电子发烧友论坛|
我根据其他人的出色工作拼凑了一个草图,让我可以监控传感器和控制继电器以及我家周围各种节点上的 IR 发射器,这些节点通过 MQTT 连接到 HomeAssistant (home-assistant.io)。
一切正常……有一段时间了。但是没有明显的原因,执行器的回调停止工作。我仍然从传感器获得“心跳”(调试尝试的一部分)和读数,但我无法再控制继电器或 IR Blaster。没有错误消息(如您所见,我尝试在所有地方插入消息进行调试)。 仅供参考,调试仍然失败并且串行连接已关闭。 完整代码如下。提前致谢。对不起,如果我可怕的代码冒犯了你的眼睛。 代码:全选// Utilises: // - PubSubClient by Nick ‘O Leary // - DHT sensor library by Adafruit // Name this node - sets mqtt addresses #define NODE_NAME "livingroom" // Activate components - comment out to deactivate //#define PIR_ACTIVE //#define DHT_ACTIVE //#define RELAY_ACTIVE #define IRBLASTER_ACTIVE #define HEARTBEAT //#define SWITCH // Debug mode ? #define DEBUG // Core library definitions and settings #include #include #define wifi_ssid "xxxxxxxxxx" #define wifi_password "xxxxxxxxxx" #define mqtt_server "192.168.xx.xx" #define mqtt_user "xxxxxxxxxx" #define mqtt_password "xxxxxxxxxx" WiFiClient espClient; PubSubClient client(espClient); long lastMsg = 0; float diff = 1.0; // Temp and humidity sensor #ifdef DHT_ACTIVE #include #define humidity_topic NODE_NAME "/sensor/humidity" #define temperature_topic NODE_NAME "/sensor/temperature" #define DHTTYPE DHT22 #define DHTPIN 14 // D5 float temp = 0.0; float hum = 0.0; DHT dht(DHTPIN, DHTTYPE, 11); // 11 works fine for ESP8266 #endif // PIR #ifdef PIR_ACTIVE #define pir_topic "livingroom/sensor/pir" #define PIRPIN D6 #define LEDPIN 13 int pirState = LOW; // we start, assuming no motion detected int pir = 0; // variable for reading the pin status #endif // IR Blaster #ifdef IRBLASTER_ACTIVE #include #include #define ir_message NODE_NAME "/control/irb" #define ir_state NODE_NAME "/control/irb/state" int khz = 38; // 38kHz carrier frequency for both NEC and Samsung IRsend irsend(2); //an IR led is connected to GPI0 2 (pin D4 on NodeMCU) #endif // 4-way Relay #ifdef RELAY_ACTIVE #define relay_zero NODE_NAME "/control/relay/0" #define zero_state NODE_NAME "/control/relay/0/state" #define relay_one NODE_NAME "/control/relay/1" #define one_state NODE_NAME "/control/relay/1/state" #define relay_two NODE_NAME "/control/relay/2" #define two_state NODE_NAME "/control/relay/2/state" #define relay_three NODE_NAME "/control/relay/3" #define three_state NODE_NAME "/control/relay/3/state" int r_zero_state = 0; int r_one_state = 0; int r_two_state = 0; int r_three_state = 0; int r_zero_test = 0; int r_one_test = 0; int r_two_test = 0; int r_three_test = 0; #endif // Heartbeat #ifdef HEARTBEAT #define heartbeat NODE_NAME "/heartbeat" #endif // Switch #ifdef SWITCH #define switchchan NODE_NAME "/sensor/switch" int switchstate = 0; int switchread = 0; #endif void setup() { Serial.begin(115200); #ifdef DHT_ACTIVE dht.begin(); // start the temp and humidity sensor #endif #ifdef IRBLASTER_ACTIVE irsend.begin(); // start the irblaster #endif #ifdef PIR_ACTIVE pinMode(PIRPIN, INPUT); // set the PIR Pin as an inout #endif // prepare GPIO for relay #ifdef RELAY_ACTIVE pinMode(D0, OUTPUT); // GPIO 16 pinMode(D1, OUTPUT); // GPIO 5 pinMode(D2, OUTPUT); // GPIO 4 pinMode(D3, OUTPUT); // GPIO 0 digitalWrite(D0, 1); digitalWrite(D1, 1); digitalWrite(D2, 1); digitalWrite(D3, 1); #endif // Switch #ifdef SWITCH pinMode(D7, INPUT); #endif // get the core stuff started setup_wifi(); client.setServer(mqtt_server, 1883); client.setCallback(callback); #ifdef RELAY_ACTIVE // Share current relay status client.publish(zero_state, "1", true); client.publish(one_state, "1", true); client.publish(two_state, "1", true); client.publish(three_state, "1", true); #endif } void setup_wifi() { delay(10); // We start by connecting to a WiFi network #ifdef DEBUG Serial.println(); Serial.print("Connecting to "); Serial.println(wifi_ssid); #endif WiFi.mode(WIFI_STA); WiFi.begin(wifi_ssid, wifi_password); while (WiFi.status() != WL_CONNECTED) { delay(500); #ifdef DEBUG Serial.print("."); #endif } #ifdef DEBUG Serial.println(""); Serial.println("WiFi connected"); Serial.println("IP address: "); Serial.println(WiFi.localIP()); #endif } void reconnect() { // Loop until we're reconnected while (!client.connected()) { #ifdef DEBUG Serial.print("Attempting MQTT connection..."); #endif // Attempt to connect if (client.connect("ESP8266Client", mqtt_user, mqtt_password)) { #ifdef RELAY_ACTIVE client.subscribe(relay_zero); client.subscribe(relay_one); client.subscribe(relay_two); client.subscribe(relay_three); #endif #ifdef IRBLASTER_ACTIVE client.subscribe(ir_message); #endif } else { #ifdef DEBUG Serial.println(""); Serial.print("failed, rc="); Serial.print(client.state()); Serial.println(" try again in 5 seconds"); // Wait 5 seconds before retrying #endif delay(5000); } } } #ifdef DHT_ACTIVE bool checkBound(float newValue, float prevValue, float maxDiff) { return !isnan(newValue) && (newValue < prevValue - maxDiff || newValue > prevValue + maxDiff); } #endif #ifdef IRBLASTER_ACTIVE void blastir(byte* payload) { String statmessage = "unset"; int val = payload[0]; int instr = payload[0] - '0'; switch (instr) { case 0: irsend.sendNEC(0xFF02FD,32); #ifdef DEBUG statmessage = "Lights On/Off Command sent"; #endif delay(1); break; case 1: irsend.sendNEC(0xFF1AE5,32); #ifdef DEBUG statmessage = "Red light command sent"; #endif delay(1); break; case 2: irsend.sendNEC(0xFF9A65,32); #ifdef DEBUG statmessage = "Green lights command sent"; #endif delay(1); break; case 3: irsend.sendNEC(0xFF22DD,32); #ifdef DEBUG statmessage = "White lights command sent"; #endif delay(1); break; case 4: irsend.sendNEC(0xFF30CF,32); #ifdef DEBUG statmessage = "DIY 1 command sent"; #endif delay(1); break; default: #ifdef DEBUG statmessage = "Could not match string"; #endif break; } #ifdef DEBUG client.publish(ir_state, String(statmessage).c_str(), true); Serial.println(statmessage); #endif delay(10); } #endif #ifdef RELAY_ACTIVE void relayswitch(byte* payload, String topicstring) { #ifdef DEBUG Serial.println("Relayswitch function called"); #endif int val = int(payload[0]); char port; int portloc = topicstring.length() - 1; #ifdef DEBUG Serial.print("Port location: "); Serial.println(portloc); #endif port = topicstring.charAt(portloc); int iport = port - '0'; int ival = val - '0'; #ifdef DEBUG Serial.print("Port: "); Serial.println(port); Serial.print("iPort: "); Serial.println(iport); #endif switch(iport) { case 0: digitalWrite(D0, ival); r_zero_state = ival; #ifdef DEBUG Serial.print("Switching Relay One to:"); Serial.println(ival); #endif client.publish(zero_state, String(ival).c_str(), true); delay(1); break; case 1: digitalWrite(D1, ival); r_one_state = ival; #ifdef DEBUG Serial.print("Switching Relay Two to:"); Serial.println(ival); #endif client.publish(one_state, String(ival).c_str(), true); delay(1); break; case 2 : digitalWrite(D2, ival); r_two_state = ival; #ifdef DEBUG Serial.print("Switching Relay Three to:"); Serial.println(ival); #endif client.publish(two_state, String(ival).c_str(), true); delay(1); break; case 3 : digitalWrite(D3, ival); r_three_state = ival; #ifdef DEBUG Serial.print("Switching Relay Four to:"); Serial.println(ival); #endif client.publish(three_state, String(ival).c_str(), true); delay(1); break; default: Serial.println("Could not match string"); break; } } #endif void callback(char* topic, byte* payload, unsigned int length) { #ifdef DEBUG Serial.print("Message arrived ["); Serial.print(topic); Serial.print("] "); for (int i = 0; i < length; i++) { Serial.print((char)payload); } Serial.println(); #endif String topicstring(topic); int stripstart = String(NODE_NAME).length()+1; int stripstop = String(NODE_NAME).length()+4; #ifdef DEBUG Serial.println(topicstring.substring(stripstart,stripstop)); #endif if(topicstring.substring(stripstart,stripstop) == "con") { int funcstart = String(NODE_NAME).length()+9; int funcstop = String(NODE_NAME).length()+12; String func = topicstring.substring(funcstart,funcstop); #ifdef DEBUG Serial.print("Func = "); Serial.println(func); #endif if(func == "rel") { #ifdef RELAY_ACTIVE relayswitch(payload, topicstring); #endif delay(1); } if(func == "irb") { #ifdef IRBLASTER_ACTIVE blastir(payload); #endif delay(1); } } delay(10); } #ifdef PIR_ACTIVE void pir_state() { pir = digitalRead(PIRPIN); if (pir == HIGH) { // check if the input is HIGH digitalWrite(LEDPIN, HIGH); // turn LED ON if (pirState == LOW) { // we have just turned on #ifdef DEBUG Serial.println("Motion detected!"); #endif client.publish(pir_topic, "1", true); // We only want to print on the output change, not state pirState = HIGH; } } else { digitalWrite(LEDPIN, LOW); // turn LED OFF if (pirState == HIGH){ // we have just turned off #ifdef DEBUG Serial.println("Motion ended!"); #endif client.publish(pir_topic, "0", true); // We only want to print on the output change, not state pirState = LOW; } } delay(10); } #endif #ifdef DHT_ACTIVE void dhtread() { float newTemp = dht.readTemperature(); float newHum = dht.readHumidity(); if (checkBound(newTemp, temp, diff)) { temp = newTemp; #ifdef DEBUG Serial.print("New temperature:"); Serial.println(String(temp).c_str()); #endif client.publish(temperature_topic, String(temp).c_str(), false); } if (checkBound(newHum, hum, diff)) { hum = newHum; #ifdef DEBUG Serial.print("New humidity:"); Serial.println(String(hum).c_str()); #endif client.publish(humidity_topic, String(hum).c_str(), false); } delay(10); } #endif #ifdef SWITCH void switchfunc(){ switchread = digitalRead(D7); if(switchread != switchstate) { client.publish(switchchan, String(switchstate).c_str(), true); #ifdef DEBUG Serial.print("Switch flipped to "); Serial.println(switchstate); #endif switchstate = switchread; delay(10); } } #endif void loop() { if (!client.connected()) { reconnect(); } delay(1000); client.loop(); // Serial.println("In loop"); long now = millis(); if (now - lastMsg > 10000) { lastMsg = now; #ifdef HEARTBEAT client.publish(heartbeat, "1", false); #endif #ifdef DEBUG Serial.println("Reading..."); #endif #ifdef PIR_ACTIVE pir_state(); #endif #ifdef DHT_ACTIVE dhtread(); #endif #ifdef SWITCH switchfunc(); #endif } } |
只有小组成员才能发言,加入小组>>
479 浏览 0 评论
1006 浏览 0 评论
1716 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1375 浏览 1 评论
1258 浏览 1 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1295浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
945浏览 3评论
2396浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2585浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1077浏览 2评论
/9
GMT+8, 2025-12-17 20:11 , Processed in 0.713772 second(s), Total 71, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
414
