大家好,
我正在尝试按照 i.MX Yocto 项目用户指南版本 L5.4.70_2.3.0 为 i.MX8mmini EVK 构建 yocto fsl-image-full 图像,但这次失败了。 这个目标坏了吗? 错误是以下错误: 15:29:00 ✔ bsp@Ubuntu3:~/yocto/imx-yocto-bsp-zeus/build-wayland$ bitbake imx-image-full WARNING: Host distribution "ubuntu-20.04" has not been validated with this version of the build system; you may possibly experience unexpected failures. It is recommended that you use a tested distribution. Loading cache: 100% |#############################################################################################################################################################################| Time: 0:00:00 Loaded 4639 entries from dependency cache. Parsing recipes: 100% |###########################################################################################################################################################################| Time: 0:00:01 Parsing of 3217 .bb files complete (3216 cached, 1 parsed). 4640 targets, 469 skipped, 1 masked, 0 errors. NOTE: Resolving any missing task queue dependencies Build Configuration: BB_VERSION = "1.44.0" BUILD_SYS = "x86_64-linux" NATIVELSBSTRING = "ubuntu-20.04" TARGET_SYS = "aarch64-poky-linux" MACHINE = "imx8mmevk" DISTRO = "fsl-imx-wayland" DISTRO_VERSION = "5.4-zeus" TUNE_FEATURES = "aarch64 cortexa53 crc crypto" TARGET_FPU = "" meta meta-poky = "HEAD:d88d62c20d7d8da85f02edb170dae0280624ad7e" meta-oe meta-multimedia meta-python = "HEAD:2b5dd1eb81cd08bc065bc76125f2856e9383e98b" meta-freescale = "HEAD:14f1a630a47375432f93c556927b879b51d84c4e" meta-freescale-3rdparty = "HEAD:dbcc686f52c3c84db8cb86aa8973a4e373651b98" meta-freescale-distro = "HEAD:ca27d12e4964d1336e662bcc60184bbff526c857" meta-bsp meta-sdk meta-ml = "HEAD:c4620c1b711d180a3f93d69ec6ca416d886f9277" meta-nxp-demo-experience = "HEAD:c7263d9f3cc7bbf44e7164ffeda494cf283d3dec" meta-browser = "HEAD:ee3be3b5986a4aa0e73df2204a625ae1fe5df37e" meta-rust = "HEAD:53bfa324891966a2daf5d36dc13d4a43725aebed" meta-clang = "HEAD:711e593d5984aad3bf35c51b7ac4482982bc16c7" meta-gnome meta-networking meta-filesystems = "HEAD:2b5dd1eb81cd08bc065bc76125f2856e9383e98b" meta-qt5 = "HEAD:21ce4c124d9a972d9122f87c64ac2773bf04c284" meta-python2 = "HEAD:4400f9155ec193d028208cf0c66aeed2ba2b00ab" Initialising tasks: 100% |########################################################################################################################################################################| Time: 0:00:02 Sstate summary: Wanted 2308 Found 0 Missed 2308 Current 882 (0% match, 27% complete) NOTE: Executing Tasks NOTE: Setscene tasks completed WARNING: libdrm-2.4.102.imx-r0 do_patch: Fuzz detected: Applying patch drm-update-arm.patch patching file xf86drm.h Hunk #1 succeeded at 504 with fuzz 2 (offset 43 lines). The context lines in the patches can be updated with devtool: devtool modify libdrm devtool finish --force-patch-refresh libdrm Don't forget to review changes done by devtool! WARNING: libdrm-2.4.102.imx-r0 do_patch: QA Issue: Patch log indicates that patches do not apply cleanly. [patch-fuzz] WARNING: ntp-4.2.8p13-r0 do_fetch: Checksum mismatch for local file /home/bspdownloads/ntp-4.2.8p13.tar.gz Cleaning and trying again. WARNING: ntp-4.2.8p13-r0 do_fetch: Renaming /home/bspdownloads/ntp-4.2.8p13.tar.gz to /home/bspdownloads/ntp-4.2.8p13.tar.gz_bad-checksum_19bb20214e0a88629e17a5b6c605d45d WARNING: ntp-4.2.8p13-r0 do_fetch: Checksum failure encountered with download of will attempt other sources if available WARNING: lttng-modules-2.10.14-r0 do_package: lttng-modules: no modules were created; this may be due to CONFIG_TRACEPOINTS not being enabled in your kernel. ERROR: python3-pybind11-native-2.5.0-r0 do_configure: Execution of '/home/bsp/yocto/imx-yocto-bsp-zeus/build-wayland/tmp/work/x86_64-linux/python3-pybind11-native/2.5.0-r0/temp/run.do_configure.3278769' failed with exit code 1: -- The CXX compiler identification is GNU 9.3.0 -- Check for working CXX compiler: /home/bsp/yocto/imx-yocto-bsp-zeus/build-wayland/tmp/hosttools/g++ -- Check for working CXX compiler: /home/bsp/yocto/imx-yocto-bsp-zeus/build-wayland/tmp/hosttools/g++ -- works -- Detecting CXX compiler ABI info -- Detecting CXX compiler ABI info - done -- Detecting CXX compile features -- Detecting CXX compile features - done -- Found PythonInterp: /usr/bin/python3.8 (found version "3.8.5") CMake Error at tools/FindPythonLibsNew.cmake:96 (message): Python config failure: Traceback (most recent call last): File "", line 4, in File "/usr/lib/python3.8/distutils/sysconfig.py", line 117, in get_python_inc return sysconfig.get_path('platinclude') File "/usr/lib/python3.8/sysconfig.py", line 512, in get_path return get_paths(scheme, vars, expand)[name] File "/usr/lib/python3.8/sysconfig.py", line 502, in get_paths return _expand_vars(scheme, vars) File "/usr/lib/python3.8/sysconfig.py", line 172, in _expand_vars _extend_dict(vars, get_config_vars()) File "/usr/lib/python3.8/sysconfig.py", line 550, in get_config_vars _init_posix(_CONFIG_VARS) File "/usr/lib/python3.8/sysconfig.py", line 421, in _init_posix _temp = __import__(name, globals(), locals(), ['build_time_vars'], 0) ModuleNotFoundError: No module named '_sysconfigdata' Call Stack (most recent call first): tools/pybind11Tools.cmake:16 (find_package) CMakeLists.txt:33 (include) -- Configuring incomplete, errors occurred! See also "/home/bsp/yocto/imx-yocto-bsp-zeus/build-wayland/tmp/work/x86_64-linux/python3-pybind11-native/2.5.0-r0/build/CMakeFiles/CMakeOutput.log". WARNING: exit code 1 from a shell command. ERROR: Logfile of failure stored in: /home/bsp/yocto/imx-yocto-bsp-zeus/build-wayland/tmp/work/x86_64-linux/python3-pybind11-native/2.5.0-r0/temp/log.do_configure.3278769 Log data follows: | DEBUG: Executing shell function do_configure | -- The CXX compiler identification is GNU 9.3.0 | -- Check for working CXX compiler: /home/bsp/yocto/imx-yocto-bsp-zeus/build-wayland/tmp/hosttools/g++ | -- Check for working CXX compiler: /home/bsp/yocto/imx-yocto-bsp-zeus/build-wayland/tmp/hosttools/g++ -- works | -- Detecting CXX compiler ABI info | -- Detecting CXX compiler ABI info - done | -- Detecting CXX compile features | -- Detecting CXX compile features - done | -- Found PythonInterp: /usr/bin/python3.8 (found version "3.8.5") | CMake Error at tools/FindPythonLibsNew.cmake:96 (message): | Python config failure: | | Traceback (most recent call last): | | File "", line 4, in | File "/usr/lib/python3.8/distutils/sysconfig.py", line 117, in get_python_inc | return sysconfig.get_path('platinclude') | File "/usr/lib/python3.8/sysconfig.py", line 512, in get_path | return get_paths(scheme, vars, expand)[name] | File "/usr/lib/python3.8/sysconfig.py", line 502, in get_paths | return _expand_vars(scheme, vars) | File "/usr/lib/python3.8/sysconfig.py", line 172, in _expand_vars | _extend_dict(vars, get_config_vars()) | File "/usr/lib/python3.8/sysconfig.py", line 550, in get_config_vars | _init_posix(_CONFIG_VARS) | File "/usr/lib/python3.8/sysconfig.py", line 421, in _init_posix | _temp = __import__(name, globals(), locals(), ['build_time_vars'], 0) | | ModuleNotFoundError: No module named '_sysconfigdata' | | Call Stack (most recent call first): | tools/pybind11Tools.cmake:16 (find_package) | CMakeLists.txt:33 (include) | | | -- Configuring incomplete, errors occurred! | See also "/home/bsp/yocto/imx-yocto-bsp-zeus/build-wayland/tmp/work/x86_64-linux/python3-pybind11-native/2.5.0-r0/build/CMakeFiles/CMakeOutput.log". | WARNING: exit code 1 from a shell command. | ERROR: Execution of '/home/bsp/yocto/imx-yocto-bsp-zeus/build-wayland/tmp/work/x86_64-linux/python3-pybind11-native/2.5.0-r0/temp/run.do_configure.3278769' failed with exit code 1: | -- The CXX compiler identification is GNU 9.3.0 | -- Check for working CXX compiler: /home/bsp/yocto/imx-yocto-bsp-zeus/build-wayland/tmp/hosttools/g++ | -- Check for working CXX compiler: /home/bsp/yocto/imx-yocto-bsp-zeus/build-wayland/tmp/hosttools/g++ -- works | -- Detecting CXX compiler ABI info | -- Detecting CXX compiler ABI info - done | -- Detecting CXX compile features | -- Detecting CXX compile features - done | -- Found PythonInterp: /usr/bin/python3.8 (found version "3.8.5") | CMake Error at tools/FindPythonLibsNew.cmake:96 (message): | Python config failure: | | Traceback (most recent call last): | | File "", line 4, in | File "/usr/lib/python3.8/distutils/sysconfig.py", line 117, in get_python_inc | return sysconfig.get_path('platinclude') | File "/usr/lib/python3.8/sysconfig.py", line 512, in get_path | return get_paths(scheme, vars, expand)[name] | File "/usr/lib/python3.8/sysconfig.py", line 502, in get_paths | return _expand_vars(scheme, vars) | File "/usr/lib/python3.8/sysconfig.py", line 172, in _expand_vars | _extend_dict(vars, get_config_vars()) | File "/usr/lib/python3.8/sysconfig.py", line 550, in get_config_vars | _init_posix(_CONFIG_VARS) | File "/usr/lib/python3.8/sysconfig.py", line 421, in _init_posix | _temp = __import__(name, globals(), locals(), ['build_time_vars'], 0) | | ModuleNotFoundError: No module named '_sysconfigdata' | | Call Stack (most recent call first): | tools/pybind11Tools.cmake:16 (find_package) | CMakeLists.txt:33 (include) | | | -- Configuring incomplete, errors occurred! | See also "/home/bsp/yocto/imx-yocto-bsp-zeus/build-wayland/tmp/work/x86_64-linux/python3-pybind11-native/2.5.0-r0/build/CMakeFiles/CMakeOutput.log". | WARNING: exit code 1 from a shell command. | ERROR: Task (virtual:native:/home/bsp/yocto/imx-yocto-bsp-zeus/sources/meta-imx/meta-ml/recipes-devtools/python/python3-pybind11_2.5.0.bb:do_configure) failed with exit code '1'有人成功构建了吗? |
只有小组成员才能发言,加入小组>>
2135个成员聚集在这个小组
加入小组我的项目我做主,使用GN+Ninja来完成构建系统(VSCode开发RT106X)
37376 浏览 0 评论
NXP IMX8应用处理器快速入门必备:技巧、使用、设计指南
6775 浏览 1 评论
7793 浏览 1 评论
7642 浏览 0 评论
NXP i.MX6UL开发板(linux系统烧录+规格+硬件+模块移植)使用手册
5071 浏览 0 评论
1556浏览 2评论
关于NINA-W132 Wi-Fi模块SPI通信遇到的疑问求解
1207浏览 2评论
如何在MPC PowerPC MCU上首次刷写后禁用BDM?
749浏览 1评论
将HFREFR和LFREFR寄存器值设置为错误的值来将故障注入CMU,但CMU_ISR值始终为零,为什么?
735浏览 1评论
将SPSDK for FRDM-MCX-W71 SDK与VS一起安装时出现hidapi构建错误怎么解决?
678浏览 1评论
/9
GMT+8, 2025-12-1 21:34 , Processed in 0.638077 second(s), Total 70, Slave 53 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
634
