我有一块 ESP-12F 板。它应休眠直到获得中断(GPIO),然后立即通过 WIFI 通知服务器,然后再次休眠 - 直到下一个中断。
我已经创建了一个用于测试的示例程序,请参阅 。 它通过 UDP 发送两条消息,然后休眠 5 秒并再次发送两条消息: 代码:全选 while (1) { for (int cnt=0; cnt < 2; cnt++) { send_udp_packet(); sleep(1); } ESP_ERROR_CHECK( esp_wifi_stop() ); ESP_ERROR_CHECK( esp_sleep_enable_timer_wakeup(5*1000*1000) ); ESP_LOGE(TAG, " ---> enter light sleep"); ESP_ERROR_CHECK( esp_light_sleep_start() ); ESP_LOGE(TAG, " ---> returned from light sleep"); ESP_ERROR_CHECK( esp_wifi_start() ); sleep(6); } 在进入 light_sleep 之前,每次都会建立 WIFI 连接(100%)。但是在 light_sleep 之后,有时会失败(有时它可以正常工作 70 个周期 - 但有时会在第二次睡眠时失败): 代码:全选14:44:10 E (24108) app: ---> returned from light sleep 14:44:10 I (24115) app: SYSTEM_EVENT_STA_START 14:44:16 E (30112) app: Error occured during sending: Host is unreachable/118 14:44:17 E (31111) app: Error occured during sending: Host is unreachable/118 14:44:18 E (32112) app: ---> enter light sleep 当它工作正常时,输出如下所示: 代码:全选14:43:57 E (10995) app: ---> returned from light sleep 14:43:57 I (11002) app: SYSTEM_EVENT_STA_START 14:43:57 I (11128) wifi: state: 0 -> 2 (b0) 14:43:57 I (11135) wifi: state: 2 -> 3 (0) 14:43:57 I (11145) wifi: state: 3 -> 5 (10) 14:43:57 I (11148) wifi: pm start, type: 1 14:43:57 I (11180) app: SYSTEM_EVENT_STA_CONNECTED 14:43:58 I (12171) event: sta ip: 192.168.178.200, mask: 255.255.255.0, gw: 192.168.178.1 14:43:58 I (12181) app: SYSTEM_EVENT_STA_GOT_IP 14:44:03 I (17006) app: Message 2 sent 14:44:04 I (18006) app: Message 3 sent 14:44:05 I (19003) wifi: state: 5 -> 0 (0) 14:44:05 I (19007) wifi: pm stop 14:44:05 I (19010) app: SYSTEM_EVENT_STA_DISCONNECTED 14:44:05 I (19018) app: SYSTEM_EVENT_STA_STOP 14:44:05 E (19103) app: ---> enter light sleep 这是相同的跟踪,当启用 wifi 调试时: 代码:全选14:57:55 E (10827) app: ---> returned from light sleep 14:57:55 I (10833) wifi: mode : sta (ec:fa:bc:a7:43:64) 14:57:55 I (10836) wifi: add if0 14:57:55 I (10839) app: SYSTEM_EVENT_STA_START 14:57:55 D (10843) wifi: first chan=1 14:57:55 D (10845) wifi: cnx_start_connect 50f 14:57:55 D (10851) wifi: scan_cancel 3 14:57:55 D (10855) wifi: scan_op_end 0 4 14:57:55 D (10859) wifi: enter scan_done 4838845 1 14:57:55 I (10865) wifi: scandone 14:57:55 D (10870) wifi: first chan=1 14:57:55 D (10874) wifi: cnx_start_handoff_cb 14:57:55 D (10879) wifi: failed 14:57:55 D (10882) wifi: scan start 4861963 14:57:55 D (10887) wifi: scan_inter_channel_timeout 1 14:57:55 D (10893) wifi: rd: chan=1 active max=11 14:57:55 D (10899) wifi: scan_op_start 2412 1 14:57:55 D (10904) wifi: rd: chan=1 active max=11 14:57:55 D (10910) wifi: scan_send_probe 14:57:55 D (10914) wifi: ucast probe 14:57:55 D (10918) wifi: send probe req on channel 1 bssid ff:ff:ff:ff:ff:ff ssid Eckbank 14:58:01 E (16842) app: Error occured during sending: Host is unreachable/118 14:58:02 E (17843) app: Error occured during sending: Host is unreachable/118 14:58:03 D (18842) wifi: scan_cancel 7 14:58:03 D (18844) wifi: scan_op_end 0 4 14:58:03 D (18846) wifi: enter scan_done 12827271 1 14:58:03 I (18849) wifi: scandone 14:58:03 D (18850) wifi: first chan=1 14:58:03 D (18852) wifi: cnx_start_handoff_cb 14:58:03 D (18855) wifi: failed 14:58:03 I (18859) wifi: del if0 14:58:03 I (18864) wifi: usl 14:58:03 D (18867) wifi: sul 0 0 14:58:03 E (18871) app: ---> enter light sleep 我正在使用分支“release/v3.3”中的“ESP8266_RTOS_SDK”以及“xtensa-lx106 1.22.0-100-ge567ec7”。 下载/安装。 我的代码有问题吗?我需要额外的睡眠吗?wifi代码是闭源的,真是可惜了! |
1个回答
可能的原因有以下几个:
1. WIFI 连接失败:可能是由于 WIFI 密码错误、WIFI网络不可用等原因导致连接失败。可以通过添加连接失败的处理程序来捕获连接错误并进行相应的处理。 2. 中断未触发:由于 GPIO 中断触发的唯一条件是外部事件的发生,如果外部事件没有发生,将无法触发中断。因此,如果连接失败,请确保 GPIO 中断已正确连接到外部事件。 3. 资源不足:ESP8266 具有有限的 RAM 和存储空间。当资源不足时,可能会导致连接失败或其他未知错误。可以尝试优化代码和减少内存使用来解决这个问题。 4. 电源问题:在低功耗模式下,电源可能会不稳定。这可能导致 ESP8266 的意外重启或其他问题。可以尝试添加额外的电容器或控制电源以解决这个问题。 综上所述,如果您的 ESP8266 在连接 WIFI 后经常失败,请依次排除以上可能的原因,并进行相应的处理。 |
只有小组成员才能发言,加入小组>>
461 浏览 0 评论
982 浏览 0 评论
1702 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1358 浏览 1 评论
1249 浏览 1 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1274浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
942浏览 3评论
2372浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2560浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1067浏览 2评论
/9
GMT+8, 2025-12-10 12:41 , Processed in 0.797663 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1609
