0x3fc9d4f0 fn=0x420121c4 [0m D (1629) esp_netif_lwip: esp_netif_update_default_netif_lwip 0x3fc9d4f0[0m D (1639) esp_netif_lwip: call api in lwip: ret=0x0, give sem[0m D (1649) esp_netif_lwip: check: remote, if=0x3fc9d4f0 fn=0x420117b6 [0m D (1649) esp_netif_lwip: esp_netif_dhcpc_start_api esp_netif:0x3fc9d4f0[0m D (1659) esp_netif_lwip: esp_netif_start_ip_lost_timer esp_netif:0x3fc9d4f0[0m D (1669) esp_netif_lwip: if0x3fc9d4f0 start ip lost tmr: no need start because netif=0x3fc9d574 interval=120 ip=0[0m D (1679) esp_netif_lwip: starting dhcp client[0m D (1679) esp_netif_lwip: call api in lwip: ret=0x0, give sem[0m D (1689) event: running post WIFI_EVENT:4 with handler 0x42007f2e and context 0x3fca55f8 on loop 0x3fc9c5c8[0m [11:28:36.204]收←◆D (2679) esp_netif_lwip: esp_netif_internal_dhcpc_cb lwip-netif:0x3fc9d574[0m D (2679) esp_netif_lwip: if0x3fc9d4f0 ip changed=1[0m D (2679) event: running post IP_EVENT:0 with handler 0x4201451e and context 0x3fc9d878 on loop 0x3fc9c5c8[0m D (2689) wifi_init_default: Got IP wifi default handler entered[0m D (2689) esp_netif_handlers: esp_netif action got_ip with netif0x3fc9d4f0 from event_id=0[0m [0;32mI (2699) esp_netif_handlers: sta ip: 172.16.63.3, mask: 255.255.0.0, gw: 172.16.63.1[0m D (2709) event: running post IP_EVENT:0 with handler 0x42007f2e and context 0x3fca5618 on loop 0x3fc9c5c8[0m [0;32mI (2719) wifi station: got ip:172.16.63.3[0m [0;32mI (2719) wifi station: Yconnected to ap SSID:EESP123456 password:12345678[0m [0;32mI (2729) main_task: Returned from app_main()[0m [11:30:35.119]收←◆D (121599) wifi:recv deauth, reason=0x0 I (121599) wifi:state: run -> init (c0) D (121599) wifi:recv deauth/disassoc, stop beacon/connect timer D (121599) wifi:connect status 5 -> 4 D (121599) wifi:sta leave I (121599) wifi:pm stop, total sleep time: 116257899 us / 120049479 us D (121609) wifi:stop CSA timer D (121609) wifi:remove 4e:1d:96:d8:a5:5e from rc list I (121619) wifi D (121619) wifi:filter: set rx policy=8 D (121629) wifi:Send disconnect event, reason=0, AP number=0 D (121629) event: running post WIFI_EVENT:5 with handler 0x420147a2 and context 0x3fc9d7d4 on loop 0x3fc9c5c8[0m D (121639) esp_netif_handlers: esp_netif action disconnected with netif0x3fc9d4f0 from event_id=5[0m D (121649) esp_netif_lwip: check: remote, if=0x3fc9d4f0 fn=0x420119f0 [0m D (121659) esp_netif_lwip: esp_netif_down_api esp_netif:0x3fc9d4f0[0m D (121659) esp_netif_lwip: esp_netif_internal_dhcpc_cb lwip-netif:0x3fc9d574[0m D (121669) esp_netif_lwip: esp_netif_start_ip_lost_timer esp_netif:0x3fc9d4f0[0m D (121679) esp_netif_lwip: if0x3fc9d4f0 start ip lost tmr: interval=120[0m D (121679) esp_netif_lwip: esp_netif_start_ip_lost_timer esp_netif:0x3fc9d4f0[0m D (121689) esp_netif_lwip: if0x3fc9d4f0 start ip lost tmr: already started[0m D (121699) esp_netif_lwip: check: local, if=0x3fc9d4f0 fn=0x420121c4 [0m D (121709) esp_netif_lwip: esp_netif_update_default_netif_lwip 0x3fc9d4f0[0m D (121709) esp_netif_lwip: call api in lwip: ret=0x0, give sem[0m D (121719) event: running post WIFI_EVENT:5 with handler 0x42007f2e and context 0x3fca55f8 on loop 0x3fc9c5c8[0m [0;31mE (121729) wifi station: Disconnect reason : 0[0m D (121729) wifi:Start wifi connect D (121739) wifi:connect status 4 -> 0 D (121739) wifi:connect chan=0 D (121739) wifi:first chan=6 D (121749) wifi:connect status 0 -> 1 D (121749) wifi:filter: set rx policy=3 D (121749) wifi:clear scan ap list D (121759) wifi:start scan: type=0x50f, priority=2, cb=0x42036826, arg=0x0, ss_state=0x1, time=121765255, index=0 D (121769) wifi:perform scan: ss_state=0x9, chan<6,0>, dur<0,120> [0;32mI (121769) wifi station: retry to connect to the AP[0m [0;32mI (121779) wifi station: connect to the AP fail[0m D (121769) wifi:rsn valid: gcipher=3 ucipher=3 akm=5 D (121789) wifi:profile match: ss_state=0x7 D (121789) wifi:scan end: arg=0x0, status=0, ss_state=0x7 D (121799) wifi:find first mathched ssid, scan done D (121799) wifi:filter: set rx policy=4 D (121799) wifi:first chan=1 D (121809) wifi:handoff_cb: status=0 D (121809) wifi:ap found, mac=4e:1d:96:d8:a5:5e D (121809) wifi:new_bss=0x3fc94a40, cur_bss=0x0, new_chan=<6,0>, cur_chan=6 D (121819) wifi:filter: set rx policy=5 I (121819) wifi D (121829) wifi:connect_op: status=0, auth=5, cipher=3 D (121839) wifi:auth mode is not none D (121839) wifi:connect_bss: auth=1, reconnect=0 I (121839) wifi:state: init -> auth (b0) D (121849) wifi:start 1s AUTH timer D (121849) wifi:clear scan ap list D (121859) wifi:recv auth: seq=2, status=0 I (121859) wifi:state: auth -> assoc (0) D (121859) wifi:restart connect 1s timer for assoc D (121869) wifi:recv assoc: type=0x10 D (121869) wifi:filter: set rx policy=6 I (121869) wifi:state: assoc -> run (10) D (121879) wifi:start 10s connect timer for 4 way handshake I (121889) wifi:connected with EESP123456, aid = 7, channel 6, BW20, bssid = 4e:1d:96:d8:a5:5e I (121889) wifi:security: WPA2-PSK, phy: bgn, rssi: -22 D (121889) wifi:remove all except 4e:1d:96:d8:a5:5e from rc list D (121899) wifi:clear blacklist D (121899) nvs: nvs_set sta.chan 1 6[0m D (121909) nvs: nvs_set_blob sta.apinfo 700[0m D (121909) wifi:filter: set rx policy=7 I (121909) wifi:pm start, type: 1 I (121919) wifi:set rx beacon pti, rx_bcn_pti: 0, bcn_timeout: 25000, mt_pti: 0, mt_time: 10000 D (121929) wifi:Send sta connected event D (121929) wifi:connect status 1 -> 5 D (121929) wifi:obss scan is disabled D (121939) wifi:start obss scan: obss scan is stopped I (121939) wifi:AP's beacon interval = 102400 us, DTIM period = 3 D (121949) wifi:set max rate: from to D (121949) wifi:sig_b=1, sig_g=0, sig_n=0, max_b=0, max_g=108, max_n=144 D (121959) wifi:update trc D (121959) event: running post WIFI_EVENT:4 with handler 0x420147bc and context 0x3fc9d7a4 on loop 0x3fc9c5c8[0m D (121969) esp_netif_handlers: esp_netif action connected with netif0x3fc9d4f0 from event_id=4[0m D (121979) esp_netif_lwip: check: remote, if=0x3fc9d4f0 fn=0x4201197a [0m D (121989) esp_netif_lwip: esp_netif_up_api esp_netif:0x3fc9d4f0[0m D (121999) esp_netif_lwip: check: local, if=0x3fc9d4f0 fn=0x420121c4 [0m D (121999) esp_netif_lwip: esp_netif_update_default_netif_lwip 0x3fc9d4f0[0m D (122009) esp_netif_lwip: call api in lwip: ret=0x0, give sem[0m D (122009) esp_netif_lwip: check: remote, if=0x3fc9d4f0 fn=0x420117b6 [0m D (122019) esp_netif_lwip: esp_netif_dhcpc_start_api esp_netif:0x3fc9d4f0[0m D (122029) esp_netif_lwip: esp_netif_start_ip_lost_timer esp_netif:0x3fc9d4f0[0m D (122039) esp_netif_lwip: if0x3fc9d4f0 start ip lost tmr: already started[0m D (122039) esp_netif_lwip: starting dhcp client[0m D (122049) esp_netif_lwip: call api in lwip: ret=0x0, give sem[0m D (122049) event: running post WIFI_EVENT:4 with handler 0x42007f2e and context 0x3fca55f8 on loop 0x3fc9c5c8[0m [11:30:36.571]收←◆D (123049) esp_netif_lwip: esp_netif_internal_dhcpc_cb lwip-netif:0x3fc9d574[0m D (123049) esp_netif_lwip: if0x3fc9d4f0 ip changed=0[0m D (123049) event: running post IP_EVENT:0 with handler 0x4201451e and context 0x3fc9d878 on loop 0x3fc9c5c8[0m D (123059) wifi_init_default: Got IP wifi default handler entered[0m D (123059) esp_netif_handlers: esp_netif action got_ip with netif0x3fc9d4f0 from event_id=0[0m [0;32mI (123069) esp_netif_handlers: sta ip: 172.16.63.3, mask: 255.255.0.0, gw: 172.16.63.1[0m D (123079) event: running post IP_EVENT:0 with handler 0x42007f2e and context 0x3fca5618 on loop 0x3fc9c5c8[0m [0;32mI (123089) wifi station: got ip:172.16.63.3[0m 日志如上,实在没看明白什么原因,麻烦看懂的人指教一下怎么解决,谢谢 |
1个回答
根据您提供的信息,您的ESP32-C3设备在连接WiFi后每隔两分钟就会断开并重连。为了解决这个问题,我们可以尝试以下几个步骤:
1. 检查WiFi信号强度:确保您的设备在WiFi信号覆盖范围内,信号强度足够稳定。如果信号不稳定,可能导致设备频繁断开和重连。 2. 更新ESP-IDF版本:您当前使用的ESP-IDF版本是v5.1.1-dirty,这可能是一个不稳定的版本。建议您尝试更新到最新的稳定版本,例如v5.1.2或更高版本。 3. 检查电源稳定性:确保您的ESP32-C3设备电源稳定,因为电源波动可能导致设备重启或断开连接。 4. 检查代码中的WiFi连接设置:在您的代码中,检查WiFi连接的配置,确保没有设置错误的参数,如超时时间、重连策略等。 5. 使用keep-alive机制:在您的代码中,可以实现一个keep-alive机制,定期发送数据包以保持连接。这可以防止因长时间无数据传输而导致的断开连接。 6. 检查路由器设置:检查您的路由器设置,确保没有设置错误的参数,如连接超时时间、最大连接数等。此外,尝试更新路由器的固件,以解决可能的兼容性问题。 7. 检查ESP32-C3硬件:如果以上方法都无法解决问题,可能是ESP32-C3硬件存在问题。您可以尝试更换一个设备进行测试。 通过以上步骤,您应该能够找到导致ESP32-C3设备频繁断开连接的原因,并采取相应的措施解决问题。 |
只有小组成员才能发言,加入小组>>
945 浏览 0 评论
1672 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1330 浏览 1 评论
1233 浏览 1 评论
5021 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1253浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
927浏览 3评论
2338浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2527浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1052浏览 2评论
/9
GMT+8, 2025-12-2 07:18 , Processed in 0.645190 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
667
