Model Optimizer version: 2019.3.0-375-g332562022
[ ERROR ] ------------------------------------------------- [ ERROR ] ----------------- INTERNAL ERROR ---------------- [ ERROR ] Unexpected exception happened. [ ERROR ] Please contact Model Optimizer developers and forward the following information: [ ERROR ] 'Graph' object has no attribute 'node' [ ERROR ] Traceback (most recent call last): File "/opt/intel/openvino_2019.3.334/deployment_tools/model_optimizer/mo/main.py", line 302, in main return driver(argv) File "/opt/intel/openvino_2019.3.334/deployment_tools/model_optimizer/mo/main.py", line 261, in driver custom_layers_mapping_path=custom_layers_mapping_path) File "/opt/intel/openvino_2019.3.334/deployment_tools/model_optimizer/mo/pipeline/caffe.py", line 65, in driver graph, original_shapes = loader.caffe_pb_to_nx(proto, model) File "/opt/intel/openvino_2019.3.334/deployment_tools/model_optimizer/mo/front/caffe/loader.py", line 294, in caffe_pb_to_nx graph.add_node(layer.name, pb=layer, model_pb=model_layer, kind='op', type='Parameter') File "/opt/intel/openvino_2019.3.334/deployment_tools/model_optimizer/mo/graph/graph.py", line 505, in add_node node.update_node() File "/opt/intel/openvino_2019.3.334/deployment_tools/model_optimizer/mo/graph/graph.py", line 470, in update_node in_ports_count = self.in_ports_count if self.has_valid('in_ports_count') else None File "/opt/intel/openvino_2019.3.334/deployment_tools/model_optimizer/mo/graph/graph.py", line 161, in has_valid return self.has(k) and not self.graph.node[self.node][k] is None File "/opt/intel/openvino_2019.3.334/deployment_tools/model_optimizer/mo/graph/graph.py", line 158, in has return k in self.graph.node[self.node] AttributeError: 'Graph' object has no attribute 'node' [ ERROR ] ---------------- END OF BUG REPORT -------------- [ ERROR ] ------------------------------------------------- 模型优化器与 Python * NetworkX package 版本2.4 存在兼容性问题。 |
1个回答
只有小组成员才能发言,加入小组>>
2个成员聚集在这个小组
加入小组172浏览 1评论
在DL Workbench 2022.1中转换模型时遇到的错误问题
244浏览 1评论
使用OpenVINO推断时收到ImportError: DLL load failed while importing ie_api错误
365浏览 1评论
如何将PyTorch模型与OpenVINO trade结合使用?
352浏览 1评论
求助,无法找到rdquo;OpenCV ldquo提供的封装配置文件求分享
429浏览 1评论
GMT+8, 2024-9-29 05:46 , Processed in 0.710983 second(s), Total 98, Slave 82 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
