硬件:ESP32-WROOM-32
idf:4.5. 使用freertos历程配置 会重启,报错 0x8 (TG1WDT_SYS_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) 代码如下Code: Select all /* FreeRTOS Example*/#include "freertos/FreeRTOS.h"#include "freertos/task.h"#include "freertos/semphr.h"#include "freertos/event_groups.h"#include "freertos/queue.h"#include "esp_task_wdt.h" #include "esp_err.h"#include "esp_log.h"#include "nvs_flash.h"#include #include #include void test_task(void *pvParam){ int num = 0; while (1) { num++; num *= 1; if (num > 1000000 && ((num / 10) % 2) == 1) { ESP_LOGI("test_task FUN", "doing : %d", num++); num = 0; } } }void Main_Init(void);void Build_task(void);void app_main(void){ Main_Init(); Build_task(); char *temp_array; temp_array = malloc(300); while (1) { vTaskList(temp_array); printf("-------------------------------------------------->n"); printf(" Name state Priority task numn"); printf("%s n",temp_array); vTaskDelay(pdMS_TO_tiCKS(3000)); }}TaskHandle_t test_taskhanlde;void Build_task(void){ test_taskhanlde = NULL; xTaskCreate(test_task, "test task", 4096, NULL, 1, &test_taskhanlde);}void Main_Init(void){ // Allow other core to finish initialization vTaskDelay(pdMS_TO_TICKS(100));} 出现下面的报错Code: Select all I (5060) test_task FUN: doing : 1000010E (10492) task_wdt: Task watchdog got triggered. The following tasks did not reset the watchdog in time:E (10492) task_wdt: - IDLE (CPU 1)E (10492) task_wdt: Tasks currently running:E (10492) task_wdt: CPU 0: IDLEE (10492) task_wdt: CPU 1: test taskE (10492) task_wdt: Aborting. 大佬帮忙看看,感谢! |
1个回答
好像知道了,是test task造成的,他一直在while,没有vtaskdelay来释放,一直进不到idle去喂狗,所以被重启了,解决方法是吧这个任务放到core 1,然后把core 1的看门狗关掉,就正常了。
只有小组成员才能发言,加入小组>>
944 浏览 0 评论
1671 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1330 浏览 1 评论
1233 浏览 1 评论
5015 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1252浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
927浏览 3评论
2333浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2526浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1051浏览 2评论
/9
GMT+8, 2025-12-2 00:39 , Processed in 0.784414 second(s), Total 69, Slave 53 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
502
