在 开发板目录: STM32Cube_FW_L0_V1.8.0ProjectsSTM32L053C8-DiscoveryExamplesLP tiM路径的这个例程:没有做任何修改,但是下载进开发板,程序不能正常进行, LPTIM唤醒定时器没有进入中断,本来进入中断LED灯会亮起来,然后唤醒STOP模式。但是开发板灯没有亮,中断没进去。难道开发板的代码也这么补严谨?
- * @file LPTIM/LPTIM_Timeout/Src/main.c
- * @author MCD Application Team
- * @version V1.8.0
- * @date 25-November-2016
- * @brief This example describes how to implement a low power timeout to
- * wake-up the system using the LPTIMER, through the STM32L0xx HAL API.
- * @attention
- * © COPYRIGHT(c) 2016 STMicroelectronics
- * Redistribution and use in source and binary forms, with or without modification,
- * are permitted provided that the following conditions are met:
- * 1. Redistributions of source code must retain the above copyright notice,
- * this list of conditions and the following disclaimer.
- * 2. Redistributions in binary form must reproduce the above copyright notice,
- * this list of conditions and the following disclaimer in the documentation
- * and/or other materials provided with the distribution.
- * 3. Neither the name of STMicroelectronics nor the names of its contributors
- * may be used to endorse or promote products derived from this software
- * without specific prior written permission.
- * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
- * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
- * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
- * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
- * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
- * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
- * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
- * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
- * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
- * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
- /* Includes ------------------------------------------------------------------*/
- #include "main.h"
- /** @addtogroup STM32L0xx_HAL_Examples
- /** @addtogroup LPTIM_Timeout
- /* Private typedef -----------------------------------------------------------*/
- /* Private define ------------------------------------------------------------*/
- /* Set the Maximum value of the counter (Auto-Reload) that defines the Period */
- #define Period (uint32_t) 65535
- /* Set the Timeout value */
- #define Timeout (uint32_t) (32768 - 1)
- /* Private macro -------------------------------------------------------------*/
- /* Private variables ---------------------------------------------------------*/
- /* LPTIM handle declaration */
- LPTIM_HandleTypeDef LptimHandle;
- /* Clocks structure declaration */
- RCC_PeriphCLKInitTypeDef RCC_PeriphCLKInitStruct;
- /* Private function prototypes -----------------------------------------------*/
- static void SystemClock_Config(void);
- static void LSE_ClockEnable(void);
- static void Error_Handler(void);
- /* Private functions ---------------------------------------------------------*/
- static void SystemClockConfig_STOP(void)
- RCC_ClkInitTypeDef RCC_ClkInitStruct;
- RCC_OscInitTypeDef RCC_OscInitStruct;
- /* Enable Power Control clock */
- __HAL_RCC_PWR_CLK_ENABLE();
- /* The voltage scaling allows optimizing the power consumption when the device is
- clocked below the maximum system frequency, to update the voltage scaling value
- regarding system frequency refer to product datasheet. */
- __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
- /* Get the Oscillators configuration according to the internal RCC registers */
- HAL_RCC_GetOscConfig( RCC_OscInitStruct);
- /* After wake-up from STOP reconfigure the system clock: Enable HSI and PLL */
- RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
- RCC_OscInitStruct.HSEState = RCC_HSE_OFF;
- RCC_OscInitStruct.HSIState = RCC_HSI_ON;
- RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
- RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI;
- RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL4;
- RCC_OscInitStruct.PLL.PLLDIV = RCC_PLL_DIV2;
- RCC_OscInitStruct.HSICalibrationValue = 0x10;
- if(HAL_RCC_OscConfig( RCC_OscInitStruct) != HAL_OK)
- Error_Handler();
- /* Select PLL as system clock source and configure the HCLK, PCLK1 and PCLK2
- clocks dividers */
- RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_SYSCLK;
- RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
- if(HAL_RCC_ClockConfig( RCC_ClkInitStruct, FLASH_LATENCY_1) != HAL_OK)
- Error_Handler();
- * @brief Main program
- * @param None
- * @retval None
- int main(void)
- /* This sample code shows how to use STM32L0xx LPTIM HAL API to realize a
- timeout function to wakeup the system from Stop mode.
- To proceed, 4 steps are required:
- /* STM32L0xx HAL library initialization:
- - Configure the Flash prefetch, Flash preread and Buffer caches
- - Systick timer is configured by default as source of time base, but user
- can eventually implement his proper time base source (a general purpose
- timer for example or other time source), keeping in mind that Time base
- duration should be kept 1ms since PPP_TIMEOUT_VALUEs are defined and
- handled in milliseconds basis.
- - Low Level Initialization
- HAL_Init();
- /* Configure the System clock to have a frequency of 2 MHz (Up to 32MHZ possible) */
- SystemClock_Config();
- /* Enable the LSE source */
- LSE_ClockEnable();
- /* Initialize LED2 */
- BSP_LED_Init(LED2);
- /* ### - 1 - Re-target the LSE to Clock the LPTIM Counter ################# */
- /* Select the LSE clock as LPTIM peripheral clock */
- RCC_PeriphCLKInitStruct.PeriphClockSelection = RCC_PERIPHCLK_LPTIM1;
- RCC_PeriphCLKInitStruct.LptimClockSelection = RCC_LPTIM1CLKSOURCE_LSI;
- HAL_RCCEx_PeriphCLKConfig( RCC_PeriphCLKInitStruct);
- /* ### - 2 - Initialize LPTIM peripheral ################################## */
- * Instance = LPTIM1.
- * Clock Source = APB or LowPowerOSCillator (in this example LSE is
- * already selected from the RCC level).
- * Counter source = Internal event.
- * Clock prescaler = 1 (No division).
- * Counter Trigger = Trigger1: PC3 or PB6 (PC3 in this example).
- * Active Edge = Rising edge.
- LptimHandle.Instance = LPTIM1;
- LptimHandle.Init.Clock.Source = LPTIM_CLOCKSOURCE_APBCLOCK_LPOSC;
- LptimHandle.Init.Clock.Prescaler = LPTIM_PRESCALER_DIV1;
- LptimHandle.Init.Trigger.Source = LPTIM_TRIGSOURCE_0;
- LptimHandle.Init.Trigger.ActiveEdge = LPTIM_ACTIVEEDGE_RISING;
- LptimHandle.Init.CounterSource = LPTIM_COUNTERSOURCE_INTERNAL;
- /* Initialize LPTIM peripheral according to the passed parameters */
- if (HAL_LPTIM_Init( LptimHandle) != HAL_OK)
- Error_Handler();
- /* ### - 3 - Start the Timeout function in interrupt mode ################# */
- * Period = 65535
- * Pulse = 32767
- * According to this configuration (LPTIMER clocked by LSE compare = 32767,
- * the Timeout period = (compare + 1)/LSE_Frequency = 1s
- if (HAL_LPTIM_TimeOut_Start_IT( LptimHandle, Period, Timeout) != HAL_OK)
- Error_Handler();
- /* ### - 4 - Enter in Stop mode ########################################### */
- HAL_PWR_EnterSTOPMode(PWR_LOWPOWERREGULATOR_ON, PWR_STOPENTRY_WFI);
- /* Infinite Loop */
- // while (1)
- * @brief Compare match callback in non blocking mode
- * @param hlptim : LPTIM handle
- * @retval None
- void HAL_LPTIM_CompareMatchCallback(LPTIM_HandleTypeDef *hlptim)
- /* Timeout was reached, turn on LED2 */
- BSP_LED_On(LED2);
- * @brief System Clock Configuration
- * The system Clock is configured as follow :
- * System Clock source = MSI
- * SYSCLK(Hz) = 2000000
- * HCLK(Hz) = 2000000
- * AHB Prescaler = 1
- * APB1 Prescaler = 1
- * APB2 Prescaler = 1
- * Flash Latency(WS) = 0
- * Main regulator output voltage = Scale3 mode
- * @param None
- * @retval None
- __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE3);
- /* Enable MSI Oscillator */
- RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_MSI;
- RCC_OscInitStruct.MSIState = RCC_MSI_ON;
- RCC_OscInitStruct.MSIClockRange = RCC_MSIRANGE_5;
- RCC_OscInitStruct.MSICalibrationValue=0x00;
- RCC_OscInitStruct.PLL.PLLState = RCC_PLL_NONE;
- /* Initialization Error */
- Error_Handler();
- /* Select MSI as system clock source and configure the HCLK, PCLK1 and PCLK2
- RCC_ClkInitStruct.ClockType = (RCC_CLOCKTYPE_SYSCLK | RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2);
- RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_MSI;
- RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
- RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
- RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
- if(HAL_RCC_ClockConfig( RCC_ClkInitStruct, FLASH_LATENCY_0) != HAL_OK)
- Error_Handler();
- * @brief Enable External Low Speed Clock (LSE)
- * @param None
- * @retval None
- /* Enable LSE clock */
- RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_LSE;
- RCC_OscInitStruct.LSEState = RCC_LSE_ON;
- HAL_RCC_OscConfig( RCC_OscInitStruct);
- * @brief This function is executed in case of error occurrence.
- * @param None
- * @retval None
- /* Infinite loop */
- while(1)
- #ifdef USE_FULL_ASSERT
- * @brief Reports the name of the source file and the source line number
- * where the assert_param error has occurred.
- * @param file: pointer to the source file name
- * @param line: assert_param error line source number
- * @retval None
- void assert_failed(uint8_t* file, uint32_t line)
- /* User can add his own implementation to report the file name and line number,
- ex: printf("Wrong parameters value: file %s on line %drn", file, line) */
- while (1)
- #endif
- /************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
1个回答
