您好,我在研发过程中,使用AD9963芯片,在XILINX的EDK开发工具中利用SDK对其进行配置,配置情况如下:
* Default AD9963 configuration: -Full-duplex mode (Tx data on TXD port, Rx data on TRXD port) -Power up everything except: -DAC12A, DAC12B, AUXADC (all unconnected on PCB) -DLL -Clocking: -DLL disabled -ADC clock = DAC clock = ext clock (nominally 80MHz) -Tx path: -Data in 2's complement (NOTE: datasheet bug!) -TXCLK is input at TXD sample rate -TXD is DDR, I/Q interleaved, I first -Tx interpolation filters bypassed -Tx gains: -Linear gain set to 100% -Linear-in-dB gain set to -3dB -DAC RSET set to 100% -Tx DCO DACs: -Enabled, configured for [0,+2]v range -Set to mid-scale output (approx equal to common mode voltage of I/Q diff pairs) -Rx path: -TRXCLK is output at TRXD sample rate -TRXD is DDR, I/Q interleaved, I first -Decimation filter bypassed -RXCML output enabled (used by ADC driver diff amp) -ADC common mode buffer off (required for DC coupled inputs) -Rx I path negated digitally (to match swap of p/n traces on PCB) */ 通过读取AD9963的寄存器的可以验证其寄存器都已经正确配置了。用示波器观察信号,测得时钟频率正确,DAC的TXD port有信号输入,但是DAC一直没有信号输出。 请问可能是什么原因造成这种现象的呢?有什么排查的方法吗? 望各位大神指教。。。。。。 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
为什么在频率为10^3 Hz处,产生的相移就可以确定约为-90度
674 浏览 1 评论
【高手问答】电路的功能是为了0.6v到40v之间调压,运放发热严重
3081 浏览 8 评论
USB3.0 工业相机的传输速率是否受到电脑主板某些硬件的限制?
1164 浏览 0 评论
2360 浏览 1 评论
1314 浏览 0 评论
GMT+8, 2024-12-22 09:56 , Processed in 0.567283 second(s), Total 73, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
