电子发烧友论坛|
我买了一个 jpeg 相机 (C429-L36) 来连接我的 esp8266。
通过在互联网上找到的一些示例,我首先在我的计算机上完成了这个程序来测试协议。 代码:全选 int main() { int USB = open( "/dev/ttyUSB1", O_RDWR | O_NOCTTY | O_SYNC ); struct termios tty; /* Set Baud Rate */ cfsetospeed (&tty, (speed_t)B115200); cfsetispeed (&tty, (speed_t)B115200); /* Setting other Port Stuff */ tty.c_cflag &= ~PARENB; // Make 8n1 tty.c_cflag &= ~CSTOPB; tty.c_cflag &= ~CSIZE; tty.c_cflag |= CS8; tty.c_cflag &= ~CRTSCTS; // no flow control tty.c_cc[VMIN] = 1; // read doesn't block tty.c_cc[VTIME] = 15; // 0.5 seconds read timeout tty.c_cflag |= CREAD | CLOCAL; // turn on READ & ignore ctrl lines /* Make raw */ cfmakeraw(&tty); tcsetattr ( USB, TCSANOW, &tty ) ; char response[261]; unsigned char cmd[20]; cmd[0] = 0x56; cmd[1] = 0x00; cmd[2] = 0x11; cmd[3] = 0x00; write(USB, cmd, 4); sleep(1); read(USB, response, 16); for(int i = 0; i< 16;++i) { printf("%c", response); fflush(stdout); } cmd[0] = 0x56; cmd[1] = 0x00; cmd[2] = 0x3; cmd[3] = 0x01; cmd[4] = 0x00; write(USB, cmd, 5); sleep(1); read(USB, response, 5); cmd[0] = 0x56; cmd[1] = 0x00; cmd[2] = 0x34; cmd[3] = 0x01; cmd[4] = 0x00; tcflush(USB,TCIOFLUSH); write(USB, cmd, 5); sleep(1); int n = 0; n = read( USB, response, 9 ); int length = 0; unsigned int res; if(n == 9) { if(response[3] == 0x00 && response[4] == 0x04) { res = (response[8] & 0xFF); res += (response[7] & 0xFF) << 8; res += (response[6] & 0xFF) << 16; res += (response[5] & 0xFF) << 24; } } int addr = 0; FILE* f = fopen("photo.jpg", "wb"); int bytes = 255; while(addr != res) { if(res - addr < bytes) bytes = res-addr; else bytes = bytes; printf("%d\n", addr); fflush(stdout); cmd[0] = 0x56; cmd[1] = 0x00; cmd[2] = 0x32; cmd[3] = 0x0C; cmd[4] = 0x00; cmd[5] = 0x0A; cmd[6] = (addr >> 24) & 0xFF; cmd[7] = (addr >> 16) & 0xFF; cmd[8] = (addr >> 8) & 0xFF; cmd[9] = (addr & 0xFF); cmd[10] = 0; cmd[11] = 0; cmd[12] = 0; cmd[13] = bytes; cmd[14] = 1; cmd[15] = 0; write(USB, cmd, 16); sleep(1); read(USB, response, 5); read(USB, response, bytes); fwrite(response, bytes, 1, f); read(USB, response, 5); addr += bytes; } fclose(f); return 0; } 它运行良好,控制器版本良好,FBuffer 长度良好,当我读取缓冲区时,文件以正确的魔术字 (0xFF 0xD8) 开头,但没有以正确的魔术字 (0xFF 0xD9) 结尾,这很奇怪,因为文件大小与宣布的 FBuffer 大小一致。 有人可以帮助我吗? |
1个回答
设置其他串口参数 */ tty.c_cflag = (tty.c_cflag & ~CSIZE) | CS8; // 8 bits per byte tty.c_iflag = IGNPAR; // ignore parity errors tty.c_oflag = 0; // no processing of output tty.c_lflag = 0; // no processing of input /* 打开读取图片的命令并发送 */ write(USB,"?CMD=STILL
只有小组成员才能发言,加入小组>>
945 浏览 0 评论
1672 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1330 浏览 1 评论
1233 浏览 1 评论
5021 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1253浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
927浏览 3评论
2338浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2526浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1052浏览 2评论
/9
GMT+8, 2025-12-2 05:54 , Processed in 0.738154 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
723
