电子发烧友论坛|
刚才看到一个方案,说是屏幕驱动用EBI,不懂,问问,M051有这个接口吗
External Bus Interface (EBI) 6.21.1 Overview This chip is equipped with an external bus interface (EBI) for external device use. To save the connections between an external device and a chip, EBI is operating at address bus and data bus multiplex mode. The EBI supports two chip selects that can connect two external devices with different timing setting requirements. 6.21.2 Features Supports up to two memory banks Supports dedicated external chip select pin with polarity control for each bank Supports accessible space up to 1 Mbytes for each bank, actually external addressable space is dependent on package pin out Supports 8-/16-bit data width Supports byte write in 16-bit data width mode Supports Address/Data multiplexed Mode Supports Timing parameters individual adjustment for each memory block Supports LCD interface i80 mode Supports PDMA mode Supports variable external bus base clock (MCLK) which based on HCLK Supports configurable idle cycle for different access condition: Idle of Write command finish (W2X) and Idle of Read-to-Read (R2R) Supports address bus and data bus separate mode |
1个回答
ort for multiple memories such as SRAM, SDRAM, Flash and ROM Configurable data width (8-bit/16-bit/32-bit) Configurable timing parameter for different external devices Automatic address generation and cycle control programmable wait state control for slow devices Support for burst mode operation for high-speed data transfer
M051 MCU does have an EBI interface. You can refer to the user manual or datasheet of the M051 MCU to get more information about the EBI interface and its configurations. Additionally, you can also find some tutorials and code examples on the internet for how to use the EBI interface in the M051 MCU. |
只有小组成员才能发言,加入小组>>
1599 浏览 0 评论
imx6ull 和 lan8742 工作起来不正常, ping 老是丢包
4738 浏览 0 评论
4229 浏览 9 评论
3822 浏览 16 评论
4398 浏览 1 评论
4210浏览 3评论
2379浏览 0评论
3393浏览 0评论
1158浏览 0评论
2843浏览 0评论
/9
GMT+8, 2025-12-2 01:36 , Processed in 0.761803 second(s), Total 74, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
186
