这是我的错误:
注: 执行设置环境任务 注: 执行运行队列任务 ERROR: 设备- 树- xilinx gitAUTOINC b7466bbeee-r0 do_ config: 函数失败 : do_ configure (log file is at / home/ yl/xlinx/petalinux/ hdmi_zed/building/tmp/work/plnx_zynq7-xxxlinx-gnueabi/device-tree/xlinx gitAUTOINC b7466bbeee-r0/temp/log.do_configres. 4459) ERROR: 储存在以下文件中的故障记录:/home/ylh/xilinx/petalinux/hdmi_zed/building/tmp/work/plnx_zynq7-xlinx-linux-gnueabi/device-tree/xilinx gitAUTOINC b7466bbeee-r0/temp/log.do_configure.4459 日志数据如下: DEBUG: 执行 shell 函数 do_ configure MISC_ARG是 -hdf_type hdf -yamlconf / home/ylh/xilinx/petalinux/hdmi_zed/building/tmp/work/plnx_zynq7-xxlinx-linux-gnueabi/device-tree/xilinx gitAUTOINC b7466bbeee-r0/deevice-tree.yaml 。 | APP_ARG is -app "device-tree" 使用以下来源的 xsct: / home/ ylh/ xilinx/ petalinux/ tools/ xsct/ SDK/ 18.3/ bin/ xsct | cmd is: xsct -sdx -nodisp /home/ylh/xilinx/petalinux/hdmi_zed/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/device-tree/xilinx+gitAUTOINC+b7466bbeee-r0/dtgen.tcl -ws /home/ylh/xilinx/petalinux/hdmi_zed/build/../components/plnx_workspace/device-tree -pname device-tree -rp /home/ylh/xilinx/petalinux/hdmi_zed/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/device-tree/xilinx+gitAUTOINC+b7466bbeee-r0/git -processor ps7_cortexa9_0 -hdf /home/ylh/xilinx/petalinux/hdmi_zed/build/tmp/deploy/images/plnx-zynq7/Xilinx-plnx-zynq7.hdf -arch 32 -app "device-tree" -hdf_type hdf -yamlconf /home/ylh/xilinx/petalinux/hdmi_zed/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/device-tree/xilinx+gitAUTOINC+b7466bbeee-r0/device-tree.yaml INFO: [Hsi 55-1698] 存放处装载时间: 0 秒 警告:不支持 pl_ck: | WARNING: Interrupt pin "s2mm_introut" of IP block: "axi_hdmi_dma" is not connected to any interrupt controller | 警告: 超音速沒有saxi_aclock 警告:不支持 pl_ck: 警告: 超音速沒有saxi_aclock 警告:不支持 pl_ck: | WARNING: Interrupt pin "interrupt" of IP block: "v_tpg_0" is not connected to any interrupt controller | iror: exi_hdmi_dma: s2mm_ introut 端口未连接 ERROR: [Hsi 55-1545] 问题运行 tcl 命令 *sw_axi_vdma:: generate: EROR: exi_ hdmi_dma: s2mm_ introut 端口没有连接 执行时 | "error "ERROR: ${drv_handle}: s2mm_introut port is not connected"" | (procedure "::sw_axi_vdma::generate" line 69) 由内部援引 | "::sw_axi_vdma::generate axi_hdmi_dma" 错误: [Hsi 55-1442] 运行 TCL 程序时产生错误 () 生成目标失败 执行时 | "error "generate_target failed"" 由内部援引 | "if {[catch {hsi generate_target -dir $project} res]} { | error "generate_target failed" | }" | (file "/home/ylh/xilinx/petalinux/hdmi_zed/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/device-tree/xilinx+gitAUTOINC+b7466bbeee-r0/dtgen.tcl" line 38) | WARNING: /home/ylh/xilinx/petalinux/hdmi_zed/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/device-tree/xilinx+gitAUTOINC+b7466bbeee-r0/temp/run.do_configure.4459:1 exit 1 from 'eval xsct -sdx -nodisp /home/ylh/xilinx/petalinux/hdmi_zed/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/device-tree/xilinx+gitAUTOINC+b7466bbeee-r0/dtgen.tcl -ws /home/ylh/xilinx/petalinux/hdmi_zed/build/../components/plnx_workspace/device-tree -pname device-tree -rp /home/ylh/xilinx/petalinux/hdmi_zed/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/device-tree/xilinx+gitAUTOINC+b7466bbeee-r0/git -processor ps7_cortexa9_0 -hdf /home/ylh/xilinx/petalinux/hdmi_zed/build/tmp/deploy/images/plnx-zynq7/Xilinx-plnx-zynq7.hdf -arch 32 ${APP_ARG} ${MISC_ARG}' ERROR: 函数失败 : do_ config( log file is at / home/ ylh/ xilinx/ petalinux/ hdmi_ zed/ building/ tmp/ work/ plnx_zynq7- cxlinx- linux- gnueabi/ device- tree/xlinx gitAUTOINC b7466bbeee- r0/temp/log.do_ configure 4459) 。 ERROR: Task ((bb:do_configit)) failed with exit code '1' NOTE: Tasks Summary: Attempted 2237 tasks of which 1747 didn't need to be rerun and 1 failed. 摘要: 1 任务失败 : (bb:do_configit) 摘要:显示1条错误信息,返回非零退出代码。 错误: 构建工程失败 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
21056 浏览 1 评论
1128 浏览 0 评论
硬创大赛项目专访 | 田奕鑫:专注细分领域创新,我们和行业巨头“化敌为友”
89412 浏览 1 评论
硬创大赛项目专访 | 王猛:专研降噪技术,让中国的黑科技产品服务全球用户
24227 浏览 1 评论
9276 浏览 3 评论
GMT+8, 2024-10-2 21:16 , Processed in 0.424570 second(s), Total 41, Slave 35 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
