我为 ESP8266 安装了 Arduino IDE,最近用它编译了另一个程序。我正在开始另一个项目,并从一些 Arduino 代码开始。我有一些 ESP8266 是从另一个项目中遗留下来的,我认为这对他们来说是一个完美的项目。当我选择像 Uno 这样的 Arduino 处理器时,代码编译得很好,但不会在我选择的任何 ESP8266 上编译。我不太熟悉这些功能,所以我似乎无法确定它的定义位置......
代码:全选#include #include // cbi/sbi definition #if defined(UCSRB) && defined(UBRRL) volatile byte * const _ucsrb = &UCSRB; #else volatile byte * const _ucsrb = &UCSR0B; #endif // Definitions for the hardware Serial port, used for Nexstar auxBus #define AUXBUS_RX_PIN 0 #define AUXBUS_TX_PIN 1 #define AUXBUS_BUSY_PIN 4 // The RTS (aka. "Busy") line for Nexstar auxBus #define auxBus Serial static inline void auxBus_enable_tx() { sbi(*_ucsrb, TXEN0); } static inline void auxBus_disable_tx() { cbi(*_ucsrb, TXEN0); } #define MINUS_PIN 9 #define PLUS_PIN 8 #define LED_PIN 13 同样,在没有任何更改的情况下,它在 Arduino 处理器上编译但在 ESP8266 处理器上失败并出现以下错误: 代码:全选Arduino: 1.8.13 (Windows 10), Board: "Generic ESP8266 Module, 80 MHz, Flash, Legacy (new can return nullptr), All SSL ciphers (most compatible), dtr (aka nodemcu), 26 MHz, 40MHz, DOUT (compatible), 1MB (FS:64KB OTA:~470KB), 2, nonos-sdk 2.2.1+100 (190703), v2 Lower Memory, Disabled, None, Only Sketch, 115200" celestron_motor_focuser_hand_controller:7:35: error: 'UCSR0B' was not declared in this scope volatile byte * const _ucsrb = &UCSR0B; \celestron_motor_focuser_hand_controller\celestron_motor_focuser_hand_controller.ino: In function 'void auxBus_enable_tx()': celestron_motor_focuser_hand_controller:16:64: error: 'TXEN0' was not declared in this scope static inline void auxBus_enable_tx() { sbi(*_ucsrb, TXEN0); } ^ celestron_motor_focuser_hand_controller:16:69: error: 'sbi' was not declared in this scope static inline void auxBus_enable_tx() { sbi(*_ucsrb, TXEN0); } ^ \celestron_motor_focuser_hand_controller\celestron_motor_focuser_hand_controller.ino: In function 'void auxBus_disable_tx()': celestron_motor_focuser_hand_controller:17:64: error: 'TXEN0' was not declared in this scope static inline void auxBus_disable_tx() { cbi(*_ucsrb, TXEN0); } ^ celestron_motor_focuser_hand_controller:17:69: error: 'cbi' was not declared in this scope static inline void auxBus_disable_tx() { cbi(*_ucsrb, TXEN0); } ^ exit status 1 'UCSR0B' was not declared in this scope |
1个回答
ESP8266和Arduino之间存在一些差异,包括处理器架构、内存和性能等方面。因此,编写在Arduino上编译的代码可能需要进行一些修改才能在ESP8266上编译和运行。在你的情况下,无法确定错误的定义位置,这可能是由于编写的代码在ESP8266上无法识别某些处理器指令或库。您需要查看您的代码,了解它是否涉及与ESP8266不兼容的指令或库,并进行相应的修改以适应ESP8266。同时,您还可以尝试使用不同的编译工具或库,以查看它们是否可以在ESP8266上编译和运行您的代码。
只有小组成员才能发言,加入小组>>
393 浏览 0 评论
954 浏览 0 评论
1679 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1337 浏览 1 评论
1236 浏览 1 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1257浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
931浏览 3评论
2345浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2533浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1054浏览 2评论
/9
GMT+8, 2025-12-4 11:33 , Processed in 0.471501 second(s), Total 44, Slave 37 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
477
