在SE5上按照官方教程运行yolact时出现错误[error] Cannot reset_dev_data when own_dev_data is true.该怎么解决呢?
linaro@BM1684-180:/data/yolact_object_demo/python$ python3 yolact_bmcv.py --cfgfile configs/yolact_base.cfg --model ../data/models/yolact_base_54_800000_fp32_b1.bmodel --input_path ../data/images/ DEBUG 07/25/2023 08:46:45.843 548337385488 sophon_inference.py:23] __init__ - 1 TPUs Detected, using TPU 0 [BMRT][bmcpu_setup:209] INFO : cpu.so already exist, don't dlopen bmcpu init: skip cpu_user_defined libusercpu.so already exist, user cpu layer is enable open usercpu.so, init user_cpu_init [BMRT][load_bmodel:784] INFO : Loading bmodel from [../data/models/yolact_base_54_800000_fp32_b1.bmodel]. Thanks for your patience... [BMRT][load_bmodel:748] INFO : pre net num: 0, load net num: 1 WARNING 07/25/2023 08:46:46.177 548337385488 sophon_inference.py:28] __init__ - 1 graphs in ../data/models/yolact_base_54_800000_fp32_b1.bmodel, using yolact_base INFO 07/25/2023 08:46:46.180 548337385488 sophon_inference.py:101] __init__ - =========================================== INFO 07/25/2023 08:46:46.181 548337385488 sophon_inference.py:102] __init__ - BModel: ../data/models/yolact_base_54_800000_fp32_b1.bmodel INFO 07/25/2023 08:46:46.181 548337385488 sophon_inference.py:103] __init__ - Input : {'x.1': [1, 3, 550, 550]}, {'x.1': Dtype.BM_FLOAT32} INFO 07/25/2023 08:46:46.181 548337385488 sophon_inference.py:104] __init__ - Output: {'proto_out0.1': [1, 138, 138, 32], 'loc.1': [1, 19248, 4], 'conf.1': [1, 19248, 81], 'mask.1': [1, 19248, 32]}, {'proto_out0.1': Dtype.BM_FLOAT32, 'loc.1': Dtype.BM_FLOAT32, 'conf.1': Dtype.BM_FLOAT32, 'mask.1': Dtype.BM_FLOAT32} INFO 07/25/2023 08:46:46.181 548337385488 sophon_inference.py:105] __init__ - =========================================== ../data/models/yolact_base_54_800000_fp32_b1.bmodel is loaded. Open /dev/jpu successfully, device index = 0, jpu fd = 27, vpp fd = 28 [2023-07-25 08:46:46.449] [error] Cannot reset_dev_data when own_dev_data is true. |
只有小组成员才能发言,加入小组>>
H264硬编码CVI_VENC_StartRecvFrame报错的原因?怎么解决?
971浏览 2评论
522浏览 1评论
639浏览 1评论
642浏览 1评论
使用sophon-demo_v0.1.8_dbb4632_20231116下面的YOLOv8中的yolov8_bmcv历程出现段错误的原因?
858浏览 1评论
/9
GMT+8, 2025-12-2 00:33 , Processed in 0.572981 second(s), Total 69, Slave 52 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
447
