电子发烧友论坛|
我们试图启动 imx8mm-evk。
我们用MIMX8MM1DVTLZAA改变了这个处理器。 U-boot 正在加载,但在 linux 映像加载时失败。但同样的图像适用于标准图像。 U-Boot SPL 2022.04-lf_v2022.04+g16e8414193 (Oct 08 2022 - 13:33:43 +0000) Can't find PMIC:PCA9450 DDRINFO: start DRAM init DDRINFO: DRAM rate 3000MTS DDRINFO:ddrphy calibration done DDRINFO: ddrmix config done SEC0: RNG instantiated Normal Boot Trying to boot from MMC1 NOTICE: BL31: v2.6(release):automotive-12.1.0_1.1.0-0-g9202efc9a NOTICE: BL31: Built : 09:52:38, Sep 5 2022 U-Boot 2022.04-lf_v2022.04+g16e8414193 (Oct 08 2022 - 13:33:43 +0000) CPU: i.MX8MMSL rev1.0 1800 MHz (running at 1200 MHz) CPU: Commercial temperature grade (0C to 95C) at 36C Reset cause: POR Model: NXP i.MX8MM EVK board DRAM: 2 GiB tcpc_init: Can't find device id=0x52 setup_typec: tcpc port2 init failed, err=-19 tcpc_init: Can't find device id=0x50 setup_typec: tcpc port1 init failed, err=-19 Core: 166 devices, 29 uclasses, devicetree: separate MMC: FSL_SDHC: 1, FSL_SDHC: 2 Loading Environment from MMC... MMC: no card present *** Warning - No block device, using default environment -Video Link 0adv7535_mipi2hdmi adv7535@3d: Can't find cec device id=0x3c fail to probe panel device adv7535@3d mxs_video lcdif@32e00000: failed to get any video link display timings probe video device failed, ret -22 [0] lcdif@32e00000, video [1] mipi_dsi@32e10000, video_bridge [2] adv7535@3d, panel adv7535_mipi2hdmi adv7535@3d: Can't find cec device id=0x3c fail to probe panel device adv7535@3d mxs_video lcdif@32e00000: failed to get any video link display timings probe video device failed, ret -22 In: serial Out: serial Err: serial SEC0: RNG instantiated BuildInfo: - ATF 9202efc MMC: no card present flash target is MMC:1 MMC: no card present MMC card init failed! MMC: no card present ** Block device MMC 1 not supported Net: Could not get PHY for FEC0: addr 0 Could not get PHY for FEC0: addr 0 No ethernet found. Fastboot: Normal Normal Boot Hit any key to stop autoboot: 0 starting USB... Bus usb@32e40000: Port not available. USB is stopped. Please issue 'usb start' first. MMC: no card present Card did not respond to voltage select! : -110 Running BSP bootcmd ... MMC: no card present MMC Device 0 not found no mmc device at slot 0 u-boot=> booti Bad Linux ARM64 Image magic! u-boot=> 如何启动Linux? |
只有小组成员才能发言,加入小组>>
2135个成员聚集在这个小组
加入小组我的项目我做主,使用GN+Ninja来完成构建系统(VSCode开发RT106X)
37376 浏览 0 评论
NXP IMX8应用处理器快速入门必备:技巧、使用、设计指南
6775 浏览 1 评论
7793 浏览 1 评论
7642 浏览 0 评论
NXP i.MX6UL开发板(linux系统烧录+规格+硬件+模块移植)使用手册
5071 浏览 0 评论
1556浏览 2评论
关于NINA-W132 Wi-Fi模块SPI通信遇到的疑问求解
1208浏览 2评论
如何在MPC PowerPC MCU上首次刷写后禁用BDM?
749浏览 1评论
将HFREFR和LFREFR寄存器值设置为错误的值来将故障注入CMU,但CMU_ISR值始终为零,为什么?
735浏览 1评论
将SPSDK for FRDM-MCX-W71 SDK与VS一起安装时出现hidapi构建错误怎么解决?
678浏览 1评论
/9
GMT+8, 2025-12-2 06:30 , Processed in 0.635958 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
531
