大家好:
板子信息:imx6ull双网口分别通过MII(COL、CRS已使用)和RMII接口物理芯片ksz8721,系统使用linux4.1.15。 在使用imx6ull的MII接口的网口使用iperf3做压力测试时,内核会出现网络超时。打印信息如下: # iperf3 -c 192.168.1.11 -t 1024 [ 5] 122.00-123.00 sec 0.00 Bytes 0.00 bits/sec 0 15.7 KBytes [ 5] 123.00-124.00 sec 0.00 Bytes 0.00 bits/sec 0 15.7 KBytes [ 5] 124.00-125.00 sec 0.00 Bytes 0.00 bits/sec [5 KBytes5.sec 0 ] 125.00-126.00 秒 0.00 字节 0.00 位/秒 0 15.7 字节 [5] 126.00-127.00 秒 0.00 字节 0.00 位/秒 0 15.7 字节 [5] 127.00-128.00 秒 0.00 字节 0.00 位/秒 7 0 15 字节 [ 142.051928] ------------ [在此处剪切] ------------ [ 142.056571] 警告:CPU:0 PID:0 at net/sched/sch_generic.c :305 dev_watchdog+0x2dc/0x30c() [142.065014] NETDEV WATCHDOG: eth0 (fec): 传输队列 0 超时 [142.071284] 链接的模块: [ 142.074363] CPU: 0 PID: 0 Comm: swapper Not tainted 4.1.15- rt18-svn46 #126 [142.081241]硬件名称:Freescale i.MX6 Ultralite(设备树) [142.087424]回溯: [142.089905][<80013014>](dump_backtrace)来自[<80013234>](show_stack+0x18/0x1c) [ 142.097477] r7:804684d8 r6:00000131 r5:00000009 r4:00000000 [ 142.103205] [<8001321c>] (show_stack) 来自 [<80545e68>] (dump_stack+0x24/0x28) [142.110442] [<80545e44>](dump_stack)来自[<8002d2b0>](warn_slowpath_common+0x88/0xb4)[142.118546] [142.118546] [ <8002d2228> ] ] r8:00000000 r7:80779f52 r6:80750610 r5:9a313a00 r4:806c8c60 [ 142.134045] [<8002d2e0>] (warn_slowpath_fmt) from [<804684d8>] (dev_watchdog+0x2dc/0x30c) [ 142.142224] r3:9a315800 r2:806c8c60 [ 142.145825] R4:9A315800 [142.148383] [<804681fc>](dev_watchdog)来自[<8006AF94>](call_timer_fn+0x2c/ 0xa0 ) [<8006af68>] (call_timer_fn) 来自 [<8006b4b4>] (run_timer_softirq+0x2b8/0x2d0) [ 142.171078] r6:00000000 r5:807bea80 r4:9a315a2c [ 142.175745] [<8006b1fc>] (run_timer_softirq) from [<8002ff7c>] (__do_softirq+0x114/0x238) [ 142.183923] r10:00000101 r9:00000001 r8:00000004 r7:8077ce84 r6:80740000 r5:00000000 [ 142.191817] r4: 8077ce88 [ 142.194373] [<8002fe68>] (__do_softirq) from [<80030544>] (irq_exit+0xb8/0x100) [ 142.201682] r10:00000000 r9:00000021 r8:9a005000 r7:00000000 r6:00000000 r5:00000010 [ 142.209574] r4 :80759938 [ 142.212132] [<8003048c>] (irq_exit) from [<8005c528>] (__handle_domain_irq+0x60/0xb0) [ 142.219961] r5:00000010 r4:80759938 [ 142.223570] [<8005c4c8>] (__handle_domain_irq) from [<800093e8 >] (gic_handle_irq+0x2c/0x5c) [ 142.231920] r9:00000021 r8:0eabc2ee r7:f4a02000 r6:80741ed8 r5:80742354 r4:f4a0200c [ 142.239734] [<800093bc>] (gic_handle_irq) from [<80013d80>] (__irq_svc+0x40/0x88) [ 142.247221] Exception stack(0x80741ed8 to 0x80741f20) [ 142.252278] 1ec0: 80741f28 fffffff7 [ 142.260464] 1ee0: 123e69f8 00000021 123e69f8 00000021 8076cbb8 00000002 0eabc2ee 00000021 [ 142.268648] 1f00: 00000000 80741f5c 00000017 80741f20 a6aaaaab 803d85e8 600f0013 ffffffff [ 142.276828] r7:80741f0c r6:ffffffff r5:600f0013 r4:803d85e8 [ 142.282550] [<803d8560>] (cpuidle_enter_state) from [<803d8774>] ( CPUIDLE_ENTER+0x1C/0x20) [142.290814] R10:8076CBB0 R9:00000001 R8:807420D4 R7:8074C140 R6:8076CBB8 R5:807420D4 [142.298707] R4:80774:80774.4:8074.4:8074.4:8074.4:8074.4:8074.4:14.44:14.44:14.44:ifly.14.4.4.4.4.400 lib youdy.ulyfor (cpu_startup_entry+0x178/0x23c) [ 142.309545] [<80053d70>] (cpu_startup_entry) 来自 [<80542530>] (rest_init+0x8c/0x90) [ 142.317291] r7:ffffffff [ 142.319849] [<805424a4>] (rest_init) 来自 [<807 (05_startker8>] 0x3A4/0x3B0) [142.327332] R5:8077C000 R4:8077C050 [142.330945] [<80705944>](start_kernel)来自[<80008078>]( 0x80008078 ) fec 20b4000.ethernet eth0: TX ring dump [ 142.346993] Nr SC addr len SKB [ 142.351357] 0 0x1c00 0x9a482800 1460 9a4605f0 [ 142.356151] cdb_esc = 0x18000000 [ 142.359385] 1 0x1400 0x9a482000 54 (null) [ 142.364179] cdb_esc = 0x58000000 [ 142.367414] 2 0x1c00 0x9a949e30 1460 9a460170 [ 142.372208] cdb_esc = 0x18000000 [142.375444] 3 0x1400 0x9a4c9000 54(空) [142.380238] cdb_esc = 0x58000000 [142.383473] 4 0x1c00 0x9a4ca800 1460 9a4602f0 [142.3802f0]30x0c08 [142.383473] 1、经多次测试发现问题多出现在CPU主动发送的时候 2、在出现问题时使用显示波器查看TXD波型,会有稀疏的波型生成 3、跟踪代码发现txq->cur_tx也在移动(在fec_main.c中的fec_enet_tx_queue函数中) 4、查看了ENETx_EIR寄出中的(BABR、BABT、EBERR、LC、UN、PLR)对应的位置(已配置EIMR),均未设置1 5、查看了以下寄存器未发现相关错误位置或计数不为0 6、查看了增强传输缓冲区描述符(ebdp->cbd_esc) 其中EE、FE、位置1、(正常情况下也有位置的),bit30也有被位置1的情况,但TXE没有位置,其他错误位置均未出现位置。 7、使用MII-Lite(COL、CRS去掉)问题依然存在。 8、RMII接口正常 现在是我无法找到相关硬信息来表示网络发送出现的问题。也无法进行及时的恢复操作。 从分析来看是发送数据包降速的非常低引起的。 在发送环绕冲满区和超时时间到才出现上面描述的内部报错。 |
只有小组成员才能发言,加入小组>>
1891个成员聚集在这个小组
加入小组我的项目我做主,使用GN+Ninja来完成构建系统(VSCode开发RT106X)
36293 浏览 0 评论
NXP IMX8应用处理器快速入门必备:技巧、使用、设计指南
4362 浏览 0 评论
6016 浏览 1 评论
6737 浏览 0 评论
NXP i.MX6UL开发板(linux系统烧录+规格+硬件+模块移植)使用手册
4182 浏览 0 评论
597浏览 2评论
求助,S32G上Core M启动后如何让Core A在Flash指定位置加载uboot?
588浏览 2评论
ESP32-WROVER-IE + LAN8720以太网,GPIO0电压只有1.6v,无法正常进入spi flash boot模式如何解决?
578浏览 2评论
求分享适用于PN7160 Android的NFC工厂测试应用程序
665浏览 2评论
746浏览 2评论
GMT+8, 2024-10-28 19:14 , Processed in 1.485140 second(s), Total 96, Slave 79 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
