你好!
我正在尝试使用 ESP8266-12E nodemcu 板将 EMG(肌电图)信号上传到 Asksensors 云。我的电路非常简单,我使用的是连接到 A0 的 myoware 肌肉传感器,然后是 vcc-3.3 v,gnd-gnd。问题是 EMG 信号需要 1000 Hz 的采样率(一秒内有 1000 个离散采样点),但现在我每秒只能获得 10 个样本,因为 ESP8266 12 E 需要 100 毫秒才能将数据更新到云端。我的 arduino 代码和串行监视器输出如下。反正有没有更快的更新?或者我的代码有什么错误吗? 请帮帮我。提前致谢。 代码:全选#include #include #include #include // user config: TODO #define MOISTURE_THRESHOLD 55 // moisture alert threshold const char* wifi_ssid = "******"; // SSID const char* wifi_password = "*******"; // WIFI const char* apiKeyIn = "********"; // API KEY IN const unsigned int writeInterval = 1; // write interval (in ms) // ASKSENSORS config. String host = "http://api.asksensors.com"; // ASKSENSORS API host name ESP8266WiFiMulti WiFiMulti; int moisture_Pin= 0; // Soil Moisture Sensor input at Analog PIN A0 int moisture_value= 0, moisture_state = 0xFF; void setup() { Serial.begin(115200); Serial.println("*****************************************************"); Serial.println("********** Program Start : Soil Moisture monitoring using ESP8266 and AskSensors IoT cloud"); Serial.println("Wait for WiFi... "); Serial.print("********** connecting to WIFI : "); Serial.println(wifi_ssid); WiFi.begin(wifi_ssid, wifi_password); while (WiFi.status() != WL_CONNECTED) { delay(500); Serial.print("."); } Serial.println(""); Serial.println("-> WiFi connected"); Serial.println("-> IP address: "); Serial.println(WiFi.localIP()); } void loop() { Serial.print("MOISTURE LEVEL : "); moisture_value= analogRead(moisture_Pin); Serial.println(moisture_value); if(moisture_value > MOISTURE_THRESHOLD) moisture_state = 0; else moisture_state = 1; // wait for WiFi connection if (WiFi.status() == WL_CONNECTED){ HTTPClient http; client.write(webFile); Serial.print("[HTTP] begin...\n"); // Create a URL for the request String url = ""; url += host; url += "/write/"; url += apiKeyIn; url += "?module1="; url += moisture_value; url += "&module2="; url += moisture_state; Serial.print("********** requesting URL: "); Serial.println(url); http.begin(url); //HTTP Serial.println(">EMG were sent to ASKSENSORS"); Serial.print("[HTTP] GET...\n"); // start connection and send HTTP header int httpCode = http.GET(); // httpCode will be negative on error if(httpCode > 0) { // HTTP header has been send and Server response header has been handled Serial.printf("[HTTP] GET... code: %d\n", httpCode); // file found at server if(httpCode == HTTP_CODE_OK) { String payload = http.getString(); Serial.println(payload); } } else { Serial.printf("[HTTP] GET... failed, error: %s\n", http.errorToString(httpCode).c_str()); } http.end(); Serial.println("********** End "); Serial.println("*****************************************************"); } delay(writeInterval); } |
1个回答
您好!要将上传间隔从100毫秒缩短到更短,您可以尝试以下方法:
1. 使用更快的ESP8266芯片(例如ESP32),这样可以提高数据传输速度。 2. 修改ESP8266的上传间隔时间,可以更改您的代码中的delay值,将延迟时间减小以提高上传速度。 3. 使用异步传输,可以将数据打包并异步传输,以缩短上传时间。 4. 您还可以尝试使用更高频率的AD转换器,以获得更快的采样频率。 关于您的代码错误,我无法在您的代码片段中找到错误。如果您有其他代码片段或更多信息,请分享它们以获得更好的帮助。谢谢! |
只有小组成员才能发言,加入小组>>
968 浏览 1 评论
553浏览 6评论
462浏览 5评论
有没有办法在不使用混杂模式的情况下实现Wifi驱动程序接收缓冲区访问中断呢?
447浏览 5评论
448浏览 4评论
418浏览 4评论
GMT+8, 2024-11-26 21:44 , Processed in 0.676007 second(s), Total 75, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
