请问ADSP-21489怎么实现DMA功能?
看了一下例程和手册,还是不太明白怎么操作DMA,请问在C语言下,以UART为例,怎么实现DMA接收串口数据到指定的数组里或者单个变量上?能贴个代码不? |
1个回答
ADSP-21489是ADI公司生产的一款数字信号处理器(DSP)产品。实现DMA功能时,可以通过配置DMA的控制寄存器和源/目的地址来实现数据的传输。
以下是一个使用DMA接收UART数据的示例代码: ```c #include #include #include #include #include "adi_initialize.h" #include "adi_uart.h" #include "adi_dma.h" // UART相关配置 #define UART_DEVICE_NUM 0 #define UART_FLOW_CONTROL false #define UART_BITRATE 115200 #define UART_WORD_LENGTH ADI_UART_WORDLEN_8BITS #define UART_PARITY ADI_UART_PARITY_NONE #define UART_STOP_BITS ADI_UART_ONE_STOPBIT // DMA相关配置 #define DMA_CHANNEL_NUM 0 #define DMA_NUM_TRANSFERS 1 #define DMA_DATA_WIDTH 2 // 数据宽度:2字节(16位) #define DMA_DATA_TRANSFER_SIZE sizeof(uint16_t) // 数据传输单位大小 // 数据接收缓冲区 #define BUFFER_SIZE 100 uint16_t buffer[BUFFER_SIZE]; // DMA完成中断标志 volatile bool dmaTransferCompleteFlag = false; // DMA回调函数 static void dmaCallback(void *pCBParam, uint32_t Event, void *pArg) { if (Event == ADI_DMA_EVENT_TRANSFER_COMPLETE) { dmaTransferCompleteFlag = true; } } int main(void) { // 系统初始化 adi_initComponents(); // 初始化UART if (adi_uart_Open(UART_DEVICE_NUM, ADI_UART_DIR_RX, NULL, NULL, &uartDevice) != ADI_UART_SUCCESS) { printf("UART open failedn"); return -1; } if (adi_uart_ConfigData(UART_DEVICE_NUM, UART_WORD_LENGTH, UART_PARITY, UART_STOP_BITS) != ADI_UART_SUCCESS) { printf("UART configuration failedn"); return -1; } if (adi_uart_SetBitrate(UART_DEVICE_NUM, UART_BITRATE) != ADI_UART_SUCCESS) { printf("UART bitrate configuration failedn"); return -1; } // 初始化DMA if (adi_dma_Init(NULL) != ADI_DMA_SUCCESS) { printf("DMA initialization failedn"); return -1; } // 配置DMA传输 ADI_DMA_TRANSFER dmaTransfer = { .DestAddr = (void *)buffer, .DestAddrMode = ADI_DMA_ADDR_MODE_LINEAR, .SrcAddr = ADI_UART_IRQ_RXDATA_UART0, .SrcAddrMode = ADI_DMA_ADDR_MODE_PERIPHERAL, .DataWidth = DMA_DATA_WIDTH, .BytesPerElement = DMA_DATA_TRANSFER_SIZE, .ElementCount = BUFFER_SIZE, .IncrementDestAddr = true, .InterruptOnCompletion = true, .UseBurstMode = true, .EnableCircularMode = false, .CallbackFcn = dmaCallback, .CallbackRefCon = NULL }; // 配置DMA传输通道 if (adi_dma_ChannelAllocate(DMA_CHANNEL_NUM, dmaTransfer.DestAddrMode, NULL) != ADI_DMA_SUCCESS) { printf("DMA channel allocation failedn"); return -1; } if (adi_dma_SetChannelConfig(DMA_CHANNEL_NUM, ADI_DMA_MODE_BASIC, true) != ADI_DMA_SUCCESS) { printf("DMA channel configuration failedn"); return -1; } // 开始DMA传输 dmaTransferCompleteFlag = false; if (adi_dma_SubmitTransfer(DMA_CHANNEL_NUM, &dmaTransfer) != ADI_DMA_SUCCESS) { printf("DMA transfer submission failedn"); return -1; } // 等待DMA传输完成 while (!dmaTransferCompleteFlag) { // 可以添加其他处理逻辑 } // 关闭UART和DMA adi_uart_Close(UART_DEVICE_NUM); adi_dma_Close(DMA_CHANNEL_NUM); return 0; } ``` 以上代码实现了使用DMA接收UART数据,并将数据存储在指定的数组中。在代码中,首先通过`adi_uart_Open`打开UART设备,然后配置UART的通信参数。接下来,初始化DMA并配置DMA传输通道和传输参数。最后,通过`adi_dma_SubmitTransfer`提交传输,等待传输完成后,关闭UART和DMA。 这只是一个示例代码,具体的配置和使用可能还需要根据实际场景进行调整。建议参考ADI公司提供的相关文档和手册,对ADSP-21489芯片和相关软件库进行进一步学习和了解。 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
435 浏览 0 评论
464 浏览 0 评论
450 浏览 0 评论
806 浏览 0 评论
RT-Thread与英飞凌(infineon)合作得板子PSOC 6 板子学习
748 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
17010 浏览 31 评论
/9
GMT+8, 2025-12-12 03:35 , Processed in 0.513427 second(s), Total 41, Slave 34 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3506
