使用ADSP-408F评估板,设置PWM,系统时钟为100MHz,PWM 的频率为10KHz,但是在示波器只能看到PWM_SYNC信号,而PPWM0_AH/AL,PWM0_BH/BL,PWM0_CH/CL,没有脉冲,下面是程序,请帮助查看一下,那里有问题呢?
void SetupPWM(void){ /***************************************************************************** Function: SetupPWM Parameters: None Returns: None Notes: Setup of 3 phase PWM timer *****************************************************************************/ static ADI_PWM_RESULT result; uint32_t temp = 0; result = adi_pwm_Open(PWM_DEV, PwmMemory, ADI_PWM_MEMORY_SIZE, hPWM, PwmCallback, NULL); // Open driver temp = (uint32_t)(fsysclk / (2u * F_SW)); // Calculate switching period as number of sys clocks (up-down counter) result = adi_pwm_SetReferencePeriod(hPWM, temp); temp = (uint32_t)((fsysclk * DEAD_TIME) / 2u); // Calculate dead time period as number of sys clocks (up-down counter) result = adi_pwm_SetDeadtime(hPWM, temp); temp = (uint32_t)(fsysclk * SYNC_PULSE_WIDTH); // Calculate sync pulse width as number of sys clocks (up-down counter) result = adi_pwm_SetSyncWidth(hPWM, temp); result = adi_pwm_ExtSyncEnable(hPWM, false, false); // Internal sync used result = adi_pwm_SetIntSyncTimerMode(hPWM, ADI_PWM_TIMER0); // Use timer 0 to generate sync. result = adi_pwm_SetPulseMode(hPWM, ADI_PWM_CHANNEL_A, ADI_PWM_HIGH_SIDE, ADI_PWM_PULSE_SYMMETRICAL); // Use symmetrical PWM on all channels result = adi_pwm_SetPulseMode(hPWM, ADI_PWM_CHANNEL_A, ADI_PWM_LOW_SIDE, ADI_PWM_PULSE_SYMMETRICAL); result = adi_pwm_SetPulseMode(hPWM, ADI_PWM_CHANNEL_B, ADI_PWM_HIGH_SIDE, ADI_PWM_PULSE_SYMMETRICAL); result = adi_pwm_SetPulseMode(hPWM, ADI_PWM_CHANNEL_B, ADI_PWM_LOW_SIDE, ADI_PWM_PULSE_SYMMETRICAL); result = adi_pwm_SetPulseMode(hPWM, ADI_PWM_CHANNEL_C, ADI_PWM_HIGH_SIDE, ADI_PWM_PULSE_SYMMETRICAL); result = adi_pwm_SetPulseMode(hPWM, ADI_PWM_CHANNEL_C, ADI_PWM_LOW_SIDE, ADI_PWM_PULSE_SYMMETRICAL); result = adi_pwm_SetTimerMode(hPWM, ADI_PWM_CHANNEL_A, false); // Use Timer 0 as reference for all channels result = adi_pwm_SetTimerMode(hPWM, ADI_PWM_CHANNEL_B, false); result = adi_pwm_SetTimerMode(hPWM, ADI_PWM_CHANNEL_C, false); result = adi_pwm_SetLowSideMode(hPWM, ADI_PWM_CHANNEL_A, false); // LS is inverse of HS on all channels - no need to update LS dutys result = adi_pwm_SetLowSideMode(hPWM, ADI_PWM_CHANNEL_B, false); result = adi_pwm_SetLowSideMode(hPWM, ADI_PWM_CHANNEL_C, false); result = adi_pwm_SetOutputPolarity(hPWM, ADI_PWM_CHANNEL_A, ADI_PWM_HIGH_SIDE, false); // Set all outputs to active low result = adi_pwm_SetOutputPolarity(hPWM, ADI_PWM_CHANNEL_A, ADI_PWM_LOW_SIDE, false); result = adi_pwm_SetOutputPolarity(hPWM, ADI_PWM_CHANNEL_B, ADI_PWM_HIGH_SIDE, false); result = adi_pwm_SetOutputPolarity(hPWM, ADI_PWM_CHANNEL_B, ADI_PWM_LOW_SIDE, false); result = adi_pwm_SetOutputPolarity(hPWM, ADI_PWM_CHANNEL_C, ADI_PWM_HIGH_SIDE, false); result = adi_pwm_SetOutputPolarity(hPWM, ADI_PWM_CHANNEL_C, ADI_PWM_LOW_SIDE, false); result = adi_pwm_SetTripEnable(hPWM, ADI_PWM_CHANNEL_A, ADI_PWM_TRIP0_SRC, true); // Enable Trip0 and trip on all channels result = adi_pwm_SetTripEnable(hPWM, ADI_PWM_CHANNEL_B, ADI_PWM_TRIP0_SRC, true); result = adi_pwm_SetTripEnable(hPWM, ADI_PWM_CHANNEL_C, ADI_PWM_TRIP0_SRC, true); result = adi_pwm_SetTripEnable(hPWM, ADI_PWM_CHANNEL_A, ADI_PWM_TRIP1_SRC, true); // Enable Trip1 and trip on all channels result = adi_pwm_SetTripEnable(hPWM, ADI_PWM_CHANNEL_B, ADI_PWM_TRIP1_SRC, true); result = adi_pwm_SetTripEnable(hPWM, ADI_PWM_CHANNEL_C, ADI_PWM_TRIP1_SRC, true); result = adi_pwm_SetTripMode(hPWM, ADI_PWM_CHANNEL_A, ADI_PWM_TRIP0_SRC, false); // Stop PWM and report fault at trip. Do not restart result = adi_pwm_SetTripMode(hPWM, ADI_PWM_CHANNEL_B, ADI_PWM_TRIP0_SRC, false); result = adi_pwm_SetTripMode(hPWM, ADI_PWM_CHANNEL_C, ADI_PWM_TRIP0_SRC, false); result = adi_pwm_SetTripMode(hPWM, ADI_PWM_CHANNEL_A, ADI_PWM_TRIP1_SRC, false); result = adi_pwm_SetTripMode(hPWM, ADI_PWM_CHANNEL_B, ADI_PWM_TRIP1_SRC, false); result = adi_pwm_SetTripMode(hPWM, ADI_PWM_CHANNEL_C, ADI_PWM_TRIP1_SRC, false); result = adi_pwm_InterruptEnable(hPWM, ADI_PWM_INTERRUPT_TIMER0, true); // Enable sync irq result = adi_pwm_InterruptEnable(hPWM, ADI_PWM_INTERRUPT_TRIP0, true); // Enable trip0 irq result = adi_pwm_InterruptEnable(hPWM, ADI_PWM_INTERRUPT_TRIP1, true); // Enable trip1 irq result = adi_pwm_OutputEnable(hPWM, ADI_PWM_CHANNEL_A, ADI_PWM_HIGH_SIDE, true); // Enable output pins result = adi_pwm_OutputEnable(hPWM, ADI_PWM_CHANNEL_A, ADI_PWM_LOW_SIDE, true); result = adi_pwm_OutputEnable(hPWM, ADI_PWM_CHANNEL_B, ADI_PWM_HIGH_SIDE, true); result = adi_pwm_OutputEnable(hPWM, ADI_PWM_CHANNEL_B, ADI_PWM_LOW_SIDE, true); result = adi_pwm_OutputEnable(hPWM, ADI_PWM_CHANNEL_C, ADI_PWM_HIGH_SIDE, true); result = adi_pwm_OutputEnable(hPWM, ADI_PWM_CHANNEL_C, ADI_PWM_LOW_SIDE, true); @@ result = adi_pwm_Enable(hPWM, true); // Enable PWM } 下面是v021有关PWM的配置,结果什么都没有看到,不知为什么? void SetupPWM(void){ /***************************************************************************** Function: SetupPWM Parameters: None Returns: None Notes: Setup of 3 phase PWM timer *****************************************************************************/ uint32_t temp = 0; temp = (uint32_t)(fsysclk / (2u * F_SW)); // Calculate switching period as number of sys clocks (up-down counter) *pREG_PWM0_TM0 = (uint16_t)temp; temp = (uint32_t)((fsysclk * DEAD_TIME) / 2u); // Calculate dead time period as number of sys clocks (up-down counter) *pREG_PWM0_DT = (uint16_t)temp; temp = (uint32_t)(fsysclk * SYNC_PULSE_WIDTH); // Calculate sync pulse width as number of sys clocks (up-down counter) *pREG_PWM0_SYNC_WID = (uint16_t)temp; *pREG_PWM0_CTL |= (ENUM_PWM_CTL_INTSYNC_0 | ENUM_PWM_CTL_INTSYNC | ENUM_PWM_CTL_EMURUN_DIS); *pREG_PWM0_ACTL |= (ENUM_PWM_SYM_LO | ENUM_PWM_SYM_HI | ENUM_PWM_XOVR_DIS); *pREG_PWM0_BCTL |= (ENUM_PWM_SYM_LO | ENUM_PWM_SYM_HI | ENUM_PWM_XOVR_DIS); *pREG_PWM0_CCTL |= (ENUM_PWM_SYM_LO | ENUM_PWM_SYM_HI | ENUM_PWM_XOVR_DIS); *pREG_PWM0_CHANCFG |= (ENUM_PWM_CHANCFG_REFTMRA_0 | ENUM_PWM_CHANCFG_LOA_INVHI | ENUM_PWM_CHANCFG_AH_ACTLO | ENUM_PWM_CHANCFG_CHOPAH_DIS | ENUM_PWM_CHANCFG_HPAH_DIS | ENUM_PWM_CHANCFG_AL_ACTLO | ENUM_PWM_CHANCFG_CHOPAL_DIS); *pREG_PWM0_CHANCFG |= (ENUM_PWM_CHANCFG_REFTMRB_0 | ENUM_PWM_CHANCFG_LOB_INV | ENUM_PWM_CHANCFG_BH_ACTLO | ENUM_PWM_CHANCFG_CHOPBH_DIS | ENUM_PWM_CHANCFG_HPBH_DIS | ENUM_PWM_CHANCFG_BL_ACTLO | ENUM_PWM_CHANCFG_CHOPBL_DIS); *pREG_PWM0_CHANCFG |= (ENUM_PWM_CHANCFG_REFTMRC_0 | ENUM_PWM_CHANCFG_LOC_INVHI | ENUM_PWM_CHANCFG_CH_ACTLO | ENUM_PWM_CHANCFG_CHOPCH_DIS | ENUM_PWM_CHANCFG_HPCH_DIS | ENUM_PWM_CHANCFG_CL_ACTLO | ENUM_PWM_CHANCFG_CHOPCL_DIS); *pREG_PWM0_TRIPCFG |= (ENUM_PWM_TRIPCFG_TRIP0A_EN |ENUM_PWM_TRIPCFG_TRIP1A_EN | ENUM_PWM_TRIPCFG_TRIP0A_FLT | ENUM_PWM_TRIPCFG_TRIP1A_FLT) | (ENUM_PWM_TRIPCFG_TRIP0B_EN |ENUM_PWM_TRIPCFG_TRIP1B_EN | ENUM_PWM_TRIPCFG_TRIP0B_FLT | ENUM_PWM_TRIPCFG_TRIP1B_FLT) | (ENUM_PWM_TRIPCFG_TRIP0C_EN |ENUM_PWM_TRIPCFG_TRIP1C_EN | ENUM_PWM_TRIPCFG_TRIP0C_FLT | ENUM_PWM_TRIPCFG_TRIP1C_FLT); *pREG_PWM0_IMSK |= (ENUM_PWM_IMSK_TRIP0_UMSK | ENUM_PWM_IMSK_TRIP1_UMSK | ENUM_PWM_IMSK_PER0_UMSK); adi_int_InstallHandler((IRQn_Type)INTR_PWM0_TRIP, PWM0_TRIP_ISR, 0, true); NVIC_SetPriority((IRQn_Type)INTR_PWM0_TRIP, 1); NVIC_EnableIRQ((IRQn_Type)INTR_TIMER0_TMR1); adi_int_InstallHandler((IRQn_Type)INTR_PWM0_SYNC, PWM0_SYNC_ISR, 0, true); NVIC_SetPriority((IRQn_Type)INTR_PWM0_SYNC, 0); NVIC_EnableIRQ((IRQn_Type)INTR_PWM0_SYNC); *pREG_PWM0_ACTL |= (ENUM_PWM_HI_EN | ENUM_PWM_LO_EN); *pREG_PWM0_BCTL |= (ENUM_PWM_HI_EN | ENUM_PWM_LO_EN); *pREG_PWM0_CCTL |= (ENUM_PWM_HI_EN | ENUM_PWM_LO_EN); *pREG_PWM0_CTL |= ENUM_PWM_CTL_PWM_EN; } |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
252 浏览 0 评论
5V供电情况下JFET前级放大电路怎么实现,JFET能不能先将信号放大到2-3mv,然后在用单运放进行1000倍左右放大?
2020 浏览 0 评论
1209 浏览 0 评论
USB Type-C的双角色端口(DRP)我这样设计可以吗?
752 浏览 0 评论
1911 浏览 0 评论
/9
GMT+8, 2025-12-2 02:38 , Processed in 0.670072 second(s), Total 71, Slave 53 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1851
