请教大家一个问题, 硬件是一样的,采样电阻接地。
负载不工作:AD单次采样时,可以采样到0x 00;AD+DMA连续采样,采样到 0x 0F到0x 12抬高了采样值,负载开启时:AD单次采样时,可以采样到0x 67 左右波动;AD+DMA连续采样,采样到 0x89 左右波动; 抬高了采样值,是我那里没有设置好吗,我就在例程上修改一个脚,从PC1改到PA1. include "adc.h" define ADC1_DR_Address ((u32)0x40012400+0x4c) __IO uint16_t ADC_ConvertedValue; static void ADC1_GPIO_Config(void){GPIO_InitTypeDef GPIO_InitStructure; / Enable DMA clock /RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE); / Enable ADC1 and GPIOC clock /RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1 | RCC_APB2Periph_GPIOA, ENABLE); / Configure PC.01 as analog input /GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;GPIO_Init(GPIOA, GPIO_InitStructure); // } static void ADC1_Mode_Config(void){DMA_InitTypeDef DMA_InitStructure;ADC_InitTypeDef ADC_InitStructure; / DMA channel1 configuration /DMA_DeInit(DMA1_Channel1);DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address; //DMA_InitStructure.DMA_MemoryBaseAddr = (u32) ADC_ConvertedValue;//DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;DMA_InitStructure.DMA_BufferSize = 1;DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;//DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Disable; //DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord; //DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;DMA_InitStructure.DMA_Mode = DMA_Mode_Circular; //DMA_InitStructure.DMA_Priority = DMA_Priority_High;DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;DMA_Init(DMA1_Channel1, DMA_InitStructure); / Enable DMA channel1 /DMA_Cmd(DMA1_Channel1, ENABLE); / ADC1 configuration / ADC_InitStructure.ADC_Mode = ADC_Mode_Independent; //ADC_InitStructure.ADC_ScanConvMode = DISABLE ; //ADC_InitStructure.ADC_ContinuousConvMode = ENABLE; //ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None; //ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right; //ADC_InitStructure.ADC_NbrOfChannel = 1; //ADC_Init(ADC1, ADC_InitStructure); RCC_ADCCLKConfig(RCC_PCLK2_Div8); ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 1, ADC_SampleTime_55Cycles5); / Enable ADC1 DMA /ADC_DMACmd(ADC1, ENABLE); / Enable ADC1 /ADC_Cmd(ADC1, ENABLE); ADC_ResetCalibration(ADC1); while(ADC_GetResetCalibrationStatus(ADC1)); ADC_StartCalibration(ADC1); while(ADC_GetCalibrationStatus(ADC1)); ADC_SoftwareStartConvCmd(ADC1, ENABLE);} void ADC1_Init(void) {ADC1_GPIO_Config(); ADC1_Mode_Config();} |
1个回答
采集结果可以同步使用示波器进行对比。除非使用稳定电源,电阻这种由于温度等外界和电路的影响较大。产生波动是正常的,只要再范围内即可。12位的AD这点波动是正常的。
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
1683 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
1582 浏览 1 评论
1013 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
703 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
1627 浏览 2 评论
1892浏览 9评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
674浏览 4评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
537浏览 3评论
556浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
525浏览 3评论
GMT+8, 2024-12-3 13:01 , Processed in 0.948143 second(s), Total 80, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
