创建了一个空任务,while函数只有一个自加计数。但是仿真不起,应该是芯片没有运行起来,不知道是不是时钟配置问题。
因为没有焊接晶振,所以暂时使用内部晶振。请帮忙看看什么问题。仿真一直提示:CPU could not be halted void SystemClock_Config(void) { RCC_OscInitTypeDef RCC_OscInitStruct; RCC_ClkInitTypeDef RCC_ClkInitStruct; RCC_PeriphCLKInitTypeDef PeriphClkInit; RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI; RCC_OscInitStruct.HSIState = RCC_HSI_ON; RCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT; RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON; RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI_DIV2; RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL16; if (HAL_RCC_OscConfig( RCC_OscInitStruct) != HAL_OK) { Error_Handler(); } RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2; RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK; RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1; RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2; RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1; if (HAL_RCC_ClockConfig( RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK) { Error_Handler(); } } |
1个回答
从您提供的信息来看,没有焊接晶振的情况下使用内部晶振,可能是产生问题的原因之一。在您的代码中,并没有找到对时钟配置的具体代码,因此无法确定是否配置正确。下面是一个示例的时钟配置代码供您参考:
```c void SystemClock_Config(void) { RCC_OscInitTypeDef RCC_OscInitStruct; RCC_ClkInitTypeDef RCC_ClkInitStruct; // Configure the oscillator type as HSI RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI; RCC_OscInitStruct.HSIState = RCC_HSI_ON; RCC_OscInitStruct.PLL.PLLState = RCC_PLL_NONE; if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK) { while (1); } // Configure the SysTick timer to generate interrupt every 1ms RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK; RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_HSI; RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1; RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1; RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1; if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0) != HAL_OK) { while (1); } // Configure the SysTick timer HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq() / 1000); // Configure the SysTick timer interrupt HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK); // Enable the SysTick timer HAL_SYSTICK_EnableInterrupt(); } ``` 您可以尝试使用该代码来配置时钟,并确保在main函数中调用SystemClock_Config来设置系统时钟。如果还是无法运行,请检查硬件连接和供电等其他问题。请注意,这只是一个简单的示例代码,您可能需要根据实际情况进行调整。希望对您有所帮助。 |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
1678 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
1580 浏览 1 评论
1012 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
703 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
1626 浏览 2 评论
1892浏览 9评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
673浏览 4评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
537浏览 3评论
556浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
524浏览 3评论
GMT+8, 2024-12-3 00:17 , Processed in 0.813666 second(s), Total 83, Slave 65 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
