电子发烧友论坛|
单片机:STM8S105K4T6
编程环境:STVD+COSMIC 使用引脚:PB0 实际现象:外接0v,转换结果0x0000 (好像小于1.6v都是0);外接1.6V,转换结果0x03ff ;外接3.3v,转换结果0x037f (好像大于2v都是0x03ff) ; 问题代码如下: main.c文件 /*----------------------------------------------------------------------------*/ /* @Name : main.c */ /* @Brief : */ /* @Include: stm8s105k.h */ /* stm8s105k_led.h */ /*----------------------------------------------------------------------------*/ //============================================================================// /* include-------------------------------------------------------------------*/ #include "stm8s105k.h" #include "stm8s105k_led.h" /* define--------------------------------------------------------------------*/ /* extern--------------------------------------------------------------------*/ extern uint8_t ADC1_CONVER_FLAG; /* main()--------------------------------------------------------------------*/ void main() { /* $ 局部变量定义------------------------------------------------------------*/ uint8_t i; //open global interrupt enableInterrupts(); //direction runing is ok LED_Init;LED_ON; /* $ ADC1初始化部分----------------------------------------------------------*/ //1.引脚模式:浮空输入 PB_DDR = (uint8_t)~(1<<0); PB_CR1 = (uint8_t)~(1<<0); PB_CR2 = (uint8_t)~(1<<0); //2.打开ADC时钟 CLK_PCKENR2 |= (uint8_t)(1<<3); //3.选择ADC转换通道 ADC_CSR = 0xF0;//通道0 ADC_CSR |= 0x00; //4.关闭使用通道的斯密特触发器 ADC_TDRL |= (uint8_t)(1<<0); //5.设置转换模式:带缓存的连续模式 ADC_CR1 |= (uint8_t)(1<<1);//使能连续转换 //(缓存满时,置位EOC,然后自动开始下一轮转换,所以进中断的第一件事是清CONT) ADC_CR3 |= (uint8_t)(1<<7);//使用缓存 //6.关闭使用通道的模拟看门狗功能 ADC_AWCRL = (uint8_t)~(1<<0); //7.禁止模拟看门狗中断 ADC_CSR = (uint8_t)~(1<<4);//写“0”禁止 //8.清除模拟看门狗中断标志 ADC_CSR = (uint8_t)~(1<<6); //9.禁止外部信号触发转换 ADC_CR2 = (uint8_t)~(1<<6); //10.设置F_ADC频率:F_master/8 ADC_CR1 = 0x8F; ADC_CR1 |= (uint8_t)0x40; //11.使能转换结束中断 ADC_CSR |= (uint8_t)(1<<5); //12.清除转换结束标志 ADC_CSR = (uint8_t)~(1<<7); //13.设置转换结果数据对齐方式:右对齐 ADC_CR2 |= (1<<3);//先读低,再读高 //14.将ADC从低功耗模式中唤醒 ADC_CR1 |= (uint8_t)(1<<0); //15.等待ADC供电稳定(最小7us) for(i=0;i<10;i++);//大概20us //16.开始转换 ADC_CR1 |= (uint8_t)(1<<0); LED_OFF; while(1) { if(ADC1_CONVER_FLAG==1) LED_ON; } } stm8_interrupt_vector.c文件 /*----------------------------------------------------------------------------*/ /* @Name : stm8_interrupt_vector.c */ /* @Brief : */ /* @Include: stm8s105k.h */ /* stm8s105k_led.h */ /*----------------------------------------------------------------------------*/ //============================================================================// /* include-------------------------------------------------------------------*/ #include "stm8s105k.h" #include "stm8s105k_led.h" /* $ 别名定义----------------------------------------------------------------*/ typedef void @far (*interrupt_handler_t)(void); /* $ 结构体定义--------------------------------------------------------------*/ struct interrupt_vector { unsigned char interrupt_instruction; interrupt_handler_t interrupt_handler; }; /* $ 全局变量----------------------------------------------------------------*/ uint16_t adc1_valtage[10]={'�'}; /* $ 运行标志----------------------------------------------------------------*/ uint8_t ADC1_CONVER_FLAG = 0; /* $ 中断函数----------------------------------------------------------------*/ @far @interrupt void NonHandledInterrupt (void) { /* in order to detect unexpected events during development, it is recommended to set a breakpoint on the following instruction */ return; } @far @interrupt void ISP_ADC1 (void) { uint8_t i; uint8_t *pDBx = ADC_DB0RH; uint8_t temp_low,temp_high; uint16_t temp; ADC_CR1 = (uint8_t)~(1<<1);//关闭连续转换 if(!(ADC_CR3 (uint8_t)(1<<6)))//数据没有溢出,则将结果读出 {//数据右对齐,先读低,后读高 for(i=0;i<10;i++) { temp_low = *(pDBx + 1) ; temp_high = *pDBx ; temp = ((uint16_t)temp_high<<8)+(uint16_t)temp_low; adc1_valtage[i] = temp; pDBx += 2; } adc1_valtage[10] = '�'; ADC1_CONVER_FLAG = 1; } else //数据溢出,则从新转换一次 { ADC_CR3 = (uint8_t)~(1<<6);//清溢出标志 ADC_CR1 |= (uint8_t) (1<<1);//使能连续转换 ADC_CR1 |= (uint8_t) (1<<0);//开始转换 LED_OFF; } ADC_CSR = (uint8_t)~(1<<7);//清转换结束标志 return; } extern void _stext(); /* startup routine */ struct interrupt_vector const _vectab[] = { {0x82, (interrupt_handler_t)_stext}, /* reset */ {0x82, NonHandledInterrupt}, /* trap */ {0x82, NonHandledInterrupt}, /* irq0 */ {0x82, NonHandledInterrupt}, /* irq1 */ {0x82, NonHandledInterrupt}, /* irq2 */ {0x82, NonHandledInterrupt}, /* irq3 */ {0x82, NonHandledInterrupt}, /* irq4 */ {0x82, NonHandledInterrupt}, /* irq5 */ {0x82, NonHandledInterrupt}, /* irq6 */ {0x82, NonHandledInterrupt}, /* irq7 */ {0x82, NonHandledInterrupt}, /* irq8 */ {0x82, NonHandledInterrupt}, /* irq9 */ {0x82, NonHandledInterrupt}, /* irq10 */ {0x82, NonHandledInterrupt}, /* irq11 */ {0x82, NonHandledInterrupt}, /* irq12 */ {0x82, NonHandledInterrupt}, /* irq13 */ {0x82, NonHandledInterrupt}, /* irq14 */ {0x82, NonHandledInterrupt}, /* irq15 */ {0x82, NonHandledInterrupt}, /* irq16 */ {0x82, NonHandledInterrupt}, /* irq17 */ {0x82, NonHandledInterrupt}, /* irq18 */ {0x82, NonHandledInterrupt}, /* irq19 */ {0x82, NonHandledInterrupt}, /* irq20 */ {0x82, NonHandledInterrupt}, /* irq21 */ {0x82, ISP_ADC1}, /* irq22 */ {0x82, NonHandledInterrupt}, /* irq23 */ {0x82, NonHandledInterrupt}, /* irq24 */ {0x82, NonHandledInterrupt}, /* irq25 */ {0x82, NonHandledInterrupt}, /* irq26 */ {0x82, NonHandledInterrupt}, /* irq27 */ {0x82, NonHandledInterrupt}, /* irq28 */ {0x82, NonHandledInterrupt}, /* irq29 */ }; stm8s105k_led.h文件 /*----------------------------------------------------------------------------*/ /* @Name : stm8s105k_led.h */ /* @Brief : */ /* @Include: stm8s105k.h */ /*----------------------------------------------------------------------------*/ //============================================================================// #ifndef __STM8S105K_LED_H #define __STM8S105K_LED_H /* include-------------------------------------------------------------------*/ #include "stm8s105k.h" /* define--------------------------------------------------------------------*/ #define LED_Init PE_DDR |= (uint8_t) (1< |
1个回答
STM8S105K4T6是一款8位单片机,使用ADC转换时出现异常的原因可能有以下几点:
1. 参考电压设置不正确:STM8S105K4T6的ADC转换结果与参考电压有关,如果参考电压设置不正确,可能导致转换结果异常。 2. 引脚配置问题:确保PB0引脚已正确配置为ADC输入。 3. 外部电路问题:检查外部电路连接是否正确,包括输入电压、电阻等。 4. 程序问题:检查程序中的ADC配置和转换逻辑是否正确。 针对您提供的代码和现象,以下是一些建议: 1. 检查参考电压设置:确保ADC的参考电压设置正确。STM8S105K4T6的ADC参考电压可以是Vref(AVDD),也可以是外部参考电压。根据您的描述,可能是参考电压设置不正确导致转换结果异常。 2. 检查引脚配置:确保PB0引脚已正确配置为ADC输入。在初始化代码中,应包含类似以下配置: ```c ADC1_ChannelConfig(ADC1_CHANNEL_8, ADC1_RANK_1, ADC1_SAMPLETIME_28_5); ``` 3. 检查外部电路:确保外部电路连接正确,输入电压、电阻等无误。 4. 检查程序逻辑:检查您的程序中的ADC配置和转换逻辑是否正确。特别是ADC通道选择、时钟配置、触发方式等。 5. 使用STM8S105K4T6的官方库函数:STVD提供了STM8S105K4T6的官方库函数,使用这些库函数可以简化编程并减少错误。 6. 调试和测试:使用STVD的仿真功能,逐步调试和测试您的程序,以找到问题所在。 如果以上建议仍然无法解决问题,建议您查阅STM8S105K4T6的数据手册和参考例程,以获取更详细的信息和解决方案。 |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
4140 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
3228 浏览 1 评论
2753 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
2181 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
14984 浏览 2 评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
3092浏览 4评论
stm32f4下spi+dma读取数据不对是什么原因导致的?
1898浏览 3评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
2070浏览 3评论
1981浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
2171浏览 3评论
/9
GMT+8, 2025-12-2 23:49 , Processed in 0.606749 second(s), Total 75, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1667
