电子发烧友论坛|
大家好
我们在我们的一款产品中使用 i.MX28,它使用以下寄存器设置在 180MHz EMI_CLK 上工作—— volatile unsigned int * DRAM_REG = (volatile unsigned int*) HW_DRAM_CTL00_ADDR; DRAM_REG[0] = 0x00000000; DRAM_REG[1] = 0x00000000; DRAM_REG[2] = 0x00000000; DRAM_REG[3] = 0x00000000; DRAM_REG[4] = 0x00000000; DRAM_REG[5] = 0x00000000; DRAM_REG[6] = 0x00000000; DRAM_REG[7] = 0x00000000; DRAM_REG[8] = 0x00000000; DRAM_REG[9] = 0x00000000; DRAM_REG[10] = 0x00000000; DRAM_REG[11] = 0x00000000; DRAM_REG[12] = 0x00000000; DRAM_REG[13] = 0x00000000; DRAM_REG[14] = 0x00000000; DRAM_REG[15] = 0x00000000; DRAM_REG[16] = 0x00000000; DRAM_REG[17] = 0x00000100; DRAM_REG[18] = 0x00000000; DRAM_REG[19] = 0x00000000; DRAM_REG[20] = 0x00000000; DRAM_REG[21] = 0x00000000; DRAM_REG[22] = 0x00000000; DRAM_REG[23] = 0x00000000; DRAM_REG[24] = 0x00000000; DRAM_REG[25] = 0x00000000; DRAM_REG[26] = 0x00010101; DRAM_REG[27] = 0x01010101; DRAM_REG[28] = 0x000f0f01; DRAM_REG[29] = 0x0f02020a; DRAM_REG[30] = 0x00000000; DRAM_REG[31] = 0x00000101;//64 MB RAM with 4 banks instaed of 8 banks DRAM_REG[32] = 0x00000100; DRAM_REG[33] = 0x00000100; DRAM_REG[34] = 0x00000000; DRAM_REG[35] = 0x00000002; DRAM_REG[36] = 0x01010000; DRAM_REG[37] = 0x07080403; DRAM_REG[38] = 0x06005003; DRAM_REG[39] = 0x0a0000c8; DRAM_REG[40] = 0x0200A06C; DRAM_REG[41] = 0x0002030c; DRAM_REG[42] = 0x0036a609; DRAM_REG[43] = 0x031a0612; DRAM_REG[44] = 0x02030202; DRAM_REG[45] = 0x00c8001c; DRAM_REG[46] = 0x00000000; DRAM_REG[47] = 0x00000000; DRAM_REG[48] = 0x00012100; DRAM_REG[49] = 0xffff0303; DRAM_REG[50] = 0x00012100; DRAM_REG[51] = 0xffff0303; DRAM_REG[52] = 0x00012100; DRAM_REG[53] = 0xffff0303; DRAM_REG[54] = 0x00012100; DRAM_REG[55] = 0xffff0303; DRAM_REG[56] = 0x00000003; DRAM_REG[57] = 0x00000000; DRAM_REG[58] = 0x00000000; DRAM_REG[59] = 0x00000000; DRAM_REG[60] = 0x00000000; DRAM_REG[61] = 0x00000000; DRAM_REG[62] = 0x00000000; DRAM_REG[63] = 0x00000000; DRAM_REG[64] = 0x00000000; DRAM_REG[65] = 0x00000000; DRAM_REG[66] = 0x00000612; DRAM_REG[67] = 0x01000f02; DRAM_REG[68] = 0x06120612; DRAM_REG[69] = 0x00000200; DRAM_REG[70] = 0x00020007; DRAM_REG[71] = 0xf4004a27; DRAM_REG[72] = 0xf4004a27; DRAM_REG[73] = 0xf4004a27; DRAM_REG[74] = 0xf4004a27; DRAM_REG[75] = 0x07000300; DRAM_REG[76] = 0x07000300; DRAM_REG[77] = 0x07400300; DRAM_REG[78] = 0x07400300; DRAM_REG[79] = 0x00000005; DRAM_REG[80] = 0x00000000; DRAM_REG[81] = 0x00000000; DRAM_REG[82] = 0x00000000; DRAM_REG[83] = 0x00000000; DRAM_REG[84] = 0x08040201; DRAM_REG[85] = 0x000f1133; DRAM_REG[86] = 0x00000000; DRAM_REG[87] = 0x00001f04; DRAM_REG[88] = 0x00001f04; DRAM_REG[89] = 0x00001f04; DRAM_REG[90] = 0x00001f04; DRAM_REG[91] = 0x00001f04; DRAM_REG[92] = 0x00001f04; DRAM_REG[93] = 0x00001f04; DRAM_REG[94] = 0x00001f04; DRAM_REG[95] = 0x00000000; DRAM_REG[96] = 0x00000000; DRAM_REG[97] = 0x00000000; DRAM_REG[98] = 0x00000000; DRAM_REG[99] = 0x00000000; DRAM_REG[100] = 0x00000000; DRAM_REG[101] = 0x00000000; DRAM_REG[102] = 0x00000000; DRAM_REG[103] = 0x00000000; DRAM_REG[104] = 0x00000000; DRAM_REG[105] = 0x00000000; DRAM_REG[106] = 0x00000000; DRAM_REG[107] = 0x00000000; DRAM_REG[108] = 0x00000000; DRAM_REG[109] = 0x00000000; DRAM_REG[110] = 0x00000000; DRAM_REG[111] = 0x00000000; DRAM_REG[112] = 0x00000000; DRAM_REG[113] = 0x00000000; DRAM_REG[114] = 0x00000000; DRAM_REG[115] = 0x00000000; DRAM_REG[116] = 0x00000000; DRAM_REG[117] = 0x00000000; DRAM_REG[118] = 0x00000000; DRAM_REG[119] = 0x00000000; DRAM_REG[120] = 0x00000000; DRAM_REG[121] = 0x00000000; DRAM_REG[122] = 0x00000000; DRAM_REG[123] = 0x00000000; DRAM_REG[124] = 0x00000000; DRAM_REG[125] = 0x00000000; DRAM_REG[126] = 0x00000000; DRAM_REG[127] = 0x00000000; DRAM_REG[128] = 0x00000000; DRAM_REG[129] = 0x00000000; DRAM_REG[130] = 0x00000000; DRAM_REG[131] = 0x00000000; DRAM_REG[132] = 0x00000000; DRAM_REG[133] = 0x00000000; DRAM_REG[134] = 0x00000000; DRAM_REG[135] = 0x00000000; DRAM_REG[136] = 0x00000000; DRAM_REG[137] = 0x00000000; DRAM_REG[138] = 0x00000000; DRAM_REG[139] = 0x00000000; DRAM_REG[140] = 0x00000000; DRAM_REG[141] = 0x00000000; DRAM_REG[142] = 0x00000000; DRAM_REG[143] = 0x00000000; DRAM_REG[144] = 0x00000000; DRAM_REG[145] = 0x00000000; DRAM_REG[146] = 0x00000000; DRAM_REG[147] = 0x00000000; DRAM_REG[148] = 0x00000000; DRAM_REG[149] = 0x00000000; DRAM_REG[150] = 0x00000000; DRAM_REG[151] = 0x00000000; DRAM_REG[152] = 0x00000000; DRAM_REG[153] = 0x00000000; DRAM_REG[154] = 0x00000000; DRAM_REG[155] = 0x00000000; DRAM_REG[156] = 0x00000000; DRAM_REG[157] = 0x00000000; DRAM_REG[158] = 0x00000000; DRAM_REG[159] = 0x00000000; DRAM_REG[160] = 0x00000000; DRAM_REG[161] = 0x00000000; DRAM_REG[162] = 0x00010000; DRAM_REG[163] = 0x00030404; DRAM_REG[164] = 0x00000003; DRAM_REG[165] = 0x00000000; DRAM_REG[166] = 0x00000000; DRAM_REG[167] = 0x00000000; DRAM_REG[168] = 0x00000000; DRAM_REG[169] = 0x00000000; DRAM_REG[170] = 0x00000000; DRAM_REG[171] = 0x01010000; DRAM_REG[172] = 0x01000000; DRAM_REG[173] = 0x03030000; DRAM_REG[174] = 0x00010303; DRAM_REG[175] = 0x01020202; DRAM_REG[176] = 0x00000000; DRAM_REG[177] = 0x02040303; DRAM_REG[178] = 0x21002103; DRAM_REG[179] = 0x00061200; DRAM_REG[180] = 0x06120612; DRAM_REG[181] = 0x06420642; DRAM_REG[182] = 0x04420442; DRAM_REG[183] = 0x20042004; DRAM_REG[184] = 0x20042004; DRAM_REG[185] = 0x80008000; DRAM_REG[186] = 0x80008000; DRAM_REG[187] = 0xC000C000; DRAM_REG[188] = 0xC000C000; DRAM_REG[189] = 0xffffffff; ---------------------------------------------- ---------------------------------------------- ------------------------------ 另一个 reg FRAC0 设置在这里 div =24 //180MHz HW_CLKCTRL_FRAC0_SET(0x00008000); HW_CLKCTRL_FRAC0_SET(0x00003F00); div = (~div); HW_CLKCTRL_FRAC0_CLR(BF_CLKCTRL_FRAC0_EMIFRAC(div)); HW_CLKCTRL_FRAC0_CLR(0x00008000); 我们想把时钟从180MHz改成90MHz,所以想知道代码中哪里需要改动?这些电阻器设置都在 uboot 和 BSP 中,我们正在两个地方更新。我们尝试通过更改一些寄存器设置并观察到时钟已更改但应用程序未启动。 |
只有小组成员才能发言,加入小组>>
2135个成员聚集在这个小组
加入小组我的项目我做主,使用GN+Ninja来完成构建系统(VSCode开发RT106X)
37376 浏览 0 评论
NXP IMX8应用处理器快速入门必备:技巧、使用、设计指南
6775 浏览 1 评论
7793 浏览 1 评论
7642 浏览 0 评论
NXP i.MX6UL开发板(linux系统烧录+规格+硬件+模块移植)使用手册
5071 浏览 0 评论
1555浏览 2评论
关于NINA-W132 Wi-Fi模块SPI通信遇到的疑问求解
1207浏览 2评论
如何在MPC PowerPC MCU上首次刷写后禁用BDM?
749浏览 1评论
将HFREFR和LFREFR寄存器值设置为错误的值来将故障注入CMU,但CMU_ISR值始终为零,为什么?
734浏览 1评论
将SPSDK for FRDM-MCX-W71 SDK与VS一起安装时出现hidapi构建错误怎么解决?
677浏览 1评论
/9
GMT+8, 2025-12-1 17:26 , Processed in 0.623773 second(s), Total 70, Slave 53 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1304
