电子发烧友论坛|
我正在尝试在 VSCode 中调试一个项目,我正在使用 Wrover Kit v4.1,这是在 macOs 上,这就是我正在做的事情:
打开 OpenOCD:代码:全选 openocd -f board/esp32-wrover-kit-3.3v.cfg 代码:全选 openocd -f board/esp32-wrover-kit-3.3v.cfg Open On-Chip Debugger v0.11.0-esp32-20221026 (2022-10-26-14:48) Licensed under GNU GPL v2 For bug reports, read Info : Listening on port 6666 for tcl connections Info : Listening on port 4444 for telnet connections Info : ftdi: if you experience problems at higher adapter clocks, try the command "ftdi tdo_sample_edge falling" Info : clock speed 20000 kHz Info : JTAG tap: esp32.cpu0 tap/device found: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0x1) Info : JTAG tap: esp32.cpu1 tap/device found: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0x1) Info : starting gdb server for esp32.cpu0 on 3333 Info : Listening on port 3333 for gdb connections Info : [esp32.cpu0] Target halted, PC=0x400D9687, debug_reason=00000001 Info : [esp32.cpu0] Reset cause (3) - (Software core reset) Info : Set GDB target to 'esp32.cpu0' Info : [esp32.cpu1] Target halted, PC=0x40112852, debug_reason=00000000 Info : [esp32.cpu1] Reset cause (14) - (CPU1 reset by CPU0) 在 vscode 中启动调试:我在 OpenOCD 控制台上得到以下信息: 代码:全选 Info : accepting 'gdb' connectionon tcp/3333 Warn : No symbols for FreeRTOS! Info : [esp32.cpu0] Target halted, PC=0x40092612, debug_reason=00000001 Info : Flash mapping 0: 0x10020 -> 0x3f400020, 116 KB Info : Flash mapping 1: 0x30020 -> 0x400d0020, 277 KB Info : [esp32.cpu0] Target halted, PC=0x40092612, debug_reason=00000001 Info : Auto-detected flash bank 'esp32.cpu0.flash' size 4096 KB Info : Using flash bank 'esp32.cpu0.flash' size 4096 KB Info : [esp32.cpu0] Target halted, PC=0x40092612, debug_reason=00000001 Info : Flash mapping 0: 0x10020 -> 0x3f400020, 116 KB Info : Flash mapping 1: 0x30020 -> 0x400d0020, 277 KB Info : Using flash bank 'esp32.cpu0.irom' size 280 KB Info : [esp32.cpu0] Target halted, PC=0x40092612, debug_reason=00000001 Info : Flash mapping 0: 0x10020 -> 0x3f400020, 116 KB Info : Flash mapping 1: 0x30020 -> 0x400d0020, 277 KB Info : Using flash bank 'esp32.cpu0.drom' size 120 KB Info : New GDB Connection: 1, Target esp32.cpu0, state: halted Info : JTAG tap: esp32.cpu0 tap/device found: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0x1) Info : JTAG tap: esp32.cpu1 tap/device found: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0x1) Info : [esp32.cpu0] requesting target halt and executing a soft reset Info : [esp32.cpu0] Debug controller was reset. Info : [esp32.cpu0] Core was reset. Info : [esp32.cpu0] Target halted, PC=0x500000CF, debug_reason=00000000 Info : [esp32.cpu0] Reset cause (3) - (Software core reset) Info : [esp32.cpu1] requesting target halt and executing a soft reset Info : [esp32.cpu0] Core was reset. Info : [esp32.cpu0] Target halted, PC=0x40000400, debug_reason=00000000 Info : [esp32.cpu1] Debug controller was reset. Info : [esp32.cpu1] Core was reset. Info : [esp32.cpu1] Target halted, PC=0x40000400, debug_reason=00000000 Info : [esp32.cpu1] Reset cause (14) - (CPU1 reset by CPU0) Info : [esp32.cpu0] Reset cause (3) - (Software core reset) Info : [esp32.cpu0] Target halted, PC=0x40092612, debug_reason=00000001 Info : [esp32.cpu0] Target halted, PC=0x400D9687, debug_reason=00000001 Info : Set GDB target to 'esp32.cpu0' Info : [esp32.cpu1] Target halted, PC=0x40112852, debug_reason=00000000 Info : [esp32.cpu0] Target halted, PC=0x40092612, debug_reason=00000001 Warn : [esp32.cpu0] Failed reading 32 bytes at address 0x40115230 在 VSCode 中它卡住了 代码:全选 static void heap_bubble_down(int index) { while (index < TAG_CACHE_SIZE / 2) { int left_index = index * 2 + 1; int right_index = left_index + 1; int next = (s_log_cache[left_index].generation < s_log_cache[right_index].generation) ? left_index : right_index; heap_swap(index, next); index = next; } } 我无法介入或运行,我的 launch.json 是: 代码:全选 { "name": "ESP32 OpenOCD", "type": "cppdbg", "request": "launch", "cwd": "${workspaceFolder}/build", "program": "${workspaceFolder}/build/hello_opencv.elf", "miDebuggerPath": "/Users/dariovazquez/.espressif/tools/xtensa-esp-elf-gdb/11.2_20220823/xtensa-esp-elf-gdb/bin/xtensa-esp32-elf-gdb", "targetArchitecture": "arm64", "setupCommands": [ { "text" : "target extended-remote :3333"}, { "text" : "set remote hardware-watchpoint-limit 2"}, { "text" : "monitor reset halt"}, { "text" : "flushregs"} ] } 有什么建议么?我错过了什么? |
只有小组成员才能发言,加入小组>>
2135个成员聚集在这个小组
加入小组我的项目我做主,使用GN+Ninja来完成构建系统(VSCode开发RT106X)
37376 浏览 0 评论
NXP IMX8应用处理器快速入门必备:技巧、使用、设计指南
6775 浏览 1 评论
7793 浏览 1 评论
7642 浏览 0 评论
NXP i.MX6UL开发板(linux系统烧录+规格+硬件+模块移植)使用手册
5071 浏览 0 评论
1555浏览 2评论
关于NINA-W132 Wi-Fi模块SPI通信遇到的疑问求解
1207浏览 2评论
如何在MPC PowerPC MCU上首次刷写后禁用BDM?
749浏览 1评论
将HFREFR和LFREFR寄存器值设置为错误的值来将故障注入CMU,但CMU_ISR值始终为零,为什么?
734浏览 1评论
将SPSDK for FRDM-MCX-W71 SDK与VS一起安装时出现hidapi构建错误怎么解决?
677浏览 1评论
/9
GMT+8, 2025-12-1 17:24 , Processed in 0.794238 second(s), Total 70, Slave 53 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
631
