要使用DMA改变PWM的占空比,你可以按照以下步骤进行操作:
1. 首先,在STM32CubeMX中配置PWM的输出模式和初始化设置。 2. 在代码中,使用HAL库初始化DMA以及PWM。 3. 创建一个存储占空比数据的数组,并使用DMA将数组中的数据从内存传输到PWM寄存器。 下面是一个示例代码,演示如何使用DMA改变PWM的占空比: ``` #include "stm32h7xx.h" #include "stm32h7xx_hal.h" #define PWM_PERIOD 1000 // PWM周期,可根据需要进行更改 #define ARRAY_SIZE 10 // 数组大小,用于存储占空比数据 TIM_HandleTypeDef htim1; //初始化PWM定时器 DMA_HandleTypeDef hdma_tim1_up; uint32_t pwmData[ARRAY_SIZE] = {100, 200, 300, 400, 500, 600, 700, 800, 900, 1000}; // 存储占空比数据的数组 void configurePWM() { __HAL_RCC_GPIOA_CLK_ENABLE(); __HAL_RCC_TIM1_CLK_ENABLE(); GPIO_InitTypeDef GPIO_InitStruct; GPIO_InitStruct.Pin = GPIO_PIN_8; GPIO_InitStruct.Mode = GPIO_MODE_AF_PP; GPIO_InitStruct.Pull = GPIO_NOPULL; GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW; GPIO_InitStruct.Alternate = GPIO_AF1_TIM1; HAL_GPIO_Init(GPIOA, &GPIO_InitStruct); htim1.Instance = TIM1; htim1.Init.Prescaler = 0; htim1.Init.CounterMode = TIM_COUNTERMODE_UP; htim1.Init.Period = PWM_PERIOD; htim1.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1; HAL_TIM_PWM_Init(&htim1); TIM_OC_InitTypeDef sConfigOC; sConfigOC.OCMode = TIM_OCMODE_PWM1; sConfigOC.Pulse = 0; sConfigOC.OCPolarity = TIM_OCPOLARITY_HIGH; sConfigOC.OCFastMode = TIM_OCFAST_DISABLE; HAL_TIM_PWM_ConfigChannel(&htim1, &sConfigOC, TIM_CHANNEL_1); HAL_TIM_PWM_Start(&htim1, TIM_CHANNEL_1); } void configureDMA() { __HAL_RCC_DMA1_CLK_ENABLE(); hdma_tim1_up.Instance = DMA1_Stream5; hdma_tim1_up.Init.Request = DMA_REQUEST_TIM1_UP; hdma_tim1_up.Init.Direction = DMA_PERIPH_TO_MEMORY; hdma_tim1_up.Init.PeriphInc = DMA_PINC_DISABLE; hdma_tim1_up.Init.MemInc = DMA_MINC_ENABLE; hdma_tim1_up.Init.PeriphDataAlignment = DMA_PDATAALIGN_WORD; hdma_tim1_up.Init.MemDataAlignment = DMA_MDATAALIGN_WORD; hdma_tim1_up.Init.Mode = DMA_CIRCULAR; hdma_tim1_up.Init.Priority = DMA_PRIORITY_HIGH; HAL_DMA_Init(&hdma_tim1_up); HAL_NVIC_SetPriority(DMA1_Stream5_IRQn, 0, 0); HAL_NVIC_EnableIRQ(DMA1_Stream5_IRQn); __HAL_LINKDMA(&htim1, hdma[TIM_DMA_ID_UPDATE], hdma_tim1_up); HAL_TIM_PWM_Start_DMA(&htim1, TIM_CHANNEL_1, pwmData, ARRAY_SIZE); } int main() { HAL_Init(); configurePWM(); configureDMA(); while(1); } void DMA1_Stream5_IRQHandler() { HAL_DMA_IRQHandler(&hdma_tim1_up); } void HAL_DMA_CompleteCallback(DMA_HandleTypeDef *hdma) { if(hdma->Instance == DMA1_Stream5) { // 从数组中读取下一个占空比值 uint32_t nextPulse = pwmData[0]; // 从数组中删除第一个元素,并将其添加到数组的末尾 for(int i = 0; i < ARRAY_SIZE - 1; i++) { pwmData[i] = pwmData[i+1]; } pwmData[ARRAY_SIZE - 1] = nextPulse; // 设置PWM占空比 __HAL_TIM_SET_COMPARE(&htim1, TIM_CHANNEL_1, nextPulse); } } ``` 在此代码中,我们首先利用STM32CubeMX配置PWM和DMA的基本参数。然后,我们创建了一个存储占空比数据的数组,并将数组传递给DMA使用。 DMA使用循环模式以连续方式从数组中读取数据,并在DMA传输完成后调用中断服务程序。在中断服务程序中,我们从数组中读取下一个占空比值,并将其设置为PWM占空比。再次启动DMA传输以实现循环读取数据的效果。 请注意,源代码中使用到的DMA和PWM外设可能需要根据具体的STM32H750开发板进行适配。还需要确保在STM32CubeMX中正确配置了相关的引脚和时钟设置。 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
1636 浏览 1 评论
1277 浏览 0 评论
1131 浏览 0 评论
STM32F405驱动DS1302时钟模块,输出时间错乱该怎么排查?
5510 浏览 2 评论
stm32f405rgt6驱动DS1302ZN出现时间错乱问题
4303 浏览 1 评论
/9
GMT+8, 2025-12-17 22:27 , Processed in 0.651008 second(s), Total 73, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
979
