CAN_Init(CAN0);//初始化CAN0
CAN_Open(CAN0, 125000, CAN_NORMAL_MODE);//配置模式 M_RUN();//电机启动 M_Zero();//电机归零 Test_NormalMode_Rx();//配置接收 首先,电机可以保证正常,驱动器是可以收到数据并且响应的。证明了发送数据 没问题。 我配置的接收以及接收过程是以下过程,发现发出去的数据,可以起到触发中断,但是收不到驱动器收到的数据;驱动器的ID设置位了1;并不能收到这个响应; CAN发送使用MSG[0] void M_RUN(void) { /* Send a 11-bits message */ tMsg.FrameType = CAN_DATA_FRAME; tMsg.IdType = CAN_STD_ID; tMsg.Id = 0x01; tMsg.DLC = 8; tMsg.Data[0] = 0X00; tMsg.Data[1] = 0X1A; tMsg.Data[2] = 0X00; tMsg.Data[3] = 0X00; tMsg.Data[4] = 0X01; tMsg.Data[5] = 0X00; tMsg.Data[6] = 0X00; tMsg.Data[7] = 0X01; if(CAN_Transmit(CAN0, MSG(0), tMsg) == FALSE) // Configure Msg RAM and send the Msg in the RAM { printf("Set Tx Msg Object failedn"); } } //接收使用MSG[1] void Test_NormalMode_Rx(void) { if(CAN_SetRxMsg(CAN0, MSG(1), CAN_STD_ID, 0X7FFF) == FALSE) { printf("Set Rx Msg Object failedn"); return; } /*Choose one mode to test*/ /* INT Mode */ CAN_EnableInt(CAN0, CAN_CON_IE_Msk); NVIC_SetPriority(CAN0_IRQn, (1 << __NVIC_PRIO_BITS) - 2); NVIC_EnableIRQ(CAN0_IRQn); } void CAN_ShowMsg(STR_CANMSG_T *Msg) { uint8_t i; printf("Read ID=%8X, Type=%s, DLC=%d,Data=", Msg->Id, Msg->IdType ? "EXT" : "STD", Msg->DLC); for(i = 0; i < Msg->DLC; i++) printf("%02X,", Msg->Data[i]); printf("nn"); } void CAN_MsgInterrupt(CAN_T *tCAN, uint32_t u32IIDR) { if(u32IIDR==1) { printf("Msg-0 INT and Callbackn"); CAN_Receive(tCAN, 0, rrMsg); CAN_ShowMsg( rrMsg); } if(u32IIDR==2) { printf("Msg-1 INT and Callbackn"); CAN_Receive(tCAN, 1, rrMsg); CAN_ShowMsg( rrMsg); } if(u32IIDR==5+1) { printf("Msg-5 INT and Callback n"); CAN_Receive(tCAN, 5, rrMsg); CAN_ShowMsg( rrMsg); } if(u32IIDR==31+1) { printf("Msg-31 INT and Callback n"); CAN_Receive(tCAN, 31, rrMsg); CAN_ShowMsg( rrMsg); } } /** * @brief CAN0_IRQ Handler. * @param None. * @return None. */ void CAN0_IRQHandler(void) { uint32_t u8IIDRstatus; u8IIDRstatus = CAN0->IIDR; if(u8IIDRstatus == 0x00008000) /* Check Status Interrupt Flag (Error status Int and Status change Int) */ { /**************************/ /* Status Change interrupt*/ /**************************/ if(CAN0->STATUS CAN_STATUS_RXOK_Msk) { CAN0->STATUS = ~CAN_STATUS_RXOK_Msk; /* Clear Rx Ok status*/ printf("RX OK INTn") ; } if(CAN0->STATUS CAN_STATUS_TXOK_Msk) { CAN0->STATUS = ~CAN_STATUS_TXOK_Msk; /* Clear Tx Ok status*/ printf("TX OK INTn") ; } /**************************/ /* Error Status interrupt */ /**************************/ if(CAN0->STATUS CAN_STATUS_EWARN_Msk) { printf("EWARN INTn") ; /* Do Init to release busoff pin */ CAN0->CON = (CAN_CON_INIT_Msk | CAN_CON_CCE_Msk); CAN0->CON = (~(CAN_CON_INIT_Msk | CAN_CON_CCE_Msk)); while(CAN0->CON CAN_CON_INIT_Msk); } if(CAN0->STATUS CAN_STATUS_BOFF_Msk) { printf("BOFF INTn") ; } } else if (u8IIDRstatus != 0) { printf("=> Interrupt Pointer = %d-%dn", CAN0->IIDR - 1, u8IIDRstatus); CAN_MsgInterrupt(CAN0, u8IIDRstatus); CAN_CLR_INT_PENDING_BIT(CAN0, ((CAN0->IIDR) - 1)); /* Clear Interrupt Pending */ } else if(CAN0->WU_STATUS == 1) { printf("Wake upn"); CAN0->WU_STATUS = 0; /* Write '0' to clear */ } } |
1个回答
1、从代码上看要接收ID = 0x7FFF的消息 ,请问消息ID是否正确。
2、确认一下对方是在Test_NormalMode_Rx调用之前还是之后发送的数据。 一般建议先配置接收再配置发送 3、另外可以示波器看一下对方是否有发数据出来 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
265 浏览 0 评论
【原创】【RA4M2-SENSOR开发板评测】低功耗+USB综合测试
789 浏览 0 评论
1306 浏览 2 评论
787 浏览 0 评论
【RA4M2-SENSOR开发板评测】Analogue+Timers综合测试
1587 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
16899 浏览 31 评论
/9
GMT+8, 2025-12-1 22:50 , Processed in 0.430515 second(s), Total 42, Slave 35 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
581
