电子发烧友论坛|
我们正在进行一个需要 ESP8266 之间通信的项目。我们使用 ESPNOW 在我们的 ESP 之间发送 MAC 地址。我们的目标是分享这一点,并为其他人提供一种在 ESP8266 上使用 ESPNOW 的简单方法。我们期待阅读您对此主题的评论。
代码:全选/* Super Simple Minimalist Easy ESPNOW This is an easy way to communicate between ESP8266s. *no error checking *no encryption *broadcast only *unlimited number of transceivers *Six bits+Five bytes of sender id and/or payload(two low order bits of first byte are reserved) *250 bytes of optional payload Aaron Chand Tim Hayward License: MIT License */ #include #include uint8_t broadcastAddress[] = {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF}; /* Optional Custom MAC Address uint8_t newMACAddress[] = {0x44, 0x44, 0x44, 0x44, 0x44, 0x44}; */ bool OkayToSend; //Sending is Complete typedef struct struct_message { //structure example to send data //must match the receiver structure char a[250]; } struct_message; struct_message myData; // create a data structure called myData char s [32]; void OnDataRecv(uint8_t * mac, uint8_t *incomingData, uint8_t len) { //receive data memcpy(&myData, incomingData, sizeof(myData)); char macStr[18]; Serial.print("Data received"); snprintf(macStr, sizeof(macStr), "%02x:%02x:%02x:%02x:%02x:%02x", mac[0], mac[1], mac[2], mac[3], mac[4], mac[5]); Serial.print(macStr); Serial.print("\t"); Serial.println(myData.a); } void OnDataSent(uint8_t *mac_addr, uint8_t sendStatus) { OkayToSend = true; } void setup() { Serial.begin(115200); //Init Serial Monitor Serial.println("Super Simple Minimalist Easy ESPNOW"); WiFi.mode(WIFI_STA); //Set Device as a WiFi Station WiFi.disconnect(); /* Uncomment to Set Custom MAC Address wifi_set_macaddr(STATION_IF, &newMACAddress[0]); */ esp_now_init(); //init ESPNOW esp_now_set_self_role(ESP_NOW_ROLE_COMBO); esp_now_register_send_cb(OnDataSent); esp_now_register_recv_cb(OnDataRecv); esp_now_add_peer(broadcastAddress, ESP_NOW_ROLE_COMBO, 1, NULL, 0); //add peer } void loop() { strcpy(myData.a,"THIS IS THE PAYLOAD"); //set values to send while (!OkayToSend){} OkayToSend = false; esp_now_send(0, (uint8_t*) &myData, sizeof(myData)); // send a message delay(100); } |
只有小组成员才能发言,加入小组>>
944 浏览 0 评论
1671 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1330 浏览 1 评论
1233 浏览 1 评论
5015 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1250浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
927浏览 3评论
2330浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2525浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1051浏览 2评论
/9
GMT+8, 2025-12-1 21:00 , Processed in 0.816254 second(s), Total 70, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
457
