我尝试配置 ROM 引导加载程序,但如果我设置 usbStringsPointer 而不是进入 ROM 引导加载程序,将导致 MCU 软件复位。
谁能帮我配置结构?一定有问题。 #define USB_STRING_DESCRIPTOR 0x03 const uint8_t USB_STR_0[4] = {0x02,0x03,0x09,0x04}; /* RM 14.4.5.2 */ __attribute__((section(".usb_str"))) usb_strings_t usb_str = { //Länge, +utf16 string .vendor = { 18,USB_STRING_DESCRIPTOR,'T',0,'Y',0,'R',0,'A',0,'C',0,'O',0,'N',0,'T',0 }, .product_description = { 12,USB_STRING_DESCRIPTOR,'V',0,'D',0,'8',0,'5',0,'0',0}, .serial_nr = { 18,USB_STRING_DESCRIPTOR,'1',0,'2',0,'3',0,'4',0,'5',0,'6',0,'7',0,'8',0 }, .str_size = {sizeof(USB_STR_0),18,12,18}, }; const uint8_t * const g_string_descriptors[4] = { USB_STR_0, usb_str.vendor, usb_str.product_description, usb_str.serial_nr, }; const Languages_desc_t g_languages = { .STR0_ptr = USB_STR_0, .Size = sizeof(USB_STR_0), .Num = (uint16_t) 0x0409, .StringDescriptors = g_string_descriptors, .Sizes = usb_str.str_size, }; __attribute__((section(".cfg_section"))) volatile const bootloader_config_t bcfg = { .tag = 0x6766636B, //!< Magic Number .crcStartAddress = 0xFFFFFFFF, //!< Disable CRC check .crcByteCount = 0xFFFFFFFF, //!< Disable CRC check .crcExpectedValue = 0xFFFFFFFF, //!< Disable CRC check .enabledPeripherals = ENABLE_PERIPHERAL_USB_HID, .i2cSlaveAddress = 0x10, //!< Use default I2C address(0x10) .peripheralDetectionTimeoutMs = 10000, //!< Use user-defined timeout(ms) .usbVid = 0x22B5, //!< Use default Vendor ID(0x15A2) .usbPid = 0x0850, //!< Use default Product ID(0x0073) .usbStringsPointer = (uint32_t)&g_languages, .clockFlags = 0xFE, //!< 0 bit cleared: Enable High speed mode. NOTE: Enabling high speed mode makes UART connection worse, requires pull-up on UART RX line! .clockDivider = 0xff, //!< Use clock divider(0) .mmcauPtr = 0x410, .FOPTConfig = {0x45FFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFF3DFE}, }; |
只有小组成员才能发言,加入小组>>
2135个成员聚集在这个小组
加入小组我的项目我做主,使用GN+Ninja来完成构建系统(VSCode开发RT106X)
37376 浏览 0 评论
NXP IMX8应用处理器快速入门必备:技巧、使用、设计指南
6775 浏览 1 评论
7793 浏览 1 评论
7642 浏览 0 评论
NXP i.MX6UL开发板(linux系统烧录+规格+硬件+模块移植)使用手册
5071 浏览 0 评论
1556浏览 2评论
关于NINA-W132 Wi-Fi模块SPI通信遇到的疑问求解
1208浏览 2评论
如何在MPC PowerPC MCU上首次刷写后禁用BDM?
749浏览 1评论
将HFREFR和LFREFR寄存器值设置为错误的值来将故障注入CMU,但CMU_ISR值始终为零,为什么?
735浏览 1评论
将SPSDK for FRDM-MCX-W71 SDK与VS一起安装时出现hidapi构建错误怎么解决?
678浏览 1评论
/9
GMT+8, 2025-12-2 06:23 , Processed in 0.690398 second(s), Total 70, Slave 53 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
389
