使用SPI CRC校验功能,DMA发送和接收,如果是CRC 8位校验没有问题,改成16位就发生接收数据错误,跟踪调试是进入到SPI_DMAReceiveCplt函数执行到SPI_WaitFlagStateUntilTimeout判断RXNE标志没有置起,记录为CRC错误
有谁用过这个功能吗?求指点!!! if (hspi->Init.CRCLength == SPI_CRC_LENGTH_16BIT) { if (SPI_WaitFlagStateUntilTimeout(hspi, SPI_FLAG_RXNE, SET, SPI_DEFAULT_TIMEOUT, tickstart) != HAL_OK) { /* Error on the CRC reception */ SET_BIT(hspi->ErrorCode, HAL_SPI_ERROR_CRC); } /* Read 8bit CRC again in case of 16bit CRC in 8bit Data mode */ READ_REG(*(__IO uint8_t *) hspi->Instance->DR); } 代码配置如下:SPI半双工传输 spi主机配置 hspi1.Instance = SPI1; hspi1.Init.Mode = SPI_MODE_MASTER; hspi1.Init.Direction = SPI_DIRECTION_1LINE; hspi1.Init.DataSize = SPI_DATASIZE_8BIT; hspi1.Init.CLKPolarity = SPI_POLARITY_LOW; hspi1.Init.CLKPhase = SPI_PHASE_1EDGE; hspi1.Init.NSS = SPI_NSS_SOFT;//SPI_NSS_HARD_OUTPUT;// hspi1.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_256; hspi1.Init.FirstBit = SPI_FIRSTBIT_MSB; hspi1.Init.TIMode = SPI_TIMODE_DISABLE; hspi1.Init.CRCCalculation = SPI_CRCCALCULATION_ENABLE; hspi1.Init.CRCPolynomial = 7; hspi1.Init.CRCLength = SPI_CRC_LENGTH_16BIT; hspi1.Init.NSSPMode = SPI_NSS_PULSE_DISABLE; if (HAL_SPI_Init( hspi1) != HAL_OK) { Error_Handler(); } spi从机配置 hspi2.Instance = SPI2; hspi2.Init.Mode = SPI_MODE_SLAVE; hspi2.Init.Direction = SPI_DIRECTION_1LINE; hspi2.Init.DataSize = SPI_DATASIZE_8BIT; hspi2.Init.CLKPolarity = SPI_POLARITY_LOW; hspi2.Init.CLKPhase = SPI_PHASE_1EDGE; hspi2.Init.NSS = SPI_NSS_SOFT;//SPI_NSS_HARD_INPUT;// hspi2.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_256; hspi2.Init.FirstBit = SPI_FIRSTBIT_MSB; hspi2.Init.TIMode = SPI_TIMODE_DISABLE; hspi2.Init.CRCCalculation = SPI_CRCCALCULATION_ENABLE; hspi2.Init.CRCPolynomial = 7; hspi2.Init.CRCLength = SPI_CRC_LENGTH_16BIT;// hspi2.Init.NSSPMode = SPI_NSS_PULSE_DISABLE; if (HAL_SPI_Init( hspi2) != HAL_OK) { Error_Handler(); } DMA配置 /* SPI1 DMA Init */ /* SPI1_TX Init */ hdma_spi1_tx.Instance = DMA1_Channel1; hdma_spi1_tx.Init.Request = DMA_REQUEST_SPI1_TX; hdma_spi1_tx.Init.Direction = DMA_MEMORY_TO_PERIPH; hdma_spi1_tx.Init.PeriphInc = DMA_PINC_DISABLE; hdma_spi1_tx.Init.MemInc = DMA_MINC_ENABLE; hdma_spi1_tx.Init.PeriphDataAlignment = DMA_PDATAALIGN_BYTE;//DMA_PDATAALIGN_HALFWORD;// hdma_spi1_tx.Init.MemDataAlignment = DMA_MDATAALIGN_BYTE;//DMA_MDATAALIGN_HALFWORD;// hdma_spi1_tx.Init.Mode = DMA_NORMAL; hdma_spi1_tx.Init.Priority = DMA_PRIORITY_LOW; if (HAL_DMA_Init( hdma_spi1_tx) != HAL_OK) { Error_Handler(); } __HAL_LINKDMA(hspi,hdmatx,hdma_spi1_tx); /* SPI2_RX Init */ hdma_spi2_rx.Instance = DMA1_Channel3; hdma_spi2_rx.Init.Request = DMA_REQUEST_SPI2_RX; hdma_spi2_rx.Init.Direction = DMA_PERIPH_TO_MEMORY; hdma_spi2_rx.Init.PeriphInc = DMA_PINC_DISABLE; hdma_spi2_rx.Init.MemInc = DMA_MINC_ENABLE; hdma_spi2_rx.Init.PeriphDataAlignment = DMA_PDATAALIGN_BYTE;//DMA_PDATAALIGN_HALFWORD;// hdma_spi2_rx.Init.MemDataAlignment = DMA_MDATAALIGN_BYTE;//DMA_MDATAALIGN_HALFWORD;// hdma_spi2_rx.Init.Mode = DMA_NORMAL; hdma_spi2_rx.Init.Priority = DMA_PRIORITY_HIGH; if (HAL_DMA_Init( hdma_spi2_rx) != HAL_OK) { Error_Handler(); } __HAL_LINKDMA(hspi,hdmarx,hdma_spi2_rx); 主函数调用: if (HAL_SPI_Receive_DMA( hspi2,(uint8_t *)spisalver_receive_array, 10) != HAL_OK) { /* Transfer error in transmission process */ Error_Handler(); } if (HAL_SPI_Transmit_DMA( hspi1, (uint8_t *)spimater_send_array,10) != HAL_OK) { /* Transfer error in transmission process */ Error_Handler(); } |
1个回答
在使用STM32G070的SPI CRC 16位校验功能时,发生数据接收错误的可能原因可能有以下几点:
1. 硬件问题:检查SPI接口的硬件连接是否正确,包括信号线的接线是否正确,电源供应是否稳定等。 2. DMA配置问题:确保DMA的配置是正确的,包括DMA通道和传输方向是否正确配置,传输大小是否正确配置等。 3. 中断优先级配置问题:如果使用了中断来处理SPI数据的接收,确保SPI接收中断的优先级配置正确,避免优先级与其他中断冲突。 4. DMA传输完整性问题:确保DMA的传输长度和缓冲区的大小是正确匹配的,避免数据溢出或不完整的传输。 5. 超时错误处理问题:在执行SPI_WaitFlagStateUntilTimeout函数时,由于超时时间的设置等原因,可能导致函数返回不成功,进而导致CRC错误的判断。可以尝试调整超时时间,或者使用其他方式判断接收是否完成。 6. SPI配置问题:确保SPI的配置是正确的,包括时钟极性、相位的设置是否正确,数据位宽是否设置正确等。 |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
1684 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
1587 浏览 1 评论
1013 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
706 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
1629 浏览 2 评论
1893浏览 9评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
678浏览 4评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
538浏览 3评论
558浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
526浏览 3评论
GMT+8, 2024-12-4 17:08 , Processed in 0.690669 second(s), Total 47, Slave 41 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
