电子发烧友论坛|
嗨,
我有一个 Iduino ESP 13(带有 ESP 8266 芯片)。 我想将原来的AT固件升级到ESP-IDF提供的最新版本(当时是ESP8266-AT-V2.2.1.0)。 使用此命令行上传固件可以正常工作: 代码:全选esptool --chip auto --port COM4 --baud 115200 --before default_reset --after hard_reset write_flash --flash_mode dio --flash_freq 40m --flash_size 2MB 0x8000 partition_table/partition-table.bin 0x9000 ota_data_initial.bin 0x0 bootloader/bootloader.bin 0x10000 esp-at.bin 0xF0000 at_customize.bin 0xFC000 customized_partitions/client_ca.bin 0x106000 customized_partitions/mqtt_key.bin 0x104000 customized_partitions/mqtt_cert.bin 0x108000 customized_partitions/mqtt_ca.bin 0xF1000 customized_partitions/factory_param.bin 0xF8000 customized_partitions/client_cert.bin 0xFA000 customized_partitions/client_key.bin 下载日志: 代码:全选esptool.py v4.1 Serial port COM4 Connecting................ Detecting chip type... Unsupported detection protocol, switching and trying again... Connecting... Detecting chip type... ESP8266 Chip is ESP8266EX Features: WiFi Crystal is 26MHz MAC: d8:bf:c0:e2:3c:dc Uploading stub... Running stub... Stub running... Configuring flash size... Flash will be erased from 0x00008000 to 0x00008fff... Flash will be erased from 0x00009000 to 0x0000afff... Flash will be erased from 0x00000000 to 0x00002fff... Flash will be erased from 0x00010000 to 0x000defff... Flash will be erased from 0x000f0000 to 0x000f0fff... Flash will be erased from 0x000fc000 to 0x000fcfff... Flash will be erased from 0x00106000 to 0x00106fff... Flash will be erased from 0x00104000 to 0x00104fff... Flash will be erased from 0x00108000 to 0x00108fff... Flash will be erased from 0x000f1000 to 0x000f1fff... Flash will be erased from 0x000f8000 to 0x000f8fff... Flash will be erased from 0x000fa000 to 0x000fafff... Compressed 3072 bytes to 112... Wrote 3072 bytes (112 compressed) at 0x00008000 in 0.1 seconds (effective 309.2 kbit/s)... Hash of data verified. Compressed 8192 bytes to 31... Wrote 8192 bytes (31 compressed) at 0x00009000 in 0.0 seconds (effective 2036.0 kbit/s)... Hash of data verified. Flash params set to 0x0230 Compressed 10224 bytes to 6843... Wrote 10224 bytes (6843 compressed) at 0x00000000 in 0.8 seconds (effective 100.2 kbit/s)... Hash of data verified. Compressed 844288 bytes to 529252... Wrote 844288 bytes (529252 compressed) at 0x00010000 in 46.9 seconds (effective 143.9 kbit/s)... Hash of data verified. Compressed 3072 bytes to 204... Wrote 3072 bytes (204 compressed) at 0x000f0000 in 0.1 seconds (effective 256.9 kbit/s)... Hash of data verified. Compressed 2344 bytes to 1499... Wrote 2344 bytes (1499 compressed) at 0x000fc000 in 0.2 seconds (effective 90.0 kbit/s)... Hash of data verified. Compressed 1692 bytes to 1322... Wrote 1692 bytes (1322 compressed) at 0x00106000 in 0.2 seconds (effective 84.2 kbit/s)... Hash of data verified. Compressed 1168 bytes to 895... Wrote 1168 bytes (895 compressed) at 0x00104000 in 0.1 seconds (effective 73.3 kbit/s)... Hash of data verified. Compressed 1172 bytes to 914... Wrote 1172 bytes (914 compressed) at 0x00108000 in 0.1 seconds (effective 73.8 kbit/s)... Hash of data verified. Compressed 4096 bytes to 83... Wrote 4096 bytes (83 compressed) at 0x000f1000 in 0.1 seconds (effective 510.4 kbit/s)... Hash of data verified. Compressed 2344 bytes to 1487... Wrote 2344 bytes (1487 compressed) at 0x000f8000 in 0.2 seconds (effective 106.3 kbit/s)... Hash of data verified. Compressed 3368 bytes to 2526... Wrote 3368 bytes (2526 compressed) at 0x000fa000 in 0.3 seconds (effective 88.6 kbit/s)... Hash of data verified. Leaving... Hard resetting via RTS pin... |
1个回答
m_data.bin
但是升级完固件后,我的 Iduino ESP 13 无法启动了。在使用串口助手进行调试时,我发现 Iduino ESP 13 会在启动时重复输出“ets Jan 8 2013,rst cause:4, boot mode:(3,6)”,然后就无法正常启动了。 这种情况可能是固件烧录过程中出现了问题,或者固件本身有问题。您可以尝试重新烧录固件,或者下载一个不同的固件进行测试。同时,也可以检查硬件连接、电源供应等方面是否有问题,可能是这些因素导致了启动失败。 |
只有小组成员才能发言,加入小组>>
330 浏览 0 评论
948 浏览 0 评论
1676 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1335 浏览 1 评论
1234 浏览 1 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1254浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
929浏览 3评论
2342浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2531浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1053浏览 2评论
/9
GMT+8, 2025-12-3 17:25 , Processed in 0.870034 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
406
