芯片:STM32F051K8TX
外部晶振:16Mhz
使用串口:USART2,中断发送接收
使用STM32Cube 生成 STM32F051K8TX芯片的 工程文件,发送串口数据,串口调试工具无法接收到数据。使用在线调试, 总是在这个地方就返回 (huart->gState == HAL_UART_STATE_READY),一直找不到原因,请帮忙查看什么原因,谢谢。
使用一个LED做指示,可以正常工作, 生成的工程,只改了main.C文件,其它文件没有改。
以下为 main.C 文件
- /* USER CODE BEGIN Header */
- * @file : main.c
- * @brief : Main program body
- * @attention
- * © Copyright (c) 2020 STMicroelectronics.
- * All rights reserved.
- * This software component is licensed by ST under BSD 3-Clause license,
- * the "License"; You may not use this file except in compliance with the
- * License. You may obtain a copy of the License at:
- * opensource.org/licenses/BSD-3-Clause
- /* USER CODE END Header */
- /* Includes ------------------------------------------------------------------*/
- #include "main.h"
- #include "usart.h"
- #include "gpio.h"
- /* Private includes ----------------------------------------------------------*/
- /* USER CODE BEGIN Includes */
- #include "stdio.h"
- /* USER CODE END Includes */
- /* Private typedef -----------------------------------------------------------*/
- /* USER CODE BEGIN PTD */
- #ifdef __GNUC_
- #define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
- #else
- #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
- #endif
- //重映射printf的功能
- PUTCHAR_PROTOTYPE
- HAL_UART_Transmit( huart2, (uint8_t *) ch, 1, 0xFFFF);
- return ch;
- /* USER CODE END PTD */
- /* Private define ------------------------------------------------------------*/
- /* USER CODE BEGIN PD */
- /* USER CODE END PD */
- /* Private macro -------------------------------------------------------------*/
- /* USER CODE BEGIN PM */
- /* USER CODE END PM */
- /* Private variables ---------------------------------------------------------*/
- /* USER CODE BEGIN PV */
- /* USER CODE END PV */
- /* Private function prototypes -----------------------------------------------*/
- void SystemClock_Config(void);
- /* USER CODE BEGIN PFP */
- void HAL_UART_RxCpltCallback(UART_HandleTypeDef *huart);
- void HAL_UART_TxCpltCallback(UART_HandleTypeDef *huart);
- /* USER CODE END PFP */
- /* Private user code ---------------------------------------------------------*/
- /* USER CODE BEGIN 0 */
- uint8_t ch = 'k';
- uint8_t kRxBuffer[20];
- uint8_t kTxBuffer[5]={'w','a','n','g','n'};
- /* USER CODE END 0 */
- * @brief The application entry point.
- * @retval int
- int main(void)
- /* USER CODE BEGIN 1 */
- /* USER CODE END 1 */
- /* MCU Configuration--------------------------------------------------------*/
- /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
- HAL_Init();
- /* USER CODE BEGIN Init */
- /* USER CODE END Init */
- /* Configure the system clock */
- SystemClock_Config();
- /* USER CODE BEGIN SysInit */
- /* USER CODE END SysInit */
- /* Initialize all configured peripherals */
- MX_GPIO_Init();
- MX_USART2_UART_Init();
- /* USER CODE BEGIN 2 */
- HAL_UART_Receive_IT( huart2,(uint8_t *)kRxBuffer, 10);
- HAL_GPIO_WritePin(GPIOA,GPIO_PIN_0,GPIO_PIN_RESET);
- /* USER CODE END 2 */
- /* Infinite loop */
- /* USER CODE BEGIN WHILE */
- while (1)
- printf("nr welcome to www.waveshere.com !!!nr");
- HAL_Delay(500);
- //HAL_GPIO_TogglePin(GPIOB,GPIO_PIN_8);
- HAL_UART_Transmit( huart2,(uint8_t *) ch, 1, 0xffff);
- HAL_UART_Transmit_IT( huart2, (uint8_t *)kTxBuffer, 5);
- /* USER CODE END WHILE */
- /* USER CODE BEGIN 3 */
- /* USER CODE END 3 */
- * @brief System Clock Configuration
- * @retval None
- RCC_OscInitTypeDef RCC_OscInitStruct = {0};
- RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
- /** Initializes the CPU, AHB and APB busses clocks
- RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
- RCC_OscInitStruct.HSEState = RCC_HSE_ON;
- RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
- RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
- RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL3;
- RCC_OscInitStruct.PLL.PREDIV = RCC_PREDIV_DIV1;
- if (HAL_RCC_OscConfig( RCC_OscInitStruct) != HAL_OK)
- Error_Handler();
- RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
- |RCC_CLOCKTYPE_PCLK1;
- RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
- RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
- RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
- if (HAL_RCC_ClockConfig( RCC_ClkInitStruct, FLASH_LATENCY_1) != HAL_OK)
- Error_Handler();
- /* USER CODE BEGIN 4 */
- UNUSED(huart);
- HAL_UART_Transmit( huart2,(uint8_t *)kRxBuffer, 10, 0xffff);
- HAL_GPIO_TogglePin(GPIOB,GPIO_PIN_8);
- /* USER CODE END 4 */
- * @brief This function is executed in case of error occurrence.
- * @retval None
- void Error_Handler(void)
- /* USER CODE BEGIN Error_Handler_Debug */
- /* User can add his own implementation to report the HAL error return state */
- /* USER CODE END Error_Handler_Debug */
- #ifdef USE_FULL_ASSERT
- * @brief Reports the name of the source file and the source line number
- * where the assert_param error has occurred.
- * @param file: pointer to the source file name
- * @param line: assert_param error line source number
- * @retval None
- void assert_failed(uint8_t *file, uint32_t line)
- /* USER CODE BEGIN 6 */
- /* User can add his own implementation to report the file name and line number,
- tex: printf("Wrong parameters value: file %s on line %drn", file, line) */
- /* USER CODE END 6 */
- #endif /* USE_FULL_ASSERT */
- /************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
以下是 USART.C文件
- * File Name : USART.c
- * Description : This file provides code for the configuration
- * of the USART instances.
- * @attention
- UART_HandleTypeDef huart2;
- /* USART2 init function */
- void MX_USART2_UART_Init(void)
- huart2.Instance = USART2;
- huart2.Init.BaudRate = 115200;
- huart2.Init.WordLength = UART_WORDLENGTH_8B;
- huart2.Init.StopBits = UART_STOPBITS_1;
- huart2.Init.Parity = UART_PARITY_NONE;
- huart2.Init.Mode = UART_MODE_TX_RX;
- huart2.Init.HwFlowCtl = UART_HWCONTROL_NONE;
- huart2.Init.OverSampling = UART_OVERSAMPLING_16;
- huart2.Init.OneBitSampling = UART_ONE_BIT_SAMPLE_DISABLE;
- huart2.AdvancedInit.AdvFeatureInit = UART_ADVFEATURE_NO_INIT;
- if (HAL_UART_Init( huart2) != HAL_OK)
- Error_Handler();
- void HAL_UART_MspInit(UART_HandleTypeDef* uartHandle)
- GPIO_InitTypeDef GPIO_InitStruct = {0};
- if(uartHandle->Instance==USART2)
- /* USER CODE BEGIN USART2_MspInit 0 */
- /* USER CODE END USART2_MspInit 0 */
- /* USART2 clock enable */
- __HAL_RCC_USART2_CLK_ENABLE();
- __HAL_RCC_GPIOA_CLK_ENABLE();
- /**USART2 GPIO Configuration
- PA2 ------> USART2_TX
- PA3 ------> USART2_RX
- GPIO_InitStruct.Pin = GPIO_PIN_2|GPIO_PIN_3;
- GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
- GPIO_InitStruct.Pull = GPIO_NOPULL;
- GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
- GPIO_InitStruct.Alternate = GPIO_AF1_USART2;
- HAL_GPIO_Init(GPIOA, GPIO_InitStruct);
- /* USART2 interrupt Init */
- HAL_NVIC_SetPriority(USART2_IRQn, 1, 0);
- HAL_NVIC_EnableIRQ(USART2_IRQn);
- /* USER CODE BEGIN USART2_MspInit 1 */
- /* USER CODE END USART2_MspInit 1 */
- void HAL_UART_MspDeInit(UART_HandleTypeDef* uartHandle)
- /* USER CODE BEGIN USART2_MspDeInit 0 */
- /* USER CODE END USART2_MspDeInit 0 */
- /* Peripheral clock disable */
- __HAL_RCC_USART2_CLK_DISABLE();
- HAL_GPIO_DeInit(GPIOA, GPIO_PIN_2|GPIO_PIN_3);
- /* USART2 interrupt Deinit */
- HAL_NVIC_DisableIRQ(USART2_IRQn);
- /* USER CODE BEGIN USART2_MspDeInit 1 */
- /* USER CODE END USART2_MspDeInit 1 */
1个回答
