Collecting gevent<2.0,>=1.2.2 (from gdbgui==0.13.2.0->-r /home/qinge/esp/esp-idf/requirements.txt (line 26))
Using cached gevent-1.5.0.tar.gz (5.3 MB) Installing build dependencies: started Installing build dependencies: still running... Installing build dependencies: finished with status 'done' Getting requirements to build wheel: started Getting requirements to build wheel: finished with status 'error' Installing Python packages from /home/qinge/esp/esp-idf/requirements.txt error: subprocess-exited-with-error × Getting requirements to build wheel did not run successfully. │ exit code: 1 ╰─> [315 lines of output] Compiling src/gevent/resolver/cares.pyx because it changed. [1/1] Cythonizing src/gevent/resolver/cares.pyx performance hint: src/gevent/libev/corecext.pyx:1291:5: Exception check on '_syserr_cb' will always require the GIL to be acquired. Possible solutions: 1. Declare '_syserr_cb' as 'noexcept' if you control the definition and you're sure you don't want the function to raise exceptions. 2. Use an 'int' return type on '_syserr_cb' to allow an error code to be returned. warning: src/gevent/libev/corecext.pyx:1288:0: Global name __SYSERR_CALLBACK matched from within class scope in contradiction to to Python 'class private name' rules. This may change in a future release. warning: src/gevent/libev/corecext.pyx:1288:0: Global name __SYSERR_CALLBACK matched from within class scope in contradiction to to Python 'class private name' rules. This may change in a future release. warning: src/gevent/libev/corecext.pyx:1288:0: Global name __SYSERR_CALLBACK matched from within class scope in contradiction to to Python 'class private name' rules. This may change in a future release. warning: src/gevent/libev/corecext.pyx:1288:0: Global name __SYSERR_CALLBACK matched from within class scope in contradiction to to Python 'class private name' rules. This may change in a future release. Error compiling Cython file: ------------------------------------------------------------ ... if events & ~(libev.EV__IOFDSET | libev.EV_READ | libev.EV_WRITE): raise ValueError('illegal event mask: %r' % events) # All the vfd_functions are no-ops on POSIX cdef int vfd = libev.vfd_open(fd) libev.ev_io_init(&self._watcher, gevent_callback_io, vfd, events) self.__watcher = &self._watcher ^ ------------------------------------------------------------ src/gevent/libev/corecext.pyx:1027:25: Cannot convert 'ev_watcher *' to Python object Error compiling Cython file: ------------------------------------------------------------ ... raise ValueError('illegal event mask: %r' % events) # All the vfd_functions are no-ops on POSIX cdef int vfd = libev.vfd_open(fd) libev.ev_io_init(&self._watcher, gevent_callback_io, vfd, events) self.__watcher = &self._watcher self.__ss = &io_ss ^ ------------------------------------------------------------ src/gevent/libev/corecext.pyx:1028:20: Cannot convert 'start_and_stop *' to Python object |
1个回答
在WSL2下,VSCode插件安装失败可能有多种原因。根据您提供的错误信息,这个问题似乎与Python包的安装有关。以下是一些建议来解决这个问题:
1. **检查Python环境**:确保您的Python环境已正确设置。在WSL2中,您可能需要使用Linux版本的Python。 2. **更新pip**:确保您的pip是最新版本。在终端中运行以下命令来更新pip: ``` python3 -m pip install --upgrade pip ``` 3. **检查依赖关系**:错误信息显示,它正在尝试安装gevent包。确保您的系统中已安装所有必要的依赖项。您可以尝试手动安装gevent: ``` python3 -m pip install gevent==1.5.0 ``` 4. **检查网络连接**:有时,网络问题可能导致安装失败。确保您的网络连接稳定。 5. **清理缓存**:清理pip缓存可能有助于解决安装问题。运行以下命令来清理缓存: ``` python3 -m pip cache purge ``` 6. **检查权限**:确保您有足够的权限来安装插件。如果您在安装过程中遇到权限问题,请尝试使用`sudo`命令。 7. **检查VSCode设置**:检查您的VSCode设置,确保Python解释器和环境变量已正确配置。 8. **查看日志**:查看VSCode的输出日志,以获取有关安装失败的更多详细信息。您可以在VSCode的“输出”面板中找到这些日志。 9. **尝试重新安装**:在解决了上述问题后,尝试重新安装插件。 10. **寻求帮助**:如果问题仍然存在,您可以在VSCode的GitHub仓库或相关社区论坛上寻求帮助。 请尝试这些建议,并根据需要调整您的环境设置。希望这些建议能帮助您解决问题。 |
只有小组成员才能发言,加入小组>>
474浏览 6评论
397浏览 5评论
有没有办法在不使用混杂模式的情况下实现Wifi驱动程序接收缓冲区访问中断呢?
377浏览 5评论
383浏览 4评论
354浏览 4评论
GMT+8, 2024-9-28 13:42 , Processed in 0.797402 second(s), Total 83, Slave 65 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
