电子发烧友论坛|
我们使用的是 Advantech 的 PCIE 88W9098 AIS-165 无线模块,但未能成功将该设备集成到运行 OpenWRT 21.03 的 LS1088ARDB 上。
我们目前正在使用针对 OpenWRT 提供的内核工具链 (5.4.188) 编译的驱动程序和固件版本 PCIE9098--17.92.5.p9-MM5X17366.p5-GPL-(FP92),这表明在编译时没有问题。 按照用户指南的说明加载驱动程序后,不会抛出任何错误。 我们正在使用以下 mod 配置文件 SD8997 = { cfg80211_wext=0xf wfd_name=p2p max_vir_bss=1 cal_data_cfg=nxp/WlanCalData_ext_8997_QFN_TB.conf drv_mode=7 } USB8997 = { cfg80211_wext=0xf wfd_name=p2p max_vir_bss=1 cal_data_cfg=nxp/WlanCalData_ext_8997_QFN_TB.conf drv_mode=7 } PCIE8997 = { cfg80211_wext=0xf wfd_name=p2p max_vir_bss=1 cal_data_cfg=nxp/WlanCalData_ext_8997_QFN_TB.conf drv_mode=7 } PCIE9098 = { cfg80211_wext=0xf sta_name=radio wfd_name=p2p max_vir_bss=1 cal_data_cfg=none drv_mode=7 mac_addr=00:50:43:20:12:34 }dmesg 日志显示没有错误 [ 824.095662] wlan: Loading MWLAN driver [ 824.099569] wlan: Register to Bus Driver... [ 824.103953] Attach moal handle ops, card interface type: 0x206 [ 824.109842] PCIE9098: init module param from usr cfg [ 824.114835] card_type: PCIE9098, config block: 0 [ 824.119455] cfg80211_wext=0xf [ 824.122423] sta_name=radio [ 824.125122] wfd_name=p2p [ 824.127658] cal_data_cfg=none [ 824.130625] drv_mode = 7 [ 824.133150] mac_addr=00:50:43:20:12:34 [ 824.136909] rx_work=1 cpu_num=4 [ 824.140057] Attach mlan adapter operations.card_type is 0x206. [ 824.146402] Request firmware: nxp/pcieuart9098_combo_v1.bin [ 824.152395] WLAN FW already running! Skip FW download [ 824.157454] WLAN FW is active [ 824.160420] on_time is 824070043985 [ 824.179626] fw_cap_info=0x81c3fa3, dev_cap_mask=0xffffffff [ 824.185121] max_p2p_conn = 8, max_sta_conn = 64 [ 824.191602] Register NXP 802.11 Adapter radio0 [ 824.196119] wlan: uap%d set max_mtu 2000 [ 824.200736] Register NXP 802.11 Adapter uap0 [ 824.205901] Register NXP 802.11 Adapter p2p0 [ 824.210242] wlan: version = PCIE9098--17.92.5.p9-MM5X17366.p5-GPL-(FP92) [ 824.217603] Attach moal handle ops, card interface type: 0x206 [ 824.223512] PCIE9098: init module param from usr cfg [ 824.228551] Configuration block, fallback processing [ 824.233525] Configuration fallback to, card_type: 0x206, blk_id: 0x0 [ 824.239902] rx_work=1 cpu_num=4 [ 824.243055] Attach mlan adapter operations.card_type is 0x206. [ 824.250407] Request firmware: nxp/pcieuart9098_combo_v1.bin [ 824.256444] WLAN FW already running! Skip FW download [ 824.261501] WLAN FW is active [ 824.264466] on_time is 824174090177 [ 824.271750] fw_cap_info=0x81c3fa3, dev_cap_mask=0xffffffff [ 824.277330] max_p2p_conn = 8, max_sta_conn = 64 [ 824.283693] Register NXP 802.11 Adapter radio1 [ 824.288250] wlan: muap%d set max_mtu 2000 [ 824.292975] Register NXP 802.11 Adapter muap0 [ 824.298114] Register NXP 802.11 Adapter p2p1 [ 824.302468] wlan: version = PCIE9098--17.92.5.p9-MM5X17366.p5-GPL-(FP92) [ 824.309842] wlan: Register to Bus Driver Done [ 824.314220] wlan: Driver loaded successfully但是尝试使用 `iw list` 不会将任何内容打印到 stdout 或 stderr 尝试“mlan radio0 getsignal”会产生以下错误: [ 7042.831417] Can not get RSSI in disconnected state mlanutl: No error information mlanutl: getsignal fail我们不确定是什么导致了这个错误,但是转储 adapter0/radio0 的 `debug` 和 `info` 会产生 `media_state=Disconnected`。 我们还尝试使用 `wpa_supplicant` 尝试连接到另一个 AP,但它也不起作用,并且声明设备不支持使用 nl80211 的关联。但是当使用 `wext` 时,它也会抛出错误。 请参阅下面的日志转储。 ---------------------------------------------- ---------- 调试日志 driver_name = "wlan" driver_version = PCIE9098--17.92.5.p9-MM5X17366.p5-GPL-(FP92) interface_name="radio0" firmware_major_version=17.92.5 bss_mode ="Managed" media_state="Disconnected" mac_address="00:50:43:20:12:34" multicast_count="2" essid="" bssid="00:00:00:00:00:00" channel="0" region_code = "10" multicast_address[0]="33:33:00:00:00:01" multicast_address[1]="33:33:00:00:00:02" num_tx_bytes = 0 num_rx_bytes = 0 num_tx_pkts = 0 num_rx_pkts = 0 num_tx_pkts_dropped = 0 num_rx_pkts_dropped = 0 num_tx_pkts_err = 0 num_rx_pkts_err = 0 carrier off tx queue 0: stopped tx queue 1: stopped tx queue 2: stopped tx queue 3: stopped === tp_acnt.on:0 drop_point:0 === ====Tx accounting==== [0] Tx packets : 0 [0] Tx packets last: 0 [0] Tx packets rate: 0 [0] Tx bytes : 0 [0] Tx bytes last : 0 [0] Tx bytes rate : 0Mbps [1] Tx packets : 0 [1] Tx packets last: 0 [1] Tx packets rate: 0 [1] Tx bytes : 0 [1] Tx bytes last : 0 [1] Tx bytes rate : 0Mbps [2] Tx packets : 0 [2] Tx packets last: 0 [2] Tx packets rate: 0 [2] Tx bytes : 0 [2] Tx bytes last : 0 [2] Tx bytes rate : 0Mbps [3] Tx packets : 0 [3] Tx packets last: 0 [3] Tx packets rate: 0 [3] Tx bytes : 0 [3] Tx bytes last : 0 [3] Tx bytes rate : 0Mbps [4] Tx packets : 0 [4] Tx packets last: 0 [4] Tx packets rate: 0 [4] Tx bytes : 0 [4] Tx bytes last : 0 [4] Tx bytes rate : 0Mbps Tx amsdu cnt : 0 Tx amsdu cnt last : 0 Tx amsdu cnt rate : 0 Tx amsdu pkt cnt : 0 Tx amsdu pkt cnt last : 0 Tx amsdu pkt cnt rate : 0 Tx intr cnt : 0 Tx intr last : 0 Tx intr rate : 0 Tx pending : 0 Tx xmit skb realloc : 0 Tx stop queue cnt : 0 ====Rx accounting==== [0] Rx packets : 0 [0] Rx packets last: 0 [0] Rx packets rate: 0 [0] Rx bytes : 0 [0] Rx bytes last : 0 [0] Rx bytes rate : 0Mbps [1] Rx packets : 0 [1] Rx packets last: 0 [1] Rx packets rate: 0 [1] Rx bytes : 0 [1] Rx bytes last : 0 [1] Rx bytes rate : 0Mbps [2] Rx packets : 0 [2] Rx packets last: 0 [2] Rx packets rate: 0 [2] Rx bytes : 0 [2] Rx bytes last : 0 [2] Rx bytes rate : 0Mbps [3] Rx packets : 0 [3] Rx packets last: 0 [3] Rx packets rate: 0 [3] Rx bytes : 0 [3] Rx bytes last : 0 [3] Rx bytes rate : 0Mbps [4] Rx packets : 0 [4] Rx packets last: 0 [4] Rx packets rate: 0 [4] Rx bytes : 0 [4] Rx bytes last : 0 [4] Rx bytes rate : 0Mbps Rx amsdu cnt : 0 Rx amsdu cnt last : 0 Rx amsdu cnt rate : 0 Rx amsdu pkt cnt : 0 Rx amsdu pkt cnt last : 0 Rx amsdu pkt cnt rate : 0 Rx intr cnt : 0 Rx intr last : 0 Rx intr rate : 0 Rx pending : 0 Rx pause : 0 Rx rdptr full cnt : 0 信息日志 drvdbg=519 mlan_processing=0 main_process_cnt=29 main_lock_flag=0 delay_task_flag=0 mlan_rx_processing=0 rx_pkts_queued=0 wmm_ac_vo=0 wmm_ac_vi=0 wmm_ac_be=0 wmm_ac_bk=0 max_tx_buf_size=4096 tx_buf_size=3103 curr_tx_buf_size=3103 ps_mode=1 ps_state=3 is_deep_sleep=1 wakeup_dev_req=1 wakeup_tries=0 wakeup_timeout=0 hs_configured=0 hs_activated=0 rx_pkts_queued=0 tx_pkts_queued=0 pps_uapsd_mode=0 sleep_pd=0 qos_cfg=0 tx_lock_flag=0 port_open=0 bypass_pkt_count=0 scan_processing=0 scan_state=0 num_cmd_timeout=0 timeout_cmd_id=0x0 timeout_cmd_act=0 last_cmd_id=0x23a 0x4d 0xb0 0x4d 0xb0 0xd6 0x1e 0xdf 0x28 0x4d last_cmd_act=0x1 0x1 0x1 0x1 0x0 0x0 0x0 0x1 0x213 0x0 last_cmd_index=3 last_cmd_resp_id=0x823a 0x804d 0x80b0 0x804d 0x80b0 0x80d6 0x801e 0x80df 0x8028 0x804d last_cmd_resp_index=3 last_event=0x0 0xb 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 last_event_index=1 num_no_cmd_node=0 num_cmd_h2c_fail=0 num_cmd_sleep_cfm_fail=0 num_tx_h2c_fail=0 num_alloc_buffer_failure=0 num_evt_deauth=0 num_evt_disassoc=0 num_evt_link_lost=0 num_cmd_deauth=0 num_cmd_assoc_ok=0 num_cmd_assoc_fail=0 num_cons_assoc_failure=0 cmd_sent=0 data_sent=0 data_sent_cnt=0 mp_rd_bitmap=0x0 curr_rd_port=0 mp_wr_bitmap=0x0 curr_wr_port=0 txbd_rdptr=0x0 txbd_wrptr=0x0 rxbd_rdptr=0x0 rxbd_wrptr=0x80 eventbd_rdptr=0x1 eventbd_wrptr=0x9 cmd_resp_received=0 event_received=0 num_tx_timeout=0 ioctl_pending=0 tx_pending=0 rx_pending=0 lock_count=63 malloc_count=50 vmalloc_count=7 mbufalloc_count=136 malloc_cons_count=4 main_state=4 driver_state=0 hs_skip_count=0 hs_force_count=0 txbd_rdptr=0x0 txbd_wrptr=0x0 rxbd_rdptr=0x0 rxbd_wrptr=0x80 eventbd_rdptr=0x1 event_wrptr=0x9 last_wr_index:0 txrx bd size:128 tcp_ack_drop_cnt=0 tcp_ack_cnt=0 tcp_ack_payload=0 wmm_tx_pending[0]:0 wmm_tx_pending[1]:0 wmm_tx_pending[2]:0 wmm_tx_pending[3]:0 |
只有小组成员才能发言,加入小组>>
2135个成员聚集在这个小组
加入小组我的项目我做主,使用GN+Ninja来完成构建系统(VSCode开发RT106X)
37376 浏览 0 评论
NXP IMX8应用处理器快速入门必备:技巧、使用、设计指南
6775 浏览 1 评论
7793 浏览 1 评论
7642 浏览 0 评论
NXP i.MX6UL开发板(linux系统烧录+规格+硬件+模块移植)使用手册
5071 浏览 0 评论
1556浏览 2评论
关于NINA-W132 Wi-Fi模块SPI通信遇到的疑问求解
1208浏览 2评论
如何在MPC PowerPC MCU上首次刷写后禁用BDM?
749浏览 1评论
将HFREFR和LFREFR寄存器值设置为错误的值来将故障注入CMU,但CMU_ISR值始终为零,为什么?
735浏览 1评论
将SPSDK for FRDM-MCX-W71 SDK与VS一起安装时出现hidapi构建错误怎么解决?
678浏览 1评论
/9
GMT+8, 2025-12-2 02:27 , Processed in 0.739269 second(s), Total 70, Slave 53 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
823
