电子发烧友论坛|
我有两个独立的设置
设置 1:
mt9034 只是任何相机的替代品,与我无关。 v4l2-ctl -d /dev/video3 --stream-mmap=4 --verbose VIDIOC_QUERYCAP: ok VIDIOC_REQBUFS returned 0 (Success) VIDIOC_QUERYBUF returned 0 (Success) VIDIOC_QUERYBUF returned 0 (Success) VIDIOC_QUERYBUF returned 0 (Success) VIDIOC_QUERYBUF returned 0 (Success) VIDIOC_QBUF returned 0 (Success) VIDIOC_QBUF returned 0 (Success) VIDIOC_QBUF returned 0 (Success) VIDIOC_QBUF returned 0 (Success) VIDIOC_STREAMON returned 0 (Success) cap dqbuf: 0 seq: 0 bytesused: 4147200 ts: 1512.118705 delta: 1512118.705 ms (ts-monotonic, ts-src-eof) 但是当我尝试使用设置 2 进行完全相同的设置时,我立即收到错误消息 v4l2-ctl -d /dev/video3 --stream-mmap=4 --verbose VIDIOC_QUERYCAP: ok VIDIOC_REQBUFS returned -1 (Resource temporarily unavailable) 设置 2 的媒体管道和 v4l2-ctl 输出: # media-ctl -p Media controller API version 5.10.72 Media device information ------------------------ driver mxc-md model FSL Capture Media Device serial bus info hw revision 0x0 driver version 5.10.72 Device topology - entity 1: mxc_isi.0 (16 pads, 2 links) type V4L2 subdev subtype Unknown flags 0 pad0: Sink <- "mxc-mipi-csi2.0":4 [ENABLED] pad1: Sink pad2: Sink pad3: Sink pad4: Sink pad5: Sink pad6: Sink pad7: Sink pad8: Sink pad9: Sink pad10: Sink pad11: Sink pad12: Source -> "mxc_isi.0.capture":0 [ENABLED] pad13: Source pad14: Source pad15: Sink - entity 18: mxc_isi.0.capture (1 pad, 1 link) type Node subtype V4L flags 0 device node name /dev/video2 pad0: Sink <- "mxc_isi.0":12 [ENABLED] - entity 22: mxc-mipi-csi2.0 (8 pads, 2 links) type Node subtype V4L flags 0 device node name /dev/v4l-subdev0 pad0: Sink <- "mt9034 4-0010":0 [ENABLED,IMMUTABLE] pad1: Sink pad2: Sink pad3: Sink pad4: Source -> "mxc_isi.0":0 [ENABLED] pad5: Source pad6: Source pad7: Source - entity 31: mxc-mipi-csi2.1 (8 pads, 1 link) type Node subtype V4L flags 0 device node name /dev/v4l-subdev1 pad0: Sink <- "basler-camera-vvcam 5-0036":0 [ENABLED,IMMUTABLE] pad1: Sink pad2: Sink pad3: Sink pad4: Source pad5: Source pad6: Source pad7: Source - entity 40: basler-camera-vvcam 5-0036 (1 pad, 1 link) type V4L2 subdev subtype Sensor flags 0 device node name /dev/v4l-subdev2 pad0: Source -> "mxc-mipi-csi2.1":0 [ENABLED,IMMUTABLE] - entity 42: mt9034 4-0010 (1 pad, 1 link) type V4L2 subdev subtype Sensor flags 0 device node name /dev/v4l-subdev3 pad0: Source [fmt:UYVY8_2X8/640x720 field:none colorspace:srgb crop:(0,0)/640x720] -> "mxc-mipi-csi2.0":0 [ENABLED,IMMUTABLE] # media-ctl -p -d /dev/media1 Media controller API version 5.10.72 Media device information ------------------------ driver vvcam-video model viv_media serial bus info hw revision 0x0 driver version 5.10.72 Device topology - entity 1: viv_v4l21 (1 pad, 1 link) type Node subtype V4L flags 0 device node name /dev/video3 pad0: Sink <- "vvcam-isp.1":0 [ENABLED] - entity 5: vvcam-isp.1 (1 pad, 1 link) type Node subtype V4L flags 0 device node name /dev/v4l-subdev4 pad0: Source -> "viv_v4l21":0 [ENABLED] - entity 7: vvcam-dwe.1 (2 pads, 0 link) type Node subtype V4L flags 0 device node name /dev/v4l-subdev5 pad0: Source pad1: Sink # v4l2-ctl -d /dev/video3 -D Driver Info: Driver name : viv_v4l2_device Card type : VIV Bus info : platform:viv1 Driver version : 5.10.72 Capabilities : 0x84200001 Video Capture Streaming Extended Pix Format Device Capabilities Device Caps : 0x04200001 Video Capture Streaming Extended Pix Format Media Driver Info: Driver name : vvcam-video Model : viv_media Serial : Bus info : Media version : 5.10.72 Hardware revision: 0x00000000 (0) Driver version : 5.10.72 Interface Info: ID : 0x03000003 Type : V4L Video Entity Info: ID : 0x00000001 (1) Name : viv_v4l21 Function : V4L2 I/O Pad 0x01000002 : 0: Sink, Must Connect Link 0x0200000a: from remote pad 0x1000009 of entity 'vvcam-isp.1': Data, Enabled # v4l2-ctl --list-devices [ 349.939100] enter isp_mi_stop (): /dev/v4l-subdev0 (): /dev/v4l-subdev1 /dev/v4l-subdev4 /dev/v4l-subdev5 (csi1): /dev/v4l-subdev2 mxc-isi-cap (platform:32e00000.isi:cap_devic): /dev/video2 FSL Capture Media Device (platform:mxc-md): /dev/media0 VIV (platform:viv1): /dev/video3 vsi_v4l2dec (platform:vsi_v4l2dec): /dev/video1 vsi_v4l2enc (platform:vsi_v4l2enc): /dev/video0 viv_media (platform:vvcam-video): /dev/media1 我确实在 dmesg 中注意到两种设置之间的差异。当我尝试在设置 2 期间使用上面的 v4l2 命令进行流式传输时,我每次都会看到此输出。它没有出现在设置 1 中。 [ 1481.632505] viv_post_event: unsubscribed event id =2 type=0x08002000 [ 1482.584451] viv_post_event: unsubscribed event id =14 type=0x08002000 [ 1482.748439] viv_post_event: unsubscribed event id =14 type=0x08002000 [ 1482.924447] viv_post_event: unsubscribed event id =1 type=0x08002000 据我所知,isp 已成功启动 Oct 26 18:24:35 ucm-imx8m-plus systemd[1]: Started ISP i.MX 8Mplus daemon. Oct 26 18:24:35 ucm-imx8m-plus start_isp.sh[1458]: Starting isp_media_server Oct 26 18:24:35 ucm-imx8m-plus start_isp.sh[1458]: DAA3840_30MC_266 on ISP 1 Oct 26 18:24:35 ucm-imx8m-plus start_isp.sh[1458]: RUN_SCRIPT=/opt/imx8-isp/bin/run.sh Oct 26 18:24:35 ucm-imx8m-plus start_isp.sh[1458]: RUN_SCRIPT_PATH=/opt/imx8-isp/bin Oct 26 18:24:36 ucm-imx8m-plus start_isp.sh[1458]: Apply configuration DAA3840_30MC_266... Oct 26 18:24:36 ucm-imx8m-plus start_isp.sh[1458]: Loading module basler-camera-driver-vvcam ... Oct 26 18:24:36 ucm-imx8m-plus start_isp.sh[1458]: basler_camera_driver_vvcam Oct 26 18:24:36 ucm-imx8m-plus start_isp.sh[1538]: basler_camera_driver_vvcam 20480 0 Oct 26 18:24:36 ucm-imx8m-plus start_isp.sh[1458]: basler-camera-driver-vvcam already loaded. Oct 26 18:24:36 ucm-imx8m-plus start_isp.sh[1458]: Loading module imx8-media-dev ... Oct 26 18:24:36 ucm-imx8m-plus start_isp.sh[1458]: imx8_media_dev Oct 26 18:24:36 ucm-imx8m-plus start_isp.sh[1458]: Loaded /lib/modules/5.10.72/kernel/drivers/staging/media/imx/imx8-media-dev.ko Oct 26 18:24:36 ucm-imx8m-plus start_isp.sh[1458]: Loading module vvcam-video ... Oct 26 18:24:36 ucm-imx8m-plus start_isp.sh[1458]: vvcam_video Oct 26 18:24:36 ucm-imx8m-plus start_isp.sh[1562]: vvcam_video 36864 0 Oct 26 18:24:36 ucm-imx8m-plus start_isp.sh[1458]: vvcam-video already loaded. Oct 26 18:24:36 ucm-imx8m-plus start_isp.sh[1458]: Loading module vvcam-dwe ... Oct 26 18:24:36 ucm-imx8m-plus start_isp.sh[1458]: vvcam_dwe Oct 26 18:24:36 ucm-imx8m-plus start_isp.sh[1567]: vvcam_dwe 28672 1 Oct 26 18:24:36 ucm-imx8m-plus start_isp.sh[1458]: vvcam-dwe already loaded. Oct 26 18:24:36 ucm-imx8m-plus start_isp.sh[1458]: Loading module vvcam-isp ... Oct 26 18:24:36 ucm-imx8m-plus start_isp.sh[1458]: vvcam_isp Oct 26 18:24:36 ucm-imx8m-plus start_isp.sh[1572]: vvcam_isp 65536 1 Oct 26 18:24:36 ucm-imx8m-plus start_isp.sh[1458]: vvcam-isp already loaded. Oct 26 18:24:36 ucm-imx8m-plus start_isp.sh[1458]: Starting isp_media_server with configuration CAMERA1 |
相关推荐 |
只有小组成员才能发言,加入小组>>
2139个成员聚集在这个小组
加入小组我的项目我做主,使用GN+Ninja来完成构建系统(VSCode开发RT106X)
37405 浏览 0 评论
NXP IMX8应用处理器快速入门必备:技巧、使用、设计指南
6800 浏览 1 评论
7830 浏览 1 评论
7665 浏览 0 评论
NXP i.MX6UL开发板(linux系统烧录+规格+硬件+模块移植)使用手册
5089 浏览 0 评论
1584浏览 2评论
关于NINA-W132 Wi-Fi模块SPI通信遇到的疑问求解
1224浏览 2评论
如何在MPC PowerPC MCU上首次刷写后禁用BDM?
769浏览 1评论
将HFREFR和LFREFR寄存器值设置为错误的值来将故障注入CMU,但CMU_ISR值始终为零,为什么?
760浏览 1评论
将SPSDK for FRDM-MCX-W71 SDK与VS一起安装时出现hidapi构建错误怎么解决?
700浏览 1评论
/9
GMT+8, 2025-12-13 17:57 , Processed in 1.543369 second(s), Total 40, Slave 33 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
486
