求教,在做STM32f407 usb hid开发,根据官方例子修改而来,使用的是HS接口,FS模式,PC可以成功识别usb hid设备。现在通过Bus Hound给设备发送数据,stm32可以收到;但是通过调用USBD_CUSTOM_HID_SendReport()函数来向PC发送数据,Bus Hound始终收不到发送的数据,调试也不能进入USBD_CUSTOM_HID_DataIn()函数。
请问这是什么原因呢? 我的各种设备描述符的配置如下: (1)设备描述符 /* USB Standard Device Descriptor */ __ALIGN_BEGIN uint8_t USBD_DeviceDesc[USB_SIZ_DEVICE_DESC] __ALIGN_END = { 0x12, /*bLength */ USB_DEVICE_DESCRIPTOR_TYPE, /*bDescriptorType*/ 0x00, /*bcdUSB */ 0x02, 0x00, /*bDeviceClass*/ 0x00, /*bDeviceSubClass*/ 0x00, /*bDeviceProtocol*/ USB_OTG_MAX_EP0_SIZE, /*bMaxPacketSize*/ LOBYTE(USBD_VID), /*idVendor*/ HIBYTE(USBD_VID), /*idVendor*/ LOBYTE(USBD_PID), /*idVendor*/ HIBYTE(USBD_PID), /*idVendor*/ 0x50, /*bcdDevice rel. 2.00*/ 0x10, USBD_IDX_MFC_STR, /*Index of manufacturer string*/ USBD_IDX_PRODUCT_STR, /*Index of product string*/ USBD_IDX_SERIAL_STR, /*Index of serial number string*/ USBD_CFG_MAX_NUM /*bNumConfigurations*/ } ; /* USB_DeviceDescriptor */ (2)配置描述符 /* USB HID device Configuration Descriptor */ __ALIGN_BEGIN static uint8_t USBD_CUSTOM_HID_CfgDesc[USB_CUSTOM_HID_CONFIG_DESC_SIZ] __ALIGN_END = { 0x09, /* bLength: Configuration Descriptor size */ USB_CONFIGURATION_DESCRIPTOR_TYPE, /* bDescriptorType: Configuration */ USB_CUSTOM_HID_CONFIG_DESC_SIZ, /* wTotalLength: Bytes returned */ 0x00, 0x01, /*bNumInterfaces: 1 interface*/ 0x01, /*bConfigurationValue: Configuration value*/ 0x00, /*iConfiguration: Index of string descriptor describing the configuration*/ 0xE0, /*bmAttributes: bus powered and Support Remote Wake-up */ 0x32, /*MaxPower 100 mA: this current is used for detecting Vbus*/ /************** Descriptor of Custom HID interface ****************/ /* 09 */ 0x09, /*bLength: Interface Descriptor size*/ USB_INTERFACE_DESCRIPTOR_TYPE,/*bDescriptorType: Interface descriptor type*/ 0x00, /*bInterfaceNumber: Number of Interface*/ 0x00, /*bAlternateSetting: Alternate setting*/ 0x02, /*bNumEndpoints*/ 0x03, /*bInterfaceClass: HID*/ 0x00, /*bInterfaceSubClass : 1=BOOT, 0=no boot*/ 0x00, /*nInterfaceProtocol : 0=none, 1=keyboard, 2=mouse*/ 0, /*iInterface: Index of string descriptor*/ /******************** Descriptor of Custom HID ********************/ /* 18 */ 0x09, /*bLength: HID Descriptor size*/ CUSTOM_HID_DESCRIPTOR_TYPE, /*bDescriptorType: HID*/ 0x11, /*bcdHID: HID Class Spec release number*/ 0x01, 0x00, /*bCountryCode: Hardware target country*/ 0x01, /*bNumDescriptors: Number of HID class descriptors to follow*/ 0x22, /*bDescriptorType*/ USBD_CUSTOM_HID_REPORT_DESC_SIZE,/*wItemLength: Total length of Report descriptor*/ 0x00, /******************** Descriptor of Custom HID endpoints ***********/ /* 27 */ 0x07, /* bLength: Endpoint Descriptor size */ USB_ENDPOINT_DESCRIPTOR_TYPE, /* bDescriptorType: */ HID_IN_EP, /* bEndpointAddress: Endpoint Address (IN) */ 0x03, /* bmAttributes: Interrupt endpoint */ HID_IN_PACKET, /* wMaxPacketSize: 2 Bytes max */ 0x00, 0x20, /* bInterval: Polling Interval (32 ms) */ /* 34 */ 0x07, /* bLength: Endpoint Descriptor size */ USB_ENDPOINT_DESCRIPTOR_TYPE, /* bDescriptorType: */ /* Endpoint descriptor type */ HID_OUT_EP, /* bEndpointAddress: */ /* Endpoint Address (OUT) */ 0x03, /* bmAttributes: Interrupt endpoint */ HID_OUT_PACKET, /* wMaxPacketSize: 2 Bytes max */ 0x00, 0x20, /* bInterval: Polling Interval (20 ms) */ /* 41 */ } ; (3)报告描述符 __ALIGN_BEGIN static uint8_t CustomHID_ReportDesc[USBD_CUSTOM_HID_REPORT_DESC_SIZE] __ALIGN_END = { 0x05, 0x8c, /* USAGE_PAGE (ST page) */ 0x09, 0x01, /* USAGE (Demo Kit) */ 0xa1, 0x01, /* COLLECTION (Application) */ /* 5 */ // The Input report 0x09,0x03, // USAGE ID - Vendor defined 0x15,0x00, // LOGICAL_MINIMUM (0) 0x26,0x00, 0xFF, // LOGICAL_MAXIMUM (255) 0x75,0x08, // REPORT_SIZE (8bit) 0x95,0x40, // REPORT_COUNT (64Byte) 0x81,0x02, // INPUT (Data,Var,Abs) /* 18 */ // The Output report 0x09,0x04, // USAGE ID - Vendor defined 0x15,0x00, // LOGICAL_MINIMUM (0) 0x26,0x00,0xFF, // LOGICAL_MAXIMUM (255) 0x75,0x08, // REPORT_SIZE (8bit) 0x95,0x40, // REPORT_COUNT (64Byte) 0x91,0x02, // OUTPUT (Data,Var,Abs) /* 31 */ 0xc0 /* END_COLLECTION */ }; |
1个回答
根据您提供的信息,您在使用STM32F407进行USB HID开发时遇到了一些问题。您可以通过以下步骤来排查和解决这个问题:
1. 确保您的USB HID设备描述符配置正确。请检查您的设备描述符,确保它与官方示例中的描述符相匹配。特别是,检查设备类、子类和协议字段,确保它们正确地设置了HID类。 2. 检查您的端点配置。确保您正确地配置了IN端点,以便STM32F407可以通过该端点向PC发送数据。请检查您的USBD_CUSTOM_HID_SendReport()函数,确保它正确地使用了IN端点。 3. 检查您的USB堆栈。确保您使用的USB堆栈支持HID类,并正确地处理了HID类特定的请求。如果您使用的是官方示例中的堆栈,请确保它与您的STM32F407硬件兼容。 4. 检查您的PC端设置。确保您的PC正确地识别了USB HID设备,并正确地安装了相应的驱动程序。您可以尝试在不同的电脑上测试,以排除是PC端的问题。 5. 使用USB协议分析工具。使用像Bus Hound这样的USB协议分析工具可以帮助您检查USB通信过程中的问题。请确保您的分析工具正确地捕获了USB数据包,并检查数据包的内容是否正确。 6. 调试和日志记录。在您的STM32F407固件中添加调试信息和日志记录,以便在出现问题时能够快速定位问题所在。您可以使用printf()函数或其他调试工具来输出调试信息。 7. 检查时钟配置。确保您的STM32F407的时钟配置正确,以便USB接口能够正常工作。特别是,检查与USB相关的时钟设置,如PLL、AHB、APB等。 8. 更新固件和硬件。如果您使用的是较旧的固件或硬件,请尝试更新到最新版本,以解决可能存在的已知问题。 通过以上步骤,您应该能够找到问题的原因并解决它。如果问题仍然存在,请提供更多的信息,以便我们能够更好地帮助您。 |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
1816 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
1631 浏览 1 评论
1098 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
739 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
1691 浏览 2 评论
1950浏览 9评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
753浏览 4评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
585浏览 3评论
604浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
568浏览 3评论
GMT+8, 2024-12-29 22:18 , Processed in 0.728963 second(s), Total 47, Slave 39 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
