“翻斗”雨量计的代码在 ESP32 上不起作用。
尝试从以下位置获取 jur 代码: to work with an ESP32。 司法代码: 代码:全选#define TENMINUTES (600*1000L) // ten minutes are 600000 milliseconds #define REEDPIN 32 //changed for RSP32 #define REEDINTERRUPT 0 volatile int pulseCount_ISR; void reedSwitch_ISR() { static unsigned long lastReedSwitchTime; // debounce for a quarter second = max. 4 counts per second if (labs(millis()-lastReedSwitchTime)>250) { pulseCount_ISR++; lastReedSwitchTime=millis(); } } void setup() { Serial.begin(9600); Serial.println(); Serial.println(\"Total\\tCurrent\"); pinMode(REEDPIN,INPUT_PULLUP); attachInterrupt(REEDINTERRUPT,reedSwitch_ISR, FALLING); } unsigned long lastSecond,last10Minutes; long lastPulseCount; int currentPulseCount; void loop() { // each second read and reset pulseCount_ISR if (millis()-lastSecond>=1000) { lastSecond+=1000; noInterrupts(); currentPulseCount+=pulseCount_ISR; // add to current counter pulseCount_ISR=0; // reset ISR counter interrupts(); Serial.print(lastPulseCount);Serial.print(\'\\t\');Serial.print(currentPulseCount); Serial.println(); } // each 10 minutes save data to another counter if (millis()-last10Minutes>=TENMINUTES) { last10Minutes+=TENMINUTES; // remember the time lastPulseCount+=currentPulseCount; // add to last period Counter currentPulseCount=0;; // reset counter for current period } } |
只有小组成员才能发言,加入小组>>
475浏览 6评论
399浏览 5评论
有没有办法在不使用混杂模式的情况下实现Wifi驱动程序接收缓冲区访问中断呢?
380浏览 5评论
385浏览 4评论
361浏览 4评论
GMT+8, 2024-10-1 20:59 , Processed in 0.633293 second(s), Total 73, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
