我打算使用ADuC7060的PWM1端口输出PWM脉冲,单端输出,占空比是50%,周期是100μS,在用Keil调试时能正常输出我所需要的PWM脉冲,后来断电后再上电却发现PWM输出异常,主要是占空比异常,周期还是正常的。后来我将官方的PWM程序烧写进去后再将我的PWM测试程序烧写到芯片中后又正常了,但是一断电再上电就出现异常了。
请问大虾这是什么造成的。解决方式是什么? 下面附上我的PWM测试程序: int main(void) { POWKEY1 = 0x1; POWCON0 = 0x78; // Set core to max CPU speed of 10.24Mhz POWKEY2 = 0xF4; // Initialize the GPIO pins for PWM mode GP0CON0 = BIT16; // Select PWM1 output PWMCON = BIT0; // PWM Standard mode, UCLK/2 PWM0COM2 = 0x80; // Configure PWM1 output low trigger time PWM0LEN = 0xFF; // Configure PWM1 output high trigger time while (1) { } } 官方的PWM程序: unsigned char bTripDetected = 0; int main(void) { POWKEY1 = 0x1; POWCON0 = 0x78; // Set core to max CPU speed of 10.24Mhz POWKEY2 = 0xF4; // Initialize the GPIO pins for PWM mode GP0CON0 = BIT16; // Select PWM1 output // GP1CON = BIT8 + BIT12 // Select PWMSYNC and PWMTRIP functions // + BIT16 + BIT20 // Select PWM2, PWM3 output // + BIT24; // Select PWM4 output // GP2CON = BIT0 + BIT4; // Select PWM0 and PWM5 output PWMCON = BIT0 + BIT10; // PWM Standard mode, UCLK/2, PWM Trip interrupt enabled ConfigurePWM(); // Call function to configure PWM bTripDetected = 0; IRQEN = BIT17; // Enable PWM Trip interrupt source while (1) { if (bTripDetected == 1) { bTripDetected = 0; ConfigurePWM(); } } } void IRQ_Handler(void) __irq // Unused in this application { unsigned long IRQSTATUS = 0; IRQSTATUS = IRQSTA; // Read off IRQSTA register if ((IRQSTATUS BIT17) == BIT17) //If PWM trip interrupt source { bTripDetected = 1; // Set flag to re configure the PWM block PWMCLRI = 0xFF; // Clear the PWM trip interrupt source } } void ConfigurePWM(void) { //Configure PWM0 for 20khz duty cycle // P0.4 PWM0COM0 = 0x80; // Configure PWM0 output high trigger time PWM0COM1 = 0xFF; // Configure PWM0 output Low trigger time // PWM0COM2 = 0x80; // Configure PWM1 output low trigger time PWM0LEN = 0xFF; // Configure PWM1 output high trigger time /* //Configure PWM2 for 10khz duty cycle // P1.5 PWM1COM0 = 0xFF; // Configure PWM2 output high trigger time PWM1COM1 = 0x1FF; // Configure PWM2 output Low trigger time PWM1COM2 = 0xFF; // Configure PWM3 output low trigger time PWM1LEN = 0x1FF; // Configure PWM3 output high trigger time //Configure PWM4 for 40khz duty cycle // P2.1 PWM2COM0 = 0x40; // Configure PWM4 output high trigger time PWM2COM1 = 0x80; // Configure PWM4 output Low trigger time PWM2COM2 = 0x40; // Configure PWM5 output low trigger time PWM2LEN = 0x80; // Configure PWM6 output high trigger time */ } |
1个回答
出现PWM输出异常的原因可能是芯片在断电后重新上电时,部分寄存器的值没有恢复到默认状态。解决这个问题的方式是在初始化PWM前,先对相关寄存器进行恢复操作。
你可以尝试在程序的开头添加如下代码,将相关寄存器恢复到默认状态,然后再配置PWM输出: ``` void reset_registers(void) { // 将相关寄存器恢复到默认状态 PWMCON0 = 0; PWMCON1 = 0; PWMCON2 = 0; PWMTH0 = 0; PWMTH1 = 0; PWMTH2 = 0; PWMADR0 = 0; PWMADR1 = 0; PWMADR2 = 0; } int main(void) { // 调用恢复寄存器函数 reset_registers(); // 后续的代码继续配置和输出PWM信号 ... } ``` 通过执行上述代码,在重新上电后可以将相关寄存器恢复到默认状态,避免出现PWM输出异常的情况。 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
232 浏览 2 评论
《DNK210使用指南 -CanMV版 V1.0》第九章 打印输出实验
182 浏览 0 评论
stm32f407+ksz8863rlli概率性ping不通
883 浏览 1 评论
嵌入式学习-飞凌嵌入式ElfBoard ELF 1板卡-常见网络服务搭建之NFS服务搭建
439 浏览 0 评论
求助:辉芒微芯片 FDM B11GBMH 的信息及开发环境安装
512 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
11323 浏览 31 评论
GMT+8, 2024-9-29 23:14 , Processed in 0.467366 second(s), Total 42, Slave 36 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
