电子发烧友论坛|
从GitHub - starfive-tech/Tools 下载的Tools中并没有create_sbl,按照readme,也能编译一个u-boot-spl.bin.normal.out文件,然后通过软件技术参考手册重新编译的visionfive2_fw_payload.img和u-boot-spl.bin.normal.out文件,通过“恢复Bootloader”的方式更新后,无法boot起来。
在论坛上,找到一个官方提供的visionfive2_fw_payload.img和u-boot-spl.bin.normal.out文件,下载后,能正常boot起来。 我需要在M模式下配置寄存器,要改opensbi程序或者uboot程序,请问有谁遇到过吗? Net: eth0: ethernet@16030000, eth1: ethernet@16040000 switch to partitions #0, OK mmc1 is current device found device 1 bootmode flash device 1 Can’t set block device Failed to load ‘/boot/uEnv.txt’ Hit any key to stop autoboot: 2 1 0 Can’t set block device Importing environment from mmc1 … Warning: Input data exceeds 1048576 bytes - truncated Info: input data size = 1048578 = 0x100002 Error: “boot2” not defined Can’t set block device Warning: defaulting to text format switch to partitions #0, OK mmc1 is current device Scanning mmc 1:2… Found /boot/extlinux/extlinux.conf Retrieving file: /boot/extlinux/extlinux.conf 823 bytes read in 8 ms (99.6 KiB/s) U-Boot menu 1: Debian GNU/Linux bookworm/sid 5.15.0-starfive 2: Debian GNU/Linux bookworm/sid 5.15.0-starfive (rescue target) Enter choice: 1: Debian GNU/Linux bookworm/sid 5.15.0-starfive Retrieving file: /boot/initrd.img-5.15.0-starfive 9684953 bytes read in 425 ms (21.7 MiB/s) Retrieving file: /boot/vmlinuz-5.15.0-starfive 8015200 bytes read in 353 ms (21.7 MiB/s) append: root=/dev/mmcblk1p3 rw console=tty0 console=ttyS0,115200 earlycon rootwait stmmaceth=chain_mode:1 selinux=0 Retrieving file: /boot/dtbs/starfive/starfive_visionfive2.dtb Failed to load ‘/boot/dtbs/starfive/starfive_visionfive2.dtb’ kernel_comp_addr_r or kernel_comp_size is not provided! 2: Debian GNU/Linux bookworm/sid 5.15.0-starfive (rescue target) Retrieving file: /boot/initrd.img-5.15.0-starfive 9684953 bytes read in 425 ms (21.7 MiB/s) Retrieving file: /boot/vmlinuz-5.15.0-starfive 8015200 bytes read in 353 ms (21.7 MiB/s) append: root=/dev/mmcblk1p3 rw console=tty0 console=ttyS0,115200 earlycon rootwait stmmaceth=chain_mode:1 selinux=0 single Retrieving file: /boot/dtbs/starfive/starfive_visionfive2.dtb Failed to load ‘/boot/dtbs/starfive/starfive_visionfive2.dtb’ kernel_comp_addr_r or kernel_comp_size is not provided! SCRIPT FAILED: continuing… libfdt fdt_check_header(): FDT_ERR_BADMAGIC Card did not respond to voltage select! : -110 ** Unable to read file ubootefi.var ** Failed to load EFI variables Scanning mmc 1:3… libfdt fdt_check_header(): FDT_ERR_BADMAGIC starfive_pcie pcie@2C000000: Starfive PCIe bus probed. PCI: Failed autoconfig bar 10 ethernet@16030000 Waiting for PHY auto negotiation to complete… TIMEOUT ! phy_startup() failed: -110FAILED: -110ethernet@16040000 Waiting for PHY auto negotiation to complete… TIMEOUT ! phy_startup() failed: -110FAILED: -110ethernet@16030000 Waiting for PHY auto negotiation to complete… |
只有小组成员才能发言,加入小组>>
VisionFive2中openplc页面无法打开怎么解决?
1430 浏览 1 评论
第一次启动StarFive VisionFive 2, U-Boot总是报错,为什么?
1298 浏览 1 评论
VisionFive 2 生态进展双周报(1.1-1.31)
2398 浏览 0 评论
JH-7110现已支持AMP双系统(Linux + RT-Thread)
2121 浏览 0 评论
VisionFive 2 生态进展双周报(9.29-10.16)
1062 浏览 0 评论
872浏览 2评论
896浏览 2评论
在starvision2上移植FreeRTOS,objdump后发现static变量的地址是0,怎么解决?
384浏览 2评论
394浏览 2评论
SPI驱动模块init后probe函数并不会打印信息是哪里出了问题?
379浏览 2评论
/9
GMT+8, 2025-12-2 02:47 , Processed in 1.021992 second(s), Total 90, Slave 73 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1138
