SEGGER J-Link GDB Server V7.92n Command Line Version
JLinkARM.dll V7.92n (DLL compiled Oct 31 2023 15:10:15) Command line: -port 2331 -s -device STM32WBA52CG -endian little -speed 4000 -if swd -vd -----GDB Server start settings----- GDBInit file: none GDB Server Listening port: 2331 SWO raw output listening port: 2332 Terminal I/O port: 2333 Accept remote connection: localhost only Generate logfile: off Verify download: on Init regs on start: off Silent mode: off Single run mode: on Target connection timeout: 0 ms ------J-Link related settings------ J-Link Host interface: USB J-Link script: none J-Link settings file: none ------Target related settings------ Target device: STM32WBA52CG Target device parameters: none Target interface: SWD Target interface speed: 4000kHz Target endian: little Connecting to J-Link... J-Link is connected. Firmware: J-Link V9 compiled May 7 2021 16:26:12 Hardware: V9.50 S/N: 69532295 Feature(s): JFlash, GDB, RDI, FlashBP, FlashDL Checking target voltage... Target voltage: 3.32 V Listening on TCP/IP port 2331 Connecting to target... Halting core... Core security extensions: Not implemented Connected to target Waiting for GDB connection...Connected to 0000:0000:0000:0000:0000:0000:0000:0001 GDB client (conn. 944) requested target.xml from GDB Server Reading common registers: Read register 'r0' (4 bytes) from hardware: 0x07000000 Read register 'r1' (4 bytes) from hardware: 0x00000000 Read register 'r2' (4 bytes) from hardware: 0x01000000 Read register 'r3' (4 bytes) from hardware: 0x01000000 Read register 'r4' (4 bytes) from hardware: 0xF8040020 Read register 'r5' (4 bytes) from hardware: 0x44050020 Read register 'r6' (4 bytes) from hardware: 0x0000000C Read register 'r7' (4 bytes) from hardware: 0x74FF0120 Read register 'r8' (4 bytes) from hardware: 0xFFFFFFFF Read register 'r9' (4 bytes) from hardware: 0xD8050040 Read register 'r10' (4 bytes) from hardware: 0xFFFFFFFF Read register 'r11' (4 bytes) from hardware: 0xFFFFFFFF Read register 'r12' (4 bytes) from hardware: 0x54020106 Read register 'sp' (4 bytes) from hardware: 0x74FF0120 Read register 'lr' (4 bytes) from hardware: 0xD5BE0408 Read register 'pc' (4 bytes) from hardware: 0x50CA0408 Read register 'xpsr' (4 bytes) from hardware: 0x00000001 Read 4 bytes @ address 0x0804CA50 (Data = 0x681B4B05) Received monitor command: ReadAPEx 0x1000000 0xF8 O.K.:0xE00FE003 Read 4 bytes @ address 0xE000EE08 (Data = 0x00000000) Received monitor command: ReadMemAP 0x1000000 0xE00FEFD0 0x8 0x0 O.K.:0x00000000,0x00000000,0x00000000,0x00000000,0x00000092,0x00000004,0x0000000A,0x00000000 Reading register 'msp' = 0x2001FF74 Reading register 'psp' = 0x00000000 Read 4 bytes @ address 0x0804BED4 (Data = 0xBD80BF00) Reading 64 bytes @ address 0x2001FF40 Connected to 0000:0000:0000:0000:0000:0000:0000:0001 Read 4 bytes @ address 0x080589C4 (Data = 0x60FB69FB) GDB client (conn. 964) requested target.xml from GDB Server Reading 64 bytes @ address 0x2001FFC0 Read 4 bytes @ address 0x0804BEC0 (Data = 0xBD80BF00) Reading common registers: Read register 'r0' (4 bytes) from hardware: 0x07000000 Read register 'r1' (4 bytes) from hardware: 0x00000000 Read register 'r2' (4 bytes) from hardware: 0x01000000 Read register 'r3' (4 bytes) from hardware: 0x01000000 Read register 'r4' (4 bytes) from hardware: 0xF8040020 Read register 'r5' (4 bytes) from hardware: 0x44050020 Read register 'r6' (4 bytes) from hardware: 0x0000000C Read register 'r7' (4 bytes) from hardware: 0x74FF0120 Read register 'r8' (4 bytes) from hardware: 0xFFFFFFFF Read register 'r9' (4 bytes) from hardware: 0xD8050040 Read register 'r10' (4 bytes) from hardware: 0xFFFFFFFF Read register 'r11' (4 bytes) from hardware: 0xFFFFFFFF Read register 'r12' (4 bytes) from hardware: 0x54020106 Read register 'sp' (4 bytes) from hardware: 0x74FF0120 Read register 'lr' (4 bytes) from hardware: 0xD5BE0408 Read register 'pc' (4 bytes) from hardware: 0x50CA0408 Read register 'xpsr' (4 bytes) from hardware: 0x00000001 Read 4 bytes @ address 0x0804BFC6 (Data = 0xB580E7FC) Read 4 bytes @ address 0x0804CA50 (Data = 0x681B4B05) Downloading 348 bytes @ address 0x08000000 - Verified OK Downloading 16148 bytes @ address 0x0800015C - Verified OK Downloading 16192 bytes @ address 0x08004070 - Verified OK Downloading 16272 bytes @ address 0x08007FB0 - Verified OK Downloading 16064 bytes @ address 0x0800BF40 - Verified OK Downloading 16144 bytes @ address 0x0800FE00 - Verified OK Downloading 16224 bytes @ address 0x08013D10 - Verified OK Downloading 16208 bytes @ address 0x08017C70 - Verified OK Downloading 16112 bytes @ address 0x0801BBC0 - Verified OK Downloading 16144 bytes @ address 0x0801FAB0 - Verified OK Downloading 16128 bytes @ address 0x080239C0 - Verified OK Downloading 16096 bytes @ address 0x080278C0 - Verified OK Downloading 16160 bytes @ address 0x0802B7A0 - Verified OK Downloading 16176 bytes @ address 0x0802F6C0 - Verified OK Downloading 16192 bytes @ address 0x080335F0 - Verified OK Downloading 16224 bytes @ address 0x08037530 - Verified OK Downloading 16208 bytes @ address 0x0803B490 - Verified OK Downloading 16160 bytes @ address 0x0803F3E0 - Verified OK Downloading 16176 bytes @ address 0x08043300 - Verified OK Downloading 16176 bytes @ address 0x08047230 - Verified OK Downloading 16048 bytes @ address 0x0804B160 - Verified OK Downloading 16000 bytes @ address 0x0804F010 - Verified OK Downloading 16048 bytes @ address 0x08052E90 - Verified OK Downloading 9076 bytes @ address 0x08056D40 - Verified OK Downloading 11780 bytes @ address 0x080590B8 - Verified OK Downloading 8 bytes @ address 0x0805BEBC - Verified OK Downloading 4 bytes @ address 0x0805BEC4 - Verified OK Downloading 4 bytes @ address 0x0805BEC8 - Verified OK Downloading 1272 bytes @ address 0x0805BECC - Verified OK Writing register 'pc' = 0x080585F0 Read 4 bytes @ address 0x080585F0 (Data = 0x46854828) Read 2 bytes @ address 0x080585F0 (Data = 0x4828) Starting target CPU... GDB closed TCP/IP connection (Socket 964) Debugger requested to halt target... ...Target halted (PC = 0x0804C398) Reading common registers: Read register 'r0' (4 bytes) from hardware: 0x03000000 Read register 'r1' (4 bytes) from hardware: 0x00080246 Read register 'r2' (4 bytes) from hardware: 0x0030020F Read register 'r3' (4 bytes) from hardware: 0x03000000 Read register 'r4' (4 bytes) from hardware: 0xF8040020 Read register 'r5' (4 bytes) from hardware: 0x44050020 Read register 'r6' (4 bytes) from hardware: 0x0000000C Read register 'r7' (4 bytes) from hardware: 0x64FF0120 Read register 'r8' (4 bytes) from hardware: 0xFFFFFFFF Read register 'r9' (4 bytes) from hardware: 0xD8050040 Read register 'r10' (4 bytes) from hardware: 0xFFFFFFFF Read register 'r11' (4 bytes) from hardware: 0xFFFFFFFF Read register 'r12' (4 bytes) from hardware: 0x54020106 Read register 'sp' (4 bytes) from hardware: 0x64FF0120 Read register 'lr' (4 bytes) from hardware: 0xF9BF0408 Read register 'pc' (4 bytes) from hardware: 0x98C30408 Read register 'xpsr' (4 bytes) from hardware: 0x00000021 Read 4 bytes @ address 0x0804C398 (Data = 0x0000E7FE) GDB closed TCP/IP connection (Socket 944) Restoring target state and closing J-Link connection... Shutting down... 因为STLINKV2连接不上换成了JLINK,可以用J-Flash连接上去,并进行擦片。但是在使用CubeIDE进行调试的时候,无法进入调试状态。 以上信息是进入调试时候的打印信息,不明白在下面这个信息后 Halting core... Core security extensions: Not implemented 为什么会跳转TCP/IP这样的连接,还有这个地方突然停止核心,一般是什么原因? 用CubeIDE,我应该是可以把程序下载进入,因为我重新上电之后,可以扫描看到BLE的广播名称,并且手机能够进行配对。 |
1个回答
以下是尝试进行故障排除的几个可能原因和步骤:
1。请确保已在STM32CubeIDE中正确配置调试设置。仔细检查是否已选择正确的调试探针(SEGGER J-Link),并在调试配置中设置正确的目标设备(STM32WBA52CG)。 2.检查开发板和调试探针之间的连接。确保使用SWD接口将调试探针正确连接到目标板。 3.验证目标设备上的固件是否正确闪存和运行。在尝试调试之前,请确保设备已通电并运行预期的程序。 4.检查是否有任何断点或观察点导致调试进程停止。尝试禁用所有断点和观察点,看看问题是否仍然存在。 5.验证J-Link驱动程序是否正确安装在您的系统上。确保安装了最新版本的J-Link软件和驱动程序。 6.尝试重新启动J-Link GDB服务器和STM32CubeIDE。有时,重新启动工具可以帮助解决任何临时问题。 7.如果可能,请尝试使用不同的调试探针或开发板来隔离问题是否与硬件组件有关。 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
STM32F405驱动DS1302时钟模块,输出时间错乱该怎么排查?
2810 浏览 2 评论
stm32f405rgt6驱动DS1302ZN出现时间错乱问题
2420 浏览 1 评论
stm32用fsmc读取ad7606采集数据,数据不变,只有开发版复位才更新数据
2288 浏览 0 评论
2404 浏览 1 评论
1643 浏览 1 评论
/9
GMT+8, 2025-12-2 22:59 , Processed in 0.574324 second(s), Total 75, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
834
