你好。我正在尝试在 psco6 (CY8CKIT-062-BT-WIFI) 上使用 DMA 将阵列传输到 SPI 外围设备。
数组长度是一个很大的任意数字,不适合 2D 传输。比方说 643 字节。 我的想法是将其分成两个描述符并将它们链接起来。即第一个描述符传输 10x64 字节,第二个描述符传输 3 字节。(我不确定是否有其他方法。) 我遇到的问题是它无法启动第二个描述符。这是我正在尝试使用的代码: #define txDma_ENABLED 1U#define txDma_HW DW0#define txDma_CHANNEL 2U#define txDma_IRQ cpuss_interrupts_dw0_2_IRQn/* Interrupt priority for TXDMA */#define TXDMA_INTERRUPT_PRIORITY (7u)volatile bool tx_dma_done = false;cy_stc_dma_descriptor_t txDma_Descriptor_1 = { .ctl = 0UL, .src=0UL, .dst = 0UL, .xCtl = 0UL, .yCtl = 0UL, .nextPtr = 0UL,};cy_stc_dma_descriptor_t txDma_Descriptor_0 = { .ctl = 0UL, .src=0UL, .dst = 0UL, .xCtl = 0UL, .yCtl = 0UL, .nextPtr = 0UL,};const cy_stc_dma_descriptor_config_t txDma_Descriptor_0_config = { .retrigger = CY_DMA_RETRIG_IM, .interruptType = CY_DMA_DESCR_CHAIN, .triggerOutType = CY_DMA_1ELEMENT, .channelState = CY_DMA_CHANNEL_DISABLED, .triggerInType = CY_DMA_1ELEMENT, .dataSize = CY_DMA_BYTE, .srcTransferSize = CY_DMA_TRANSFER_SIZE_DATA, .dstTransferSize = CY_DMA_TRANSFER_SIZE_WORD, .descriptorType = CY_DMA_2D_TRANSFER, .srcAddress = NULL, .dstAddress = NULL, .srcXincrement = 1, .dstXincrement = 0, .xCount = 1, .srcYincrement = 0, .dstYincrement = 0, .yCount = 1, .nextDescriptor = 0UL,};const cy_stc_dma_channel_config_t txDma_channelConfig = { .descriptor = txDma_Descriptor_0, .preemptable = false, .priority = 3, .enable = false, .bufferable = false,};const uint8_t small_buffer[10]={0xA1,0xB2,0xC3};uint32_t configure_tx_dma(uint8_t* tx_buffer){ cy_en_dma_status_t dma_init_status; const cy_stc_sysint_t intTxDma_cfg = { .intrsrc=txDma_IRQ, .intrPriority = 7u }; /* Initialize descriptor */ dma_init_status = Cy_DMA_Descriptor_Init( txDma_Descriptor_0, txDma_Descriptor_0_config); Cy_DMA_Descriptor_SetXloopSrcIncrement( txDma_Descriptor_0, 1); Cy_DMA_Descriptor_SetYloopSrcIncrement( txDma_Descriptor_0, 64); Cy_DMA_Descriptor_SetXloopDataCount( txDma_Descriptor_0, 64); Cy_DMA_Descriptor_SetYloopDataCount( txDma_Descriptor_0, 10); Cy_DMA_Descriptor_SetNextDescriptor( txDma_Descriptor_0, txDma_Descriptor_1); dma_init_status = Cy_DMA_Descriptor_Init( txDma_Descriptor_1, txDma_Descriptor_0_config); Cy_DMA_Descriptor_SetXloopSrcIncrement( txDma_Descriptor_1, 1); Cy_DMA_Descriptor_SetYloopSrcIncrement( txDma_Descriptor_1, 3); Cy_DMA_Descriptor_SetXloopDataCount( txDma_Descriptor_1, 3); Cy_DMA_Descriptor_SetYloopDataCount( txDma_Descriptor_1, 1); Cy_DMA_Descriptor_SetNextDescriptor( txDma_Descriptor_1, 0UL); if (dma_init_status!=CY_DMA_SUCCESS) { return INIT_FAILURE; } dma_init_status = Cy_DMA_Channel_Init(txDma_HW, txDma_CHANNEL, txDma_channelConfig); if (dma_init_status!=CY_DMA_SUCCESS) { return INIT_FAILURE; } /* Set source and destination for descriptor 1 */ Cy_DMA_Descriptor_SetSrcAddress( txDma_Descriptor_0, tx_buffer); Cy_DMA_Descriptor_SetDstAddress( txDma_Descriptor_0, (void *) SCB6->TX_FIFO_WR); Cy_DMA_Descriptor_SetSrcAddress( txDma_Descriptor_1, small_buffer); Cy_DMA_Descriptor_SetDstAddress( txDma_Descriptor_1, (void *) SCB6->TX_FIFO_WR); /* Initialize and enable the interrupt from TxDma */ Cy_SysInt_Init( intTxDma_cfg, tx_dma_complete); NVIC_EnableIRQ((IRQn_Type)intTxDma_cfg.intrSrc); /* Enable DMA interrupt source. */ Cy_DMA_Channel_SetInterruptMask(txDma_HW, txDma_CHANNEL, CY_DMA_INTR_MASK); /* Enable DMA block to start descriptor execution process */ Cy_DMA_Enable(txDma_HW); return INIT_SUCCESS;}void tx_dma_complete(void){ /* Check tx DMA status */ if ((CY_DMA_INTR_CAUSE_COMPLETION != Cy_DMA_Channel_GetStatus(txDma_HW, txDma_CHANNEL)) (CY_DMA_INTR_CAUSE_CURR_PTR_NULL != Cy_DMA_Channel_GetStatus(txDma_HW, txDma_CHANNEL))) { /* DMA error occurred while TX operations */ //handle_error(); } tx_dma_done = true; /* Clear tx DMA interrupt */ Cy_DMA_Channel_ClearInterrupt(txDma_HW, txDma_CHANNEL);}void spi_dma_transfer(){ Cy_DMA_Channel_SetDescriptor(txDma_HW, txDma_CHANNEL, txDma_Descriptor_0); Cy_DMA_Channel_Enable(txDma_HW, txDma_CHANNEL);} |
1个回答
您好!关于无法启动第二个描述符的问题,可能有几个原因导致:
1. 描述符链配置问题:请确保第一个描述符的链结束符(bit[15])设置为0,而第二个描述符的链结束符设置为1。 2. 描述符的有效性问题:请确保每个描述符的有效位(bit[31])都被设置为1,以确保DMA引擎可以正确处理它们。 3. DMA配置问题:请确保正确配置了DMA引擎相关的寄存器,包括描述符地址、描述符数目和DMA通道。 此外,您还可以尝试使用中断方式来处理每个描述符的传输完成事件,以便及时处理第二个描述符的传输。 对于您提到的不适合2D传输的问题,您可以尝试使用多个描述符来传输数据,如您所示的将数组分成两个描述符。另外,您还可以使用循环模式来重复传输同一个描述符,从而实现大数组的传输。 最后,如果您提供更多的代码和错误消息,我可以帮助您更好地理解问题并给出更具体的建议。 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
470 浏览 0 评论
532 浏览 0 评论
660 浏览 0 评论
822 浏览 0 评论
RT-Thread与英飞凌(infineon)合作得板子PSOC 6 板子学习
758 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
17032 浏览 31 评论
/9
GMT+8, 2025-12-13 15:42 , Processed in 1.421089 second(s), Total 73, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
407
