电子发烧友论坛|
使用STM32CubeProgrammer可以连接到芯片,但是不能擦除
15:17:06 : STM32CubeProgrammer API v2.12.0 | Windows-64Bits 15:17:10 : ST-LINK SN : 390A070A2416303030303032 15:17:10 : ST-LINK FW : V2J41S7 15:17:10 : Board : -- 15:17:10 : Voltage : 4.70V 15:17:10 : SWD freq : 4000 KHz 15:17:10 : Connect mode: Under Reset 15:17:10 : Reset mode : Hardware reset 15:17:10 : Device ID : 0x413 15:17:10 : Revision ID : Rev Y 15:17:10 : Debug in Low Power mode is not supported for this device. 15:17:11 : UPLOADING OPtiON BYTES DATA ... 15:17:11 : Bank : 0x00 15:17:11 : Address : 0x40023c14 15:17:11 : Size : 4 Bytes 15:17:11 : UPLOADING ... 15:17:11 : Size : 1024 Bytes 15:17:11 : Address : 0x8000000 15:17:11 : Read progress: 15:17:11 : Data read successfully 15:17:11 : Time elapsed during the read operation is: 00:00:00.007 15:18:01 : MASS ERASE ... 15:18:01 : Error: Mass erase operation failed.Please verify flash protection使用最新版本的STM32CUBEIDE 调试STM32F407ZGT6单片机报错信息 STMicroelectronics ST-LINK GDB server. Version 7.3.0Copyright (c) 2023, STMicroelectronics. All rights reserved.Starting server with the following options: Persistent Mode : Disabled Logging Level : 1 Listen Port Number : 61234 Status Refresh Delay : 15s Verbose Mode : Disabled SWD Debug : EnabledSTM32_SystemReset(), failure reset target.Waiting for debugger connection...Debugger connectedWaiting for debugger connection...Debugger connectedWaiting for debugger connection... ------------------------------------------------------------------- STM32CubeProgrammer v2.13.0 -------------------------------------------------------------------Log output file: C:UsersJohn9AppDataLocalTempSTM32CubeProgrammer_a12424.logST-LINK SN : 390A070A2416303030303032ST-LINK FW : V2J41S7Board : --Voltage : 3.14VSWD freq : 4000 KHzConnect mode: Under ResetReset mode : Hardware resetDevice ID : 0x413Revision ID : Rev YDevice name : STM32F405xx/F407xx/F415xx/F417xxFlash size : 1 MBytes (default)Device type : MCUDevice CPU : Cortex-M4BL Version : 0x91Memory Programming ...Opening and parsing file: ST-LINK_GDB_server_a12424.srec File : ST-LINK_GDB_server_a12424.srec Size : 39.39 KB Address : 0x08000000 Erasing memory corresponding to segment 0:Erasing internal memory sectors [0 2]Error: failed to erase memoryError: failed to erase memoryEncountered Error when opening P:ProgramSTMicroelectronicsSTM32CubeIDESTM32CubeIDEpluginscom.st.stm32cube.ide.mcu.externaltools.cubeprogrammer.win32_2.0.600.202301161003toolsbinSTM32_Programmer_CLI.exeError in STM32CubeProgrammerShutting down...Exit. |
1个回答
用cubeprogrammer 工具连上后,能读取FLASH 和 option byte 的内容么?如果能读取的话,重点检查一下option byte的内容是否正常。
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
4140 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
3228 浏览 1 评论
2753 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
2181 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
14984 浏览 2 评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
3088浏览 4评论
stm32f4下spi+dma读取数据不对是什么原因导致的?
1897浏览 3评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
2068浏览 3评论
1980浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
2170浏览 3评论
/9
GMT+8, 2025-12-2 18:04 , Processed in 0.703386 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1087
